This thread is about: How to install an entire ICE system, it's in How To at the Honda Civic forum Civinfo; First off, many thanks for the inspiration of previous 'How To's' especially Pottsy for head unit removal and speaker replacement as well as those contributors ...
Old 11th May 2007, 14:58   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Swindon Japster's Avatar
First off, many thanks for the inspiration of previous 'How To's' especially Pottsy for head unit removal and speaker replacement as well as those contributors for iPod icelink.
Firstly, I replaced the existing speakers, front and rear with Kenwood 17cms (Components in the front). An improvement but basically the headunit is just not up to it. Amplification was required.
Power cable run from the battery, fed in to the the battery termination 'box' with a carefully drilled hole.
Although not close to the battery, I ran the cable through a main loom grommet found in upper drivers footwell.
Because of a lack of pre-out in the headunit, speaker cables were run front to back, through amp 'high inputs' and then back to pick up again at the headunit (I used an Autoleads SOT lead to save cutting the original wiring).
The amps (a Sony 4 channel for the front and rear speakers and an amplied Pioneer active sub box) are mounted neatly under the seats. Although the routing of this volume of wiring takes time in order for the seats to return to their 'down position'. However, this way none of the boot space is taken up and the sub is more effective as it is within the cabin space.
Th Pioneer box has a bass controller, which is a nice feaure but another wire to run. This is housed within the roll top draw that is home to cupholders.
With the sound system sorted my attention turned to entertaining the children.
As I wanted to put a DVD player and hook up for a Playstation 2 in the glove box, it was easier to take the glovebox right out - 2 screws, 2 plastic studs in the front lip, 2 'bolts' under the end panel of the dash, another that is exposed with the cetre console removed and a 'hidden' screw/bolt that secures the rear of the glove box to a 'hanger'
'Hidden' screw on rear of glove box
My kids have a 'Buzz' game which have specific conrollers for PS, requiring a USB connection, which was a bit of a pain as wireless controllers that suit most games are literally plug and play. Whilst I was fitting the USB I also fitted a remote reset button for PS. The remote infrared eye for the DVD is run down the centre console to the rear.
USB and reset in drivers armrest cubby.
I had the 6.5" screens professionally fitted by Veba with some 'flush mounts'. These screens have an infrared transmitter for wireless headphones and also link with an 'AV switcher' (mounted above passenger kick panel) that allows either video source to be shown on either screen (no arguing from the back hopefully).
The screen cables were awkward to run down the inside of the seat backs as the clips that hold them on are delicate ( 3 large and stiff fixings at the top, smaller clips down the 'non airbag' side) If fact, although I was careful, my dealer managed to break them when I had a seat cover changed recently!
Earthing points for most of the visual kit was picked up on a stud located on the passenger side inner wing.
Finally Dension icelink was installed with lead through to silver cubby under radio.
No doubt I have been short on detail at times and would welcome any questions.
A happy SJ.
Swindon Japster is offline   Reply With Quote
Old 11th May 2007, 15:07   #2 (permalink)
apemonkeyman's Avatar
If you put the backs of the seats down, don't the amp & sub get in the way when the seat bases collapse to the floor?
Old 11th May 2007, 15:10   #3 (permalink)
Bog
Bog's Avatar
WOW! That is very good and thanks for writing it up!
Old 11th May 2007, 15:46   #4 (permalink)
Wine and cooking !
l-noel's Avatar
Very impressive !
Old 11th May 2007, 16:05   #5 (permalink)
basegreen's Avatar
I bet the kids do get a buzz with those bad boys under the rear seats
Old 11th May 2007, 16:32   #6 (permalink)
Apemonkeyman,
Don't use this facility as carry kids around and also have access to a van.
SJ
Last edited by Swindon Japster; 11th May 2007 at 16:37. Reason: Should have included apemonkeymans reply
Old 11th May 2007, 16:34   #7 (permalink)
I only go nuts with the bass controller when they are not in situe. However the missus loves it!
SJ
Old 11th May 2007, 17:10   #8 (permalink)
Apemonkeyman,
SJ
It wasn't a criticism, just a question to bear in mind if I chose to install similar - I do need to be able to fold seats down so wondered if the amp & sub got in the way of that, thus making this unsuitable for me...
Old 11th May 2007, 17:26   #9 (permalink)
basegreen's Avatar
SJ
Good stuff
Old 11th May 2007, 17:27   #10 (permalink)
sco77harris's Avatar
nice job
Old 11th May 2007, 22:40   #11 (permalink)
Harps's Avatar
nice work mate looks good!
Old 12th May 2007, 08:43   #12 (permalink)
Remember to tell your insurer that you have made all those modifications or you could find them or the whole car is not covered.
Ian
Parky is offline   Reply With Quote
Old 14th May 2007, 15:25   #13 (permalink)
Meino's Avatar
Can you be more specific about how you run the power cable into the car?
I have to check for the main loom grommet... Is it left or right?
I asked my dealer recently how I could get the power cable inside. They told me I had to drill a hole to run the power cable through....
Meino is offline   Reply With Quote
Old 15th May 2007, 10:03   #14 (permalink)
No worries AMM, didn't take it as a criticism. I originally considered a new Blaupunkt 4 channel for its size, perhaps mounting behind glove box, but information regarding the new, car specific, small units is scarcer than their avaialability, so I gave up. The underfloor area in the boot was another favourite for a while, seat backs are a common mounting place but again all of these will limit practicality.
SJ
Old 15th May 2007, 10:05   #15 (permalink)
Ian
Thanks Ian, intestingly I have just changed insurers and Elephant cover up to £750 worth of kit as standard (also much cheaper than the AA).
SJ
Old 15th May 2007, 10:10   #16 (permalink)
Meino,
Pictures I took were of a RHD car, guess yours is LHD, but also guessing that the grommets etc are in the same place? The one I used will be behind your glovebox close to the centre console line.
SJ
Old 15th May 2007, 11:16   #17 (permalink)
Meino's Avatar
Meino,
SJ
Mine is indeed a LHD.. So will check behind my glovebox... Do you think I have to take the glovebox apart?
Thanks again!!
Old 18th May 2007, 06:59   #18 (permalink)
SJ, very nice job! I have put a couple of hi-res versions of his photos here:
www.civinfo.com/forum/dismantled.php
Old 30th May 2007, 14:49   #19 (permalink)
How many cost this amp? Could you give me a model description to search it in spain?
Best regards
ayasystems is offline   Reply With Quote
Old 31st May 2007, 10:18   #20 (permalink)
Sony Amp 4 channel ('Stream'-design XM-SD14X) sells at about £130, Pioneer active sub (TS-WX11A) sells at about £200. I rate these componenets very highly in terms of price v. performance especially the Pioneer box in this install as space was at a premium.
SJ
LinkBack to this Thread: http://www.civinfo.com/forum/how/5606-how-install-entire-ice-system.html
www.clubhondacivic.com :: Ver tema - como montar subwoofer debajo de asientos traseros?? This thread Refback 7th March 2008 16:48
www.clubhondacivic.com :: Ver tema - seal "remote"radio de serie ACTUALIZADO 19-2-08 This thread Refback 19th February 2008 09:51
Similar Threads for: How to install an entire ICE system
[HOW-TO] Install fog lights civicsport How To 44 5th May 2008 11:51
[HOW TO] Install a subwoofer and amp Deemon How To 28 12th December 2007 22:40
Phone Sony HCB-700 HFT install gizmotron Electronics 3 26th October 2007 17:26
Phone Sat Nav & Phone install spile Electronics 0 29th March 2007 18:29
My install my new ICE - install VaTaR Ipods, MP3 Players and ICE 9 6th January 2007 08:16
