This thread is about: Sound isolation, it's in How To at the Honda Civic forum Civinfo; Hi, Dynamat essentially seems to be the same thing as vibroplast - and I suspect it works out pretty well (better than usual bitumen without ...
LinkBack (8) Thread Tools Display Modes
Old 29th January 2008, 10:50   #41 (permalink)
Dynamat essentially seems to be the same thing as vibroplast - and I suspect it works out pretty well (better than usual bitumen without the foil lining).
Anyhow, as I have a new and better Civic now, I will probably be doing this all over again, which means more pics and hopefully better results
Rasmus is offline   Reply With Quote
Old 1st February 2008, 22:50   #42 (permalink)
Having posted a similar tread the this one on an Impreza website (my last car) I've been looking at this tread with interest after swapping the Subaru for a Civic this week.
In the past I've used NoiseKiller (Noisekiller UK - Car Soundproofing - Vehicle, Industrial, and Marine Sound Proofing) and their barrier mat is excellent. However recently, I have found a cheaper (per sqft) and possibly better alternative:
Second Skin Audio. The manufacturers offer great advice on the three different speps to audio bliss!: http://www.secondskinaudio.com/store.php?category=70
The UK distributors are based in Oxford and their partner company (Oxford Car Audio) have been honest help over the years with a number of audio installations I have done: Car Audio Direct - Second Skin Damplifier Bulk Kit - Accessory
I've got £200 worth arriving tomorrow (2x Damplifier bulk pack & 4x Overkill v2) and so that's my weekend project sorted! (As a note, the Pro version of the Damplifier & Overkill is just twice as thick).
I'll post a new thread when I'm done.
danieldenham is offline   Reply With Quote
Old 3rd February 2008, 23:14   #43 (permalink)
Ramus, you'll like this:
Sound Deadener Showdown
Dan
Old 14th March 2008, 23:33   #44 (permalink)
Andiww's Avatar
Hi there! Before I change my speakrs I will surely isolate the doors. But does it make sense to put the isolation material on the internal side of the plastic panels? Shouldnt we put the bitumen on the metal parts of the doors? Or maybe there is no difference....?
Andiww is offline   Reply With Quote
Old 15th March 2008, 11:20   #45 (permalink)
I guess it would be best to do both - just take care not to obstruct the drainage holes or the windows - I would do the deadening first and then look again whether or not to change the speakers, the old ones might be quite good enough with proper soundproofing in place
Old 15th March 2008, 11:49   #46 (permalink)
Diesel Demon
damianscott71's Avatar
Soundproof both, and replace the speakers too. The honda supplied ones are pants. I also ran some speaker foam around the egde of the door trim to make a better seal and thus prevent (or minimise) bass leakage.
Because I added the seal about a year after I did the speakers, I could tell that there was a noticable improvement in the bass response with the foam. A few people have complained about the lack of bass from the infinity speakers. You can buy 10m reels of the foam strip from CPC, can't remember the part number though. It's really cheap, only a few quid.
Old 15th March 2008, 15:14   #47 (permalink)
Yes, it makes sense to put isolation materials on both the plastic and the metal. The sound deadening material has damping effect on all surfaces, so it will reduce rattles that the plastic makes (especially if you have a subwoofer or listen to loud music). And ofcourse - if you are thinking of changing speakers as well then do all at once - and don't try to save on the materials - it is really not worth it. Regular bitumen (which needs heating before sticking) is heavy, more trouble and the results aren't in fact as good as with special components such as Vibroplast, Bimast etc. Some people have even tried roof fixing bitumen and I really can not see why - the proper materials you need to do all four doors on a Civic cost about 50-100 euros, while the car itself costs around 18'000 euros.
Old 15th March 2008, 17:25   #48 (permalink)
Andiww's Avatar
Thanks for your help! Now I don't have much spare time but will do this in not far future. I'll post some pics. One more thing... Before I put the sound isolation, should I remove the original one that honda gives as standard?
Old 13th April 2008, 09:55   #49 (permalink)
Right, since my last car was destroyed by a punk kid in a BMW, I now have a new one, which also needed some work done about the noise. I was a lot smarter now, I used the right materials (vibroplast) from the beginning and not wasting any time.
Here are some photos.
Doors:
Picasa Web Albums - Rasmus - Civic
Rear arches:
This time I did not change the speakers, but installed a FLI 10" active subwoofer instead to beef up the system. Its good enough and the car is nearly ready - just need to figure out how and where to install a satnav and parking sensors so my gf doesn't reverse into anything.
Old 23rd April 2008, 18:11   #50 (permalink)
Sound isolating the roof?
last time I got really scared by a big drop of water falling on my roof. First I thought that it was something massive, like a chestnut, but there was no tree or similar and it did rain quite hard some minutes before. Since then, it reoccured several times when waiting under the edge of a bridge or similar.
So I was wondering if it would be complicated to remove the ceiling to put some sound isolation behind it? I'm especially concerned about plastic parts that could easily break or the window airbags...
Greetings,
DynoFK2
DynoFK2 is offline   Reply With Quote
Old 28th April 2008, 11:03   #51 (permalink)
Yes, the roof needs some sound deadening materials too - it acts like a diffuser and magnifies the noise that raindrops make and also wind noise at higher speeds.
I have not yet looked into removing the roof panels, but my friend from a Honda service says that to do that you have to remove quite a lot of trim...
If anyone manages to do the roof as well, please be so kind to take a few photos.
LinkBack to this Thread: http://www.civinfo.com/forum/how/5241-sound-isolation.html
Zgomot rulare Civic - Hondafan This thread Refback 21st November 2008 16:15
HONDAFAN Forum :: Vizualizare subiect - zgomot rulare civic This thread Refback 27th April 2008 18:04
Missione rumore - Altro... This thread Refback 24th April 2008 12:50
Sound Deadening ...Whats the Best Way??? - Talk Audio Forums This thread Refback 21st April 2008 12:14
Forums CivicYume :: Voir le sujet - Installation Audio This thread Refback 16th March 2008 15:21
aftermarket speakers - Audio This thread Refback 12th March 2008 22:04
Untitled document This thread Refback 24th October 2007 18:48
Zvočna izolacija This thread Refback 18th October 2007 09:22
Similar Threads for: Sound isolation
[How-To] Installing Parrot CK3100 with Multicomm ; blue lights ; sound isolation opjepass How To 36 17th October 2008 12:25
Windows Isolation Switch Maldax Bugs, faults and irritations 1 6th October 2007 21:26
Sweet sound fennj Type-R 8 9th September 2007 20:01
Speakers What Sound Kit would you get for your new civic for £700 or under? psykik Ipods, MP3 Players and ICE 10 3rd September 2007 22:39
Music sound system mrcanadian Bugs, faults and irritations 6 24th August 2006 12:27
