This thread is about: [HOW TO] Wire in a sat nav device, it's in How To at the Honda Civic forum Civinfo; Bought a new tom tom and wanted to wire it up (like the earlier snooper post) I got the cig lighter connection and I thought ...
Old 8th July 2006, 16:52   #1 (permalink)
I got the cig lighter connection and I thought I could cut the end off and use the bare wires to connect it into the fuse box. but..........
The cig connector cable says "Input 12v and Output 5v"- does this mean my idea cannot be done as by putting it into a 12v supply in the fuse box may damage the tom tom unit????
please help
EDITED: Amended title.
Old 8th July 2006, 18:16   #2 (permalink)
Good thinking for being cautious! If you had snipped the wires, that would have been the end of the tomtom...
Go to Halfords (or any car bits place) and buy a female in-line cig lighter socket. It's just a stand alone cig lighter socket with 2 wires coming out of the back. Wire the 2 wires in to the fusebox (like the snooper), and then plug the tomtom cig plug into your hidden cig socket. Stuff the whole lot away up and under the dash - and you're done.
Old 8th July 2006, 19:21   #3 (permalink)
cheers pottsy!!!!!! genius that you are
Old 7th January 2007, 02:48   #4 (permalink)
daiashthomas's Avatar
if u disassemble the plug on your tomtom cable there will be a small PCB (Circuit Board). u can simply put this circuit board into a new housing and then hard wire from an ignition feed like the snooper post
daiashthomas is offline   Reply With Quote
Old 18th January 2007, 14:23   #5 (permalink)
warriorpete's Avatar
just bought a cig lighter socket to wire in my road angel but noticed that it only has one cable from it with a spade fitting on end. Presume i remove this and wire into fuse box - but how is it earthed? Should i get another sort with two wires?
warriorpete is offline   Reply With Quote
Old 18th January 2007, 22:16   #6 (permalink)
but dont expect the warrenty to be valid?
Mad4amanda is offline   Reply With Quote
Old 20th January 2007, 00:19   #7 (permalink)
u can use a spare or even a mobile fone charger as they are the same voltage
Similar Threads for: [HOW TO] Wire in a sat nav device
streaming mp3s to radio,new device roylatham Introduce yourself 1 24th August 2007 20:07
Tech Drive by Wire Minkster Engines and Transmission 11 24th June 2007 15:03
Amplifier How to wire an amp? Silver6 Ipods, MP3 Players and ICE 4 30th January 2007 19:15
tracking device - road pricing markymark81 Any non Civic chat here please! 0 11th January 2007 12:28
Tech Drive by wire CavOK Engines and Transmission 1 25th April 2006 03:14
