#62 (permalink) |
![]() Car: 2012 Silver 1.8 EX-GT
Thanks given: 119
Its the same as the Clarion unit has Std Honda connectors at the back including the 7 pin reversing camera port which my cable plugs directly into.
#63 (permalink) | |
Car: '09 1.8 3D,Alabaster Silver
Thanks given: 3
![]() I have a 3D (Type S) and I could not really use the guide but the idea of how to enter the camera wires in the car I used it and I thank you
Thanks to Robby_Alessio from:
#64 (permalink) |
![]() Car: 1.8cc EX, 5dr
Thanks given: 57
fyi this might help some ***
fyi if you dont mind me stealing this picture., basically bold red line is the cable and the dotted line is where you have to thread it. stage 1 thread it through the top , stage 2 there is an opening hole here , i threaded my chicken wire up from here to the top labelled .1. did a knot and pulled the cable through , stage 3 , again threaded the chicken wire up from point 4 to point 3 and again knotted the video cable to the chicken wire and pulled it through ! reason why i split it in two goes is its just toooo hard to thread it from the top and all the way down expecting it to come out of the grommit . so i split it in two parts. http://img17.imageshack.us/img17/3063/civicboot.jpg
#66 (permalink) |
Thanks given: 57
hello is it this reverse wire here . im too peel back the cable tidy plastic tube and scotch lock it .
can i scotch lock the negative to the black reverse wire also . i heard it will help signal quality? ![]() By carwashe at 2012-01-07 |
#67 (permalink) |
Thanks given: 119
Yes it is the reverse wire and yes if you want to connect the ground to the black you can
#68 (permalink) | |
![]() Car: 2007 Blue 2.2i-CDTi
Thanks given: 15
I did this and it does improve signal, however I found that the screen flickered as I put my foot on the brake. Connecting the negative to the boot lid on a nearby stud with a star washer & ring crimp did the trick! |
#69 (permalink) | |
Thanks given: 57
am i alright to use one of the screws that hold the brake light housing in place? |
#71 (permalink) |
Thanks given: 57
do u have a ring crimp and star washer you can kindly sell to me . i checked on ebay and you can buy em in mlutiples of 100 which i dont need lol
just a thought so evrytime i put it in reverse and if someone happens to touch my boot lid they are goign to be in for a shocker >? lol Last edited by cv65user; 8th January 2012 at 01:27. |
#72 (permalink) |
Thanks given: 57
big thx to bog ,reversing camera now installed after 3 weeks lol . didnt need an attenuator or needed the ground the reverse light in the end .
got a few tips i will update thread with pixs at had my warnings now!! undo all bolts i recommend one of these otherwise the nuts will fall into rear trim /floor and you will never find it if working outside ![]() remove rear brake lights first as the centre cluster is held on to these so brake lights must be removed first ![]() me taking out rear light cluster to saw a little hole ![]() getting my 12v feed ![]() moment of truth ![]() final product ![]() tidying up ![]() big thx to bog ,reversing camera now installed after 3 weeks lol . didnt need an attenuator or needed the ground the reverse light in the end . got a few tips i will update this thread with pixs at had my warnings now!! tadaaaaaaaaaaa
Thanks to cv65user from:
#74 (permalink) |
![]() Join Date: 25th May 2011
Urgent I need some help
[QUOTE=cv65user;1084905]fyi this might help some ***
fyi if you dont mind me stealing this picture., basically bold red line is the cable and the dotted line is where you have to thread it. stage 1 thread it through the top , stage 2 there is an opening hole here , i threaded my chicken wire up from here to the top labelled .1. did a knot and pulled the cable through , stage 3 , again threaded the chicken wire up from point 4 to point 3 and again knotted the video cable to the chicken wire and pulled it through ! reason why i split it in two goes is its just toooo hard to thread it from the top and all the way down expecting it to come out of the grommit . so i split it in two parts. http://img17.imageshack.us/img17/3063/civicboot.jpg[/QUOTI need some help to remove the rear door trim as I want to instal a camera.i done almost everything ,but I can not remove the trim where is the lights.i have unscrew 2 screws now I pull and I can not removed.please any tip how to removed.thanks |
#75 (permalink) |
hello. Who can install me reverse camera? i will pay for yoy. How much would be? I will come across to you if you live not far from RM8 (essex). Please contact me icky@inbox.lt
#76 (permalink) |
i-VTEC - DO YOU?
![]() Car: 2009 CTR, Black
Thanks given: 21
Seriously, how did anyone ever manage to get the cable plugged in without disassembling the dash! To those that did, I salute you! My hands, great as they are at a good number of tasks, are not well suited to this job!
#77 (permalink) | |
![]() Car: Silver Civic EX 1.8
Thanks given: 3
I have big hands but have no problem at all, make sure you have trimmed just a slither of plastic on the sides of the plug & it goes in just fine. |
#80 (permalink) |
Car: 2007 2.2 EX Nighthawk Black
Thanks given: 4
Thanks for the guide. Finally got round to fitting my Camera today, followed the instructions and no issues. It's brilliant. Big thanks to Bog and MrBozo for the video cable and camera!
| Tags |
| camera, navigation, reversing camera |
LinkBack to this Thread: http://www.civinfo.com/forum/how/51366-how-install-aftermarket-reversing-camera-easy-way.html
| CHUMPA13: “07 Honda Civic 5D 2.2 i-CTDi, Albaster Silver | This thread | Refback | 28th December 2012 08:58 | |
| Szybkie pytanie szybka odpowied¼ - Strona 26 | This thread | Refback | 26th June 2012 19:11 | |
| Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - NAVI-DVD!!! VIdeo gucken??? | This thread | Refback | 5th February 2012 16:04 | |
| Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - NAVI-DVD!!! VIdeo gucken??? | This thread | Refback | 10th August 2011 10:44 | |
| Szybkie pytanie szybka odpowied¼ | This thread | Refback | 30th May 2011 10:05 | |
Similar Threads for: How to Install an Aftermarket Reversing Camera - The easy Way!
| Reversing Camera for 09 EX-GT | Bog | Gordons Honda | 1 | 23rd November 2010 23:36 |
| New Aftermarket Reversing Cameras | Autobulbs | General commercial posts | 0 | 20th May 2010 09:47 |
| Ambient Lighting Easy Install | ante00 | How To | 9 | 27th March 2010 23:35 |
| Subwoofer easy small install... easily removeable? | Unknownsoldier | Ipods, MP3 Players and ICE | 20 | 22nd June 2009 08:20 |
| reversing camera | albmg1977 | Honda CR-V | 1 | 23rd February 2009 15:34 |
