| This thread is about: [HOW TO] Replace headlight bulbs & front position light, it's in How To at the Honda Civic forum Civinfo; Also replaced H1's and H7's with nightbreakers. Only thing is that I managed to drop one of the H1 covers. Have no idea where it ... | ||
#41 (permalink) |
Also replaced H1's and H7's with nightbreakers. Only thing is that I managed to drop one of the H1 covers. Have no idea where it went - can't see it from the top. Used a long piece of wire(bent it to L shape) to maybe push it back from under the engine to make it drop out - no use though. Anyone have any ideas? Or should I just go to the dealers and ask them to jack the car up to get the cover out from under the car????
#42 (permalink) | |
#43 (permalink) |
I'm trying to change my side light/position light/whatever you to call them bulbs to some super white LED ones to match my HID headlights. I've taken the covers off the back of the light assemblies (and lost one in the bottom of the engine bay
#44 (permalink) | |
#45 (permalink) |
TYPE R GT (R-15016)
Just been looking at mine (CTR) , the left hand side as you look at it seems easy, but the battery side seems alittle more tricky. There seems to be some sort of air inlet tube right in front of the bulb housing cover next to the battery. Is this only on CTR'S ? and will it have to be removed ?
#47 (permalink) |
TYPE R GT (R-15016)
But I will never get my hand in between the battery and this pipe ? maybe I need to remove the battery then ?
#48 (permalink) |
I did, and I have got massive gorilla hands!
Your hand doesn't need to go right down, only partially, then use your thumb and index finger to undo the cap (clockwise), and just your fingers to remove the bulb, then holding the bulb between your fingers, use your other hand (left) to change it. It's easy honest, but if you are struggling remove the battery. |
#50 (permalink) |
Yeah but your not going down there, your hand needs to go down right behind the light cluster itself, before you get to the battery!
Thanks to Mr JP from:
#51 (permalink) |
Type-R GT -08
Well i tried to open the lid at the battery side today, just to look if it was possible. But i could not do it
I am waiting for a pair of 6000K D2R bulbs to replace my 4300K that i use now. That is the reason i tested it hehe. I guess you can remove the airpipe in some way to make it easier. |
| Bulbs Headlight replacement bulbs | Brian | Lights | 4 | 6th October 2007 17:24 |
| Bulbs Confused with the headlight bulbs for CTR | MoOriginal | Lights | 9 | 17th July 2007 13:02 |
| Tyre Other Front back or replace | candle | Wheels, Tyres, Suspension and Brakes | 4 | 2nd April 2007 12:29 |
| Fog Fog Light Bulbs | scol78 | Lights | 0 | 23rd March 2007 12:35 |
| Speakers Do I need to replace front & rear speakers? | richierich | Ipods, MP3 Players and ICE | 5 | 6th October 2006 12:31 |
