#21 (permalink) |
I had drop links replaced less than a year ago because of the noises. problem solved,
but had to change them again last week because the seals were damaged,so i bought 2 new ones from ebay, £25 for both replaced them myself easy job to do. but i noticed that they were about 1" shorter than the ones that a local garage replaced last year so i don't know which ones are the correct size. Drivers side noise is still there. so annoying. |
#22 (permalink) |
The flying Dutchman
![]() Car: 2007 2.2 I-CTDI Sport
Thanks given: 54
great guide, replaced one today, the nuts came of pretty easy, but i sprayed them every day since last saturday.
no more knocking sound for me!!! massive thanks for the guide, saved me 100 euro's! |
#26 (permalink) |
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 831
Stopped my suspension knocking when I did mine.
If you get both sides of the car jacked up on axle stands you'll have no trouble with alignment etc. |
#29 (permalink) |
![]() Car: 2007 2.2es.5 door Red
Thanks given: 41
Cheers, jobs done following your how to (pretty much the same) the old ones were totally shot, about 3mm play in the top ball joint on the passenger side, replacement links fitted and now it feels like a new car.......I might do the ones on my civic next......thanks for the how to
Cheers, Gary |
#31 (permalink) |
![]() Car: 2006 1.8 Sport Ishift Milano
Thanks given: 128
Thanks for this how to. Just changed my drop links today. I jacked up the entire front end and took both wheels off which took the load off the anti roll bar which meant I didn't need to lower the car down onto a hub support. I had to cut two of the nuts off as they were completely stuck. The car feels completely different now, much sharper handling.
#32 (permalink) |
![]() Join Date: 1st October 2012
Thanks for this - awesome write-up. Will be needing this shortly! Quick query though - is it an urgent (or dangerous) issue if these are knocking? mine started about 2 weeks ago and it's getting worse. I've got time off work in a fortnight but do about 300 miles a week. That safe?
#33 (permalink) |
Clingfilmed
Thanks given: 831
It's not dangerous up to a limit, obviously you don't want the ARB detaching but a small amount of play is acceptable. Mine were knocking from November 2011 to Feb 2012 as I was waiting for the weather to improve before changing them.
LinkBack to this Thread: http://www.civinfo.com/forum/how/61650-how-change-drop-links-easy-way.html
| encore les amortisseurs... qui claquent - Honda FORUM Honda - FORUM Auto par marques | This thread | Refback | 20th November 2011 11:34 | |
| Claquements dans le train avant - Honda Civic - FORUM Honda - FORUM Auto par marques | This thread | Refback | 25th October 2011 07:38 | |
Similar Threads for: How to: Change drop links the easy way
| Suspension Front Drop Links | kissifer1972 | Wheels, Tyres, Suspension and Brakes | 11 | 10th November 2012 00:34 |
| Suspension Drop Links | crowmar kirkliss | Wheels, Tyres, Suspension and Brakes | 1 | 13th August 2011 09:33 |
| Suspension Front Drop links replacement. | Wilfko | Wheels, Tyres, Suspension and Brakes | 6 | 24th January 2011 19:36 |
| Suspension Drop Links | dave7891 | Wheels, Tyres, Suspension and Brakes | 7 | 2nd July 2010 14:03 |
| Suspension Anti Roll bar drop links | coolmail1uk | Wheels, Tyres, Suspension and Brakes | 0 | 24th May 2010 13:38 |
