This thread is about: [HOW TO] Swap the microphone from left to right, it's in How To at the Honda Civic forum Civinfo; Well it didn't take long before I got the drill to the Civ... The idea is that the microphone for the Voice Control and the ...
Old 30th April 2006, 16:28   #1 (permalink)
The idea is that the microphone for the Voice Control and the HFT is mounted on the left. It's not the best position and sometimes people you phone complain of muffled speech. So I've moved it from the left to the right to see if it makes it any better. It certainly sounds clearer when stationary, but I've yet to test it on the move.
Pop off the grey cover with your fingers (insert at the lower end), then unscrew the 2 screws. The mic is on the left and you can easily unclip it:
On the back, unplug the green connector:
Then remove the other half of the green connector by poking in a small flat head screwy:
With the connector off you can now unclip the shiny black cover (two clips at the top) pictured below removed. You can then remove the mic and clip the shiny black cover back on:
Use a 2mm drill and drill lots of holes. I did it in the same pattern as the left, but at the top (what will be rearmost):
The finished new holes:
On the rear I've removed a plastic post to allow the mic to fit in it's new position:
Now I've reconnected the mic and stuck it to the hole on right using a bit of double sided number plate sticky (nice and sticky and thick and foamy).
EDIT 31/7/06
The "CivPilot mod".
Put the mic in with the wires on the right hand side - it is directional and it will pick up your voice better this way.
See posts below for full details.
The green connector is now the wrong way round, but I've put it loosely where it was and taped it into position. It's a tight fit in there when you put it back, so it needs to be in that position:
Poke it all back in - when you do, make sure the clips at the top re-engage into the roof - keep it pushed up (and engaged) while you do the two screws back up:
Admire your first modification, knowing that it can all go back to standard if needed:
Usual disclaimer: it's all your fault, not mine.
Thanks to Pottsy from:
Old 30th April 2006, 17:00   #2 (permalink)
jme1978's Avatar
Great post! top work!!
J
jme1978 is offline   Reply With Quote
Old 30th April 2006, 17:28   #3 (permalink)
basegreen's Avatar
Ace, well done
Old 9th May 2006, 13:51   #4 (permalink)
Pottsy,
Has anyone at Honda looked at this.. and if so why havent they taken the hint?
honda_girly is offline   Reply With Quote
Old 9th May 2006, 14:42   #5 (permalink)
basegreen's Avatar
Can those bulbs in there be changed to the same blue lighting as the footwell?
Old 9th May 2006, 16:02   #6 (permalink)
Ancient Nerd's Avatar
Pottsy,
Great information, many thanks for sharing it.
Has it made a big improvement, or was it marginal? I would love to avoid some of the howlers from the Speech Recognition system
Old 14th May 2006, 21:56   #7 (permalink)
pjelsworth's Avatar
This is great information. I really would like to know if it made a big difference. I have no problem at all with voice commands, but the hands-free telephone is dreadful ..... nobody can hear me at all when I am doing anything but slow speeds ..... I need to fix this. Does anyone else have the same problem?
Old 14th May 2006, 22:06   #8 (permalink)
basegreen's Avatar
EVERYONE. It's just not up to the task.
Old 17th May 2006, 13:59   #9 (permalink)
Smell My Cheese!
richierich's Avatar
Its good to know I am not the only one having these issues, has anyone had anything from Honda about this matter, the dealer has contacted them regarding this, but if anyone has any news it would be good to know.
Also, did moving it improve the sound quality? I rang myself from the car earlier left a message on the office voicemail, absolutely appalling quality, just got to try to get a copy of the message on to the computer to email to dealer now.
News on the success of the change would be appreciated.
Richierich
Old 17th May 2006, 16:40   #10 (permalink)
Smell My Cheese!
richierich's Avatar
Just called Honda Customer Services, who are not aware of any complaints/problems concerning the HFT on the Civic, they have only had compliments, I have proposed to email them a link to this site (any opposition), in the mean time it might be worth more people bringing it to their attention.
Call - 01753 590760
Email - customer.services@honda-eu.com
I spoke to a Lady called Jo.
Richierich
Old 17th May 2006, 17:09   #11 (permalink)
basegreen's Avatar
Call - 01753 590760
Richierich
Give the link to Sarah Roseblade. She's the CS Dept manager.
Old 17th May 2006, 19:30   #12 (permalink)
Explosive Mind Unleashed
Kpow99's Avatar
Call - 01753 590760
Richierich
They are lying, I called them about a week after delivery as my aftersales couldn't/wouldn't help. Raised the point and CS where like so I asked if there was a technical department to speak to ..."Are you a dealer?" no so they gave me the number of Honda Chiswick, spoke to a receptionist who said they were all busy and left a message for call back.....no call. I'll go round the block again when I have some time to do so, too busy posting on here at the moment
Kpow99 is offline   Reply With Quote
Old 17th May 2006, 19:47   #13 (permalink)
Originally Posted by Ancient Nerd
Pottsy,
It's marginally better, but still not good enough. Can be very quiet on the motorway for the other party, but shouting at the mic helps!
Old 17th May 2006, 20:03   #14 (permalink)
basegreen's Avatar
sounds like the issue is with the mic gain then, really
Old 17th May 2006, 22:20   #15 (permalink)
Smell My Cheese!
richierich's Avatar
With regards to the mic gain the dealer in Oxford did hint at the fact that there was a way to increase the sensitivity of the microphone, I did not push him too much, but it seemed as though there is some set up function that uses the eco lights as a gauge to show how well the microphone is listening they recommend it is 2/3 of the way up the scale.
Its funny that you mention Chiswick Honda, it is there Corporate sales division I am dealing with, although I received an email tonight to say Hoonda would contact me direct.
We'll see what happens, might call the Oxford guy and ask him if you can increase the sensitivity.
I managed to ring myself earlier and leave a message on my mobile phone, then used the phones memo recorder to record the message to the phone, beamed it to the laptop and converted it to a .wav, I might email that to them, I was on the brand new tarmac on the A34 north of Oxford, could barely hear my voice.
Maybe if we all shout loud enough they might hear us, or do you think the fact that we are all using the HFT means they can't hear!
Richierich
Old 18th May 2006, 08:55   #16 (permalink)
Kpow99's Avatar
Honda CS told me that Chiswick have a very good Tech dept that we the public can talk to as we can't talk to the Slough bunch
Old 21st May 2006, 23:38   #17 (permalink)
Fedorov's Avatar
Just had a thought today... you couldn't do this mod on my EX as the big rocker switch to operate the glass-roof is on the right side - bit trickier if you've got a glass-roof anyway!
Old 3rd July 2006, 19:30   #18 (permalink)
move the mic
i have moved my mir to the drivers side and it has made a massive differenc, everybody who used to complain when i used it with my phone now says it's a million times better and a couple have even said they didn't realise that i was on the hands free !!!
bates65 is offline   Reply With Quote
Old 24th July 2006, 08:46   #19 (permalink)
steveking1000's Avatar
Just did it this weekend. Great guide, thanks. I couldn't quite drill as neatly as you but close. I also put some padding between the mic and the roof to try and keep other noises to a minimum.
Just spoke to the wife on the way to work this morning, and the difference is like night and day!
Thanks again for the guide.
steveking1000 is offline   Reply With Quote
Old 24th July 2006, 10:36   #20 (permalink)
Galaxy class starship
Copycat's Avatar
If you thought that was good, then go and check out all the other HowTo topics at
http://www.civinfo.com/forum/viewforum.php?f=12
Similar Threads for: [HOW TO] Swap the microphone from left to right
[HOW TO] Modify the EX HFT for better microphone performance WonkySights How To 62 21st November 2007 21:40
Voice recog Setting Microphone Level richierich Electronics 40 20th July 2007 13:18
Voice recog Microphone adjusment rayhopkins Electronics 5 10th July 2007 13:05
Anyone for a Swap Topcat For sale and Wanted 2 24th November 2006 00:58
[HOW TO] Set Microphone Level richierich How To 0 23rd May 2006 16:24
