Old 21st July 2012, 23:56   #81 (permalink)
kevin43's Avatar
Car: 2,2 i-ctdi exclusive
Thanks given: 2
Originally Posted by awwatsonisajedi View Post
Thanks for the guide. Finally got round to fitting my Camera today, followed the instructions and no issues. It's brilliant. Big thanks to Bog and MrBozo for the video cable and camera!
video working too? where can i buy this? Thanks
kevin43 is offline   Reply With Quote
Old 22nd July 2012, 20:40   #82 (permalink)
Bog
Bog's Avatar
Car: 2012 Silver 1.8 EX-GT
Thanks given: 119
Have look at the links in my signature
Thanks to Bog from:
Old 23rd July 2012, 23:48   #83 (permalink)
kevin43's Avatar
Thanks given: 2
hi
i want in the car this all
: Popcorn: . do you have all for camera, video mp3... ? i have civic 2006 no usb
Old 24th July 2012, 14:52   #84 (permalink)
kevin43's Avatar
Thanks given: 2
Question
you know help me? : Zmätený:
Old 24th July 2012, 15:05   #85 (permalink)
Bog
Bog's Avatar
Thanks given: 119
Yes, I can help...
What are your DIY skills like?
No point even considering this is you don't have basic Car electrics knowledge.
BTW, where are you from originally? Slovakia?
Old 24th July 2012, 16:03   #86 (permalink)
kevin43's Avatar
Thanks given: 2
I think so it´s not complex for instalation... here is all for instalation.
I need only buy.
yes i´m from Slovakia but now i´m in ireland.
sorry for my English
Old 24th July 2012, 16:50   #87 (permalink)
Bog
Bog's Avatar
Thanks given: 119
OK
If it is easier for you, send me a PM in Slovak with exactly want you want... My partner is Slovakian and she can translate for me
Old 1st August 2012, 12:34   #88 (permalink)
scoobyscotty's Avatar
Car: 2007 1.8 5dr ex champ
Thanks given: 3
Can someone help please, thinking of doing this job at the weekend and just a bit confused. When i undo the 3 nuts on the rear tail gate am i removing the big plastic light cluster on the back or just something else?
scoobyscotty is offline   Reply With Quote
Old 2nd August 2012, 00:08   #89 (permalink)
speak2al's Avatar
Car: 2007 Blue 2.2i-CDTi
Thanks given: 15
This one:
(Image borrowed from Syx's thread, [HOW TO] Replace rear centre light panel (Pre-2009))
Note that you don't need to remove the centre panel to install the camera; I used that picture because it was handy!
When running the video lead from the camera to the nav unit, consider running an extra wire as well. You may wish to add a component at a later date that allows you to switch the camera on whilst driving forward and it saves a whole lot of hassle having to go through the whole process again!
You'll need to leave enough slack in the tailgate to connect to the red power line of the camera, then a couple of metres in the front of the car to connect to the new component.
speak2al is offline   Reply With Quote
Old 2nd August 2012, 00:28   #90 (permalink)
Thanks given: 3
Originally Posted by speak2al View Post
This one:
Many thanks
Im not sure if thats the right panel that i need to remove, its stage 2 in the instructions. its the bit were i feed the camera cable from out of the car into the inside tailgate.
Old 2nd August 2012, 13:06   #91 (permalink)
speak2al's Avatar
Thanks given: 15
Many thanks
Yes it's correct, have a look at the attached pictures showing my camera. You file a groove in the bottom of the tail light such that the wire can pass through without getting squashed when the tail light is tight in place. I tucked the wire up into the space as shown.
Just the three nuts to remove, careful not to drop them inside the trim as the guide says!
Thanks to speak2al from:
Old 2nd August 2012, 13:28   #92 (permalink)
Thanks given: 3
Thanks for the help, should have better idea what I'm doing now. I'm a bit of an over thinker, I plan everything out before I do anything
Old 15th August 2012, 10:06   #93 (permalink)
Thanks given: 3
Smile tip for fitting the cable
Just been fitting the cable into DVD unit and found a good tip, I'm sure other people have done this but I just thought I'd share.
Open door as far as you can kneel with you feet under you and lean forward loads easier to reach inside.
I used my phone to take photos behind the unit to check I got the right place and after to make sure it was fitted ok.
Cable fitted under 10 mins
Hope this help anyone stuck
Thanks to scoobyscotty from:
Old 16th August 2012, 17:00   #94 (permalink)
Thanks given: 3
Does anyone have any tips for feeding the cable down the boot and back into the car, I'm stuck. Tried some stiff cable but no luck.
Old 19th August 2012, 08:12   #95 (permalink)
hello. would the reverse camera work on my 2007 Honda civic EX american style car?
http://0.tqn.com/d/cars/1/0/k/e/lk_0...x_interior.jpg
http://images02.olx.com/ui/3/74/67/55226767_1.jpg
honda200713 is offline   Reply With Quote
Old 19th August 2012, 08:53   #96 (permalink)
Bog
Bog's Avatar
Thanks given: 119
I don't think you can as the AFIK the Nav unit installed in your Civic does not have the 7 pin connector at the rear of it
like this...
Back Up Camera Using Factory Navi? - 8th Generation Honda Civic Forum
Maybe yours/later versions have it... if yes, then yes you can have a camera
Old 2nd November 2012, 17:33   #97 (permalink)
Car: 2.2 i-CTDi EX, Pearl Black
Thanks given: 14
Bog,
AS you can see I'm a newbie to Civics and this forum. I would love to connect a rear view camera to the Satnav ( or should I saw pay a guy across the road to do it as I'm hopeless with electrics) - would you mind posting exactly what you need to get the job done, special cables, connectors etc.
many thanks
Burroo
Burroo is offline   Reply With Quote
Old 31st December 2012, 17:50   #98 (permalink)
Thanks given: 2
Great guide, got my camera working 1st time on my oem sat nav with your cable.
got the cable in the back easily, just feel where the other cables are and you can feel where you are going.
I was confused originally, as i was trying to put the cable into the back of the screen! no room to get your hand up there!
fed the wire though the car just hiding it under the roof lining seal, took 1 minute.
Also found my extension for camera signal was male on both ends, and my connector on the lead was male, so i cut the female connector off the part by the camera and soldered it on the extension for connecting to your cable.
really pleased with quality of the camera.
thanks
dynamique_g is offline   Reply With Quote
Thanks to dynamique_g from:
Old 31st December 2012, 19:31   #99 (permalink)
Bog
Bog's Avatar
Thanks given: 119
thanks
Enjoy... it's a great and useful mod
Glad you managed to do it without having to take dash apart which in it's self is not too hard, but you saved some time
Old 26th January 2013, 19:04   #100 (permalink)
peter212693's Avatar
Thanks given: 1
Hi guys,
I've started to fit my camera today and got a little stuck. I got it in the back of the nav unit, well I think I did it went into what felt like the right slot! I have got my cable through to the tailgate so I need to get it through the rubber cover piece but it won't go through. I have used a coat hanger but when trying to pull it back through the coat hanger come but the wire will not pull through.
Any tips
peter212693 is offline   Reply With Quote
Tags
camera, navigation, reversing camera
LinkBack to this Thread: http://www.civinfo.com/forum/how/51366-how-install-aftermarket-reversing-camera-easy-way.html
CHUMPA13: ´07 Honda Civic 5D 2.2 i-CTDi, Albaster Silver This thread Refback 28th December 2012 08:58
Szybkie pytanie szybka odpowied¼ - Strona 26 This thread Refback 26th June 2012 19:11
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - NAVI-DVD!!! VIdeo gucken??? This thread Refback 5th February 2012 16:04
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - NAVI-DVD!!! VIdeo gucken??? This thread Refback 10th August 2011 10:44
Szybkie pytanie szybka odpowied¼ This thread Refback 30th May 2011 10:05
Similar Threads for: How to Install an Aftermarket Reversing Camera - The easy Way!
Reversing Camera for 09 EX-GT Bog Gordons Honda 1 23rd November 2010 23:36
New Aftermarket Reversing Cameras Autobulbs General commercial posts 0 20th May 2010 09:47
Ambient Lighting Easy Install ante00 How To 9 27th March 2010 23:35
Subwoofer easy small install... easily removeable? Unknownsoldier Ipods, MP3 Players and ICE 20 22nd June 2009 08:20
reversing camera albmg1977 Honda CR-V 1 23rd February 2009 15:34
