| This thread is about: A solution to connect DVD-Players and Game consoles to the Navigation Screen, it's in How To at the Honda Civic forum Civinfo; Originally Posted by pcr Can anyone save me from getting a headache and help me understand the following ?. Prior to selecting a rearview camera, ... | ||
LinkBack (11) | Thread Tools | Display Modes |
#41 (permalink) | |
Interesting that the NTSC works, I assumed it would not work! I think the only way of controling the brightness would be via the source. I'm someone will correct me if I'm wrong, but I think the display's resolution is 300 lines (whick is the same a the majority of the cheap cams on ebay) Last edited by Bog; 24th July 2007 at 22:41. |
#42 (permalink) |
Bog,
Thanks for the reply, here's an update. Today I used a DVD player as source and was surprised by the results. Using PAL, again the bottom say 15% of the picture is not displayed. Using NTSC, the picture was perfect. I think the previous attempt at NTSC which gave a reduced size picture was due to the way the computer output the picture. I am tempted to conclude that the satnav can handle both PAL and NTSC, but NTSC is the better. It only displays 480 lines (NTSC standard), and not the 576 required by PAL. I am ordering a Pioneer ND-BC2 camera, which is NTSC. |
#44 (permalink) |
got this working on mine today, thanks bog for the how to on not having to use reverse to get the video on the screen.
working on the sound input when get my ipod kit, then it will be the best thing to add to any civic with satnav. its so easy to do as well and cheap to sort out, why didnt honda do this? will post some pics when ive sorted it all. |
#45 (permalink) |
I've been playing today too! NTSC fits the screen perfectly.
I was also thinking of a way to power an AV source or reversing cam, so that it cam on when the switch is operated. The attached circuit is how I've done it (sorry about the bad drawing, but it is nearly midnight!) 001.jpg I have tried it and it works. It will allow me to switch on the reversing cam independently of the reversing lights. I also plan to incorporate a video switch to allow me to swap sources. Hope this helps. |
#46 (permalink) | |
sorry for my english, I'm form spain best regard guys Last edited by ayasystems; 31st July 2007 at 10:44. |
#49 (permalink) |
done my video mod today, and it is fantasic & full stereo sound. here are some pics:-
1) back of satnav unit, white plug in the green socket is for the video input, nice & easy. 2) back of glove box with the rca/phono connectors for video,sound & 3.5mm jack for mp3 as well. 3 & 4) inside of the glove box with the connectors. job done |
#51 (permalink) |
For the sound are you connecting to a connects 2 box and then to the Aux port?? Also how are you switching between the video source and the SatNav?? Do you have a control box... You have made a pukka job of the works, Are you using NTSC?? This is what the camera throws out to the screen, have checked with Alpine... Thats y PAL isnt to be used!!! |
#52 (permalink) |
hi, for the sound im using this:-
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=005 for the video i followed the link to the usa forum where some one had connected the video to the satnav box using a plug, which i went for as no soldering to the nav box. have a good read through the thread like i need and you will get all the info you need now ive done the job and add the pics of where ive put the inputs needed. no control box is needed, just a switch and 1 diode, i used 2 diodes but you can get away with one. the hardest part is stripping everything down and putting it back. im now glad i went for the EX as ive now got what i wanted from day one. |
#55 (permalink) |
hi, follow the link to where i got it from ebay. it can display track info but only for sat radio version hu, but we do not get these in europe.
i think it could be done at some stage, but im happy with what ive now got, the sound quality is amazing. |
#56 (permalink) |
I am planning to make a small cricuit to display the rear cam while driving FW. (using the rear defroster pushbutton).
My only concern is that when the car is moving forward and you "fool" the unit that it is in reverse, the NAVIGATION system is using this info also to detect if the car is moving backwards (to correct the car position). Anyone had problems with camera ON while using NAVIGATION.? |
#59 (permalink) |
i dont think you will use the camera that much when driving forwards, its very distracting and it will do your head in. (had this on another car)
im more than happy that it switches automaticly when i select reverse. i can now back up close to walls,other cars etc but i still use my mirrors and pdc as before. the camera is a nice touch. |
#60 (permalink) |
BEWARE
Engaging the camera using this mod will completely fool If you drive < 50km/h the GPS system will think that you are driving in the oposite direction! I noticed it can take minutes before the GPS/map is correct again. You can test this easily: 1- Remove the backup bulbs 2- Connect (if you want using a switch) the back up bulb socket brown wire to the +12V (sigaret lighter..) and the camera will turn on during driving. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/6117-solution-connect-dvd-players-game-consoles-navigation-screen.html
| Forums CivicYume • Afficher le sujet - Mettre un Poste Autoradio dans l'ORNI | This thread | Refback | 27th November 2008 23:59 | |
| Forums CivicYume • Afficher le sujet - [HOW TO] DVD, Consoles et autres sur écran de navigation | This thread | Refback | 13th June 2008 23:41 | |
| le systeme navi - Honda FORUM Honda - FORUM Auto par marques | This thread | Refback | 18th April 2008 18:20 | |
| FN2 Satnav & Stereo questions - Type R Owners Forums | This thread | Refback | 31st January 2008 00:39 | |
| Navigatore - Elettronica | This thread | Refback | 28th November 2007 12:44 | |
| www.clubhondacivic.com :: Ver tema - Brico Entrada de video AUXILIAR para navegador | ||||
