This thread is about: Tyre rotation calculator, it's in How To at the Honda Civic forum Civinfo; Following a long discussion about tyre rotation , I've been meaning to make a calculator to work out the optimum rotation mileage (and more). You'll ...
Old 7th May 2007, 10:28   #1 (permalink)
Following a long discussion about tyre rotation, I've been meaning to make a calculator to work out the optimum rotation mileage (and more).
You'll need a tyre depth gauge, pictured below (about £3 or £4).
Anyway, here's the calculator:
http://www.civinfo.com/forum/rotate.php
You enter your current tread depths and what you consider to be the minimum acceptable end-of-life depth and it will tell you stuff like:
You should rotate your tyres at 12,334 miles. The set will need replacing at 24,668 miles.
If you don't rotate your tyres, the fronts will wear out at 21,144 miles, and the rears will wear out at 29,602 miles.
Or, if you missed the optimum rotation point:
You should have rotated your tyres at 8,805 miles. However, if you do it now the set will need replacing at 16,766 miles. The front tread depth will be 3.1 mm, and the rear tread depth will be 2.5 mm.
If you don't rotate your tyres, the fronts will wear out at 13,926 miles, and the rears will wear out at 23,952 miles.
Old 7th May 2007, 10:48   #2 (permalink)
sco77harris's Avatar
whats all this about then
Old 7th May 2007, 11:04   #3 (permalink)
JoeyF's Avatar
What a great idea, I just generally wait for the front to wear to something near minimum and then change over, at least now I know now when to rotate and when to start saving for a new set!!!
Old 7th May 2007, 11:06   #4 (permalink)
oh i see
Old 7th May 2007, 14:53   #5 (permalink)
There seem to be different schools of opinion on this one.
Some say rotate, some say leave the tyre/wheel on the corner it has got used to.
Being lazy guess which school I've joined ?
Old 7th May 2008, 20:21   #6 (permalink)
in the manual it is specified that you should rotate at 10.000 km...
toto is offline   Reply With Quote
Old 8th May 2008, 09:12   #7 (permalink)
Glepor's Avatar
Not a big fan of rotation. Don't like having to shell out for all 4 tyres at once!!
Glepor is offline   Reply With Quote
Old 15th May 2008, 11:25   #8 (permalink)
Coldwarkid's Avatar
You should rotate your tyres at 42,000 miles. The set will need replacing at 84,000 miles.
If you don't rotate your tyres, the fronts will wear out at 42,000 miles, and the rears will wear out at 700 miles
Coldwarkid is offline   Reply With Quote
Old 15th May 2008, 12:14   #9 (permalink)
My tyres rotate quite nicely on their own.
Much prefer to replace two tyres at a time (fronts) rather than wait and get stung for four at once if I rotated.
dave9_3 is offline   Reply With Quote
Old 15th May 2008, 12:22   #10 (permalink)
I was going to crack that one but decided against it
Similar Threads for: Tyre rotation calculator
Tyre Pressures Maldax Wiki Article Discussion 15 27th May 2008 17:58
Tyre Other new tyre KEN BYE Wheels, Tyres, Suspension and Brakes 0 5th June 2007 17:10
Spare Tyre repair Kit mgdoffshore Wheels, Tyres, Suspension and Brakes 3 31st March 2007 20:37
MPG Gas Mileage and Vehicle's Costs Calculator paulosilva76 Engines and Transmission 3 20th January 2007 15:55
Spare New tyre - ouch! Hartside Wheels, Tyres, Suspension and Brakes 42 11th October 2006 00:25
