This thread is about: [HOW TO] Manually switch on the Reversing Camera, it's in How To at the Honda Civic forum Civinfo; This ‘How To’ will allow you to manually switch on your reversing camera (If fitted) without the need for engaging reverse. When the switch is ...
Old 5th June 2007, 19:11   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Bog
Bog's Avatar
When the switch is pressed, the Navigation System is fooled into thinking the car is in reverse gear and switches on the rear view camera. The circuit also prevents the reversing lights from coming on.
Whilst this is an easy modification, you will need some basic soldering skills and be prepared to take most of the dashboard apart to gain access to the rear of the Navigation unit.
Have fun.....
HOW TO - Manual Reverse Cam Switch.pdf
Thanks to Bog from:
Old 5th June 2007, 20:23   #2 (permalink)
PTR
PTR's Avatar
WOW amazing doc!!! excellent job!!!
Old 5th June 2007, 20:50   #3 (permalink)
sco77harris's Avatar
wahwahweewah when i get the camera i will do this
Old 5th June 2007, 22:14   #4 (permalink)
stew's Avatar
Bog,
Can you explain where abouts the factory fitted nav unit is. Is it in the glove box? How do you get access to replace the DVD?
I ask because I am looking for somewhere to mount my kenwood unit.
stew is offline   Reply With Quote
Old 5th June 2007, 22:49   #5 (permalink)
Bog
Bog's Avatar
Yes, it's accessed via the glove box. If you look at the second drawing in my PDF you can make out where the front of the Navi unit would be (Single DIN, just below the upper mouting screws.)
Old 5th June 2007, 22:53   #6 (permalink)
Nice work Bog, when I get my camera fitted I'll give it a go
Old 6th June 2007, 14:27   #7 (permalink)
mmw109's Avatar
I see you're fooling the Sat-Nav into thinking you're in reverse.
Has anyone tried this on an I-Shift ? Is there any risk the car might do something else as if it's in reverse ?
My old punto once developed a problem where it thought it was in reverse (on the motorway no less) and would start doing it's reverse 'beeping' and flashing up "R" on the dashboard. I wouldn't want a repeat of this.
mmw109 is offline   Reply With Quote
Old 6th June 2007, 15:51   #8 (permalink)
Bog
Bog's Avatar
I doubt it as the reversing lights circuit is isolated by the switch to ensure the reversing lights don't come on! The Nav unit only uses the feed to switch over the video source.
Old 13th June 2007, 15:01   #9 (permalink)
Have fun.....
Attachment 4101
Thank you from spain my friend. I'll do it!
ayasystems is offline   Reply With Quote
Old 16th June 2007, 19:04   #10 (permalink)
Stef's Avatar
For your help, here is a how to remove the lower part of the dash.
Keep up the good work.
Old 10th August 2007, 11:26   #11 (permalink)
Stef's Avatar
BEWARE
Engaging the camera using this mod will completely fool the GPS system.
If you drive < 50km/h the GPS system will think that you are driving in the oposite direction! I noticed it can take minutes before the GPS/map is correct again.
Old 6th September 2007, 19:12   #12 (permalink)
Hi, i'm new here and i'm gonna try install an audio-video system and, of course, i'm interested in this mod.
Since i don't like cutting original cables and connectors, does anyone know number of the connector that should be cutted?
yurassik is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/6112-how-manually-switch-reversing-camera.html
Forum Honda Civic ab 2006 (FK, FN, FD) &bull; Thema anzeigen - Rückfahrkamera This thread Refback 29th April 2008 18:23
Similar Threads for: [HOW TO] Manually switch on the Reversing Camera
Parking Reversing Camera Sandozer Electronics 7 16th March 2008 11:29
Video Reversing camera - photos Pottsy Electronics 42 8th September 2007 23:05
Parking Reversing camera giggy Electronics 7 31st August 2007 23:57
Video Reversing camera Challenge Maldax Electronics 3 9th April 2007 01:01
Reverse Reversing lights civvie06 Lights 22 10th September 2006 23:31
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
