| This thread is about: Stop the seatbelt beeper, it's in How To at the Honda Civic forum Civinfo; Originally Posted by TTDegs I'm just going to assume my EX is like the two of yours (It's late, dark and raining outside!) No dedication, ... | ||
LinkBack (4) | Thread Tools | Display Modes |
#46 (permalink) |
I find the beep very annoying, but at least it is not as bad as the Avensis I used to have. On that, if you drove without your seatbelt on (which I only ever did very slowly inside a car park when I was moving the car a short distance and was about to get out again) it would beep and then BEEP and then SCREEEEECH at you.
I always wear my seatbelt, and the ONLY time I forgot was on the Civic test drive! I was so busy working out what all the controls were for that it slipped my mind. |
#48 (permalink) |
Thanks, now I've finally silenced the beeper.
I never ever drive without the seatbelt buckled; twenty years of practice have shown that I don't need any device to tell me this. So it was good to get the car stripped for this noise which might cause distraction and block useful information. Let's keep simple matters simple. |
#49 (permalink) |
Why not disconnect the plug and attach a new loop circuit to an axtra switch under the clutch ?
That way pressing down the clutch would make the circuit and "hay presto" the beeper would work ! That way you will be reminded only when you forget, and only when you go to drive off ! If you didn't put your belt on, you would be reminded at every gear change! I think this would fulfill all of the required safety features and also stop the annoying Beep in a very simple fix. |
#51 (permalink) | |
What a good question, I had not thought of an iShift solution, as I would never consider owning one myself. I maybe some time on this one! |
#52 (permalink) | |
Got it. This one would work for all and is simpler to do. Same as the clutch, but under the handbreak lever instead. That way it would only sound when you are in motion or the handbreak is not applied! In record time! |
#53 (permalink) | |
This is the handbrake on: hb_on.jpg And off: hb_off.jpg And from the rear: hb_back.jpg The beeper circuit needs to have an earth only when the handbrake is released. So re-connect the plug, snip the black wire and connect the snipped bit that is not earthed to your new wire. A reminder of the plug area: seatbelt_connector.jpg Run this wire to the handbrake area, and this wire needs to be earthed when the handbrake is released, so I would do something like this: Insulate this bit of the handbrake: mod1.jpg Use a self tapper and clamp: mod2.jpg And attach like this: mod3.jpg Now attach your wire to the self tapper. It will earth when the lever is released. I didn't bother, because I like it as it is, but this may be useful for someone forgetful... |
#55 (permalink) |
would it not just be easier to put your seatbelt on before you start the engine??
i really dont see why you all find it so annoying. |
#56 (permalink) | |
But what would be the fun in that now? ufo.gif |
#57 (permalink) | |
#58 (permalink) | |
12th June 2006 1.8EX
I achieve the same (No step 2 & 3), you could too get a 1.8! ![]() |
#59 (permalink) | |
#60 (permalink) |
I shall re-write the list to make it clearer:
