Old 3rd November 2011, 00:03   #1 (permalink)
OOOOSH
smig's Avatar
Car: 2007 Type R GT - NHB
Thanks given: 80
How to fit an aftermarked reversing camera to an aftermarked head unit
I know a few of these exist, but not specifically for fitting an aftermarked reversing camera to an aftermarket head unit, so heres what I did:-
This was done on my 57 plate Civic Type R, the head unit is a Pioneer AVIC-F930BT.
I bought the full double din conversion kit from Impulse car audio http://www.impulsecar.co.uk/product_details.php?productid=MjE=
Bob from Impulse gave me the following tips:
Fitting the 103mm cage kit
1. Cut out the little piece of plastic on the corner of the dash where the original radio housing fitted. This will then allow the new fascia to fit.
2. Place cage in fascia and check if the trim ring will fit through the four corners. Cut the plastic if necessary (see image) then bend tabs to hold the cage in place
3. Screw side plates to head unit using hole number 2 marked on the plate (top and bottom) with the copper coloured piece located into slots 17 and 19 beneath the plate.
4. Check that the head unit locks into the cage at the correct depth.
The pic below shows how the chassis connection plates are attached to the double din head unit.
Once the standard head unit has been removed (see the excellent attachment in Bog`s thread) http://www.civinfo.com/forum/how/51366-how-install-aftermarket-reversing-camera-easy-way.html, the bottom left corner of the dash needs cutting out square, in order for the double din chassis to fit, as per pic below.
Connect the replacement double din wiring loom (instructions are provided from Impulse). If a reversing camera is to be fitted (I bought the YW cam from MrBozo) http://www.civinfo.com/forum/civinfo-traders/51600-sale-reverse-cameras.html
then connect the yellow AV cable which comes with the cam, to the brown 'rear view camera in' connector.
The yellow AV cable will be run to the reversing light.
A wire also needs to be connected to the 'reverse gear signal input' which will be run to the reversing light.
With the knee panel removed, run both cables behind the dash, and behind the back of the boot release plastic.
Then pull to remove the plastic trim adjacent to the kick plate garnish, and run both the cables along the edge of the carpet.
Lift the rear seat cushion up and pull to remove the plastic inspection panel by the seatbelt. Run the cables into this space.
Remove the rear arm rest to expose the rear speaker as shown in Munro`s thread http://www.civinfo.com/forum/how/9294-rear-speakers-replacement-coaxials-3-door.html
, pull the cables through here.
Now pull the panel away from the body, and run the cables through here.
Now drop the rear seat forward, and pull the rear panel away from the body, feed the cables through this space towards the rubber grommet at the top of the boot.
Pull to remove the grommet, and feed the cables through the hole.
I had to cut the yellow AV cable approx 12" from the end, as its head is too large to get through the grommet and cavity, this will be re-attached later. I pushed a metal bar through the grommet, taped the cables to the bar, and pulled the lot through the grommet.
In order to route the cables through the side cavity of the boot, I pushed a length of TV co-axial cable through, taped the cables to it, and pulled it back through
The red power cable from the reversing camera, and the cable which is connected to the 'reverse gear signal input' were terminated in a pin connector as per pic below (note: the black ground cable from the reversing camera is not used at all).
I then inserted the pin connector into the back of the reversing bulb plug, into the brown coloured wire. The end of the previously cut yellow AV cable will now need to be re attached (by soldering or chocky block connector etc).
The reversing camera is screwed in position adjacent the rear number plate light.
The reversing light assembly is removed by unbolting the 3 nuts behind the bulb inspection panel in the boot, the reversing camera cables are then fed behind the centre panel into this hole.
A cable sized notch needs cutting into the removed light cluster, in order for it to sit flush when re-fitted.
The reversing camera cables are fed into the boot, and the light cluster re-attached, ensuring the cables go into the notch.
Join the colour coded connectors together, tidy the cables up, and re-fit any panels etc and admire your handy work.
smig is offline   Reply With Quote
Thank You to smig from 6 Users:
Old 4th November 2011, 11:32   #2 (permalink)
Car: 2006 2.2 ex red
Thanks given: 1
Hi, just wanted to know which camera you used? And how you mounted it? Thanks
fireimy is offline   Reply With Quote
Old 4th November 2011, 11:37   #3 (permalink)
OOOOSH
smig's Avatar
Thanks given: 80
Forum member MrBozo sells various styles of reversing camera, I chose YW style (check out the 'traders' forum). It was simply screwed to the underside of the panel using the supplied screws.
Thanks to smig from:
Old 4th November 2011, 11:42   #4 (permalink)
murray's Avatar
Car: CW Civic FD2
Thanks given: 155
Great job mate.
murray is offline   Reply With Quote
Old 4th November 2011, 16:01   #5 (permalink)
Bog
Bog's Avatar
Car: 2012 Silver 1.8 EX-GT
Thanks given: 119
Nice write up
Old 8th December 2011, 21:40   #6 (permalink)
Foldy Mirror Mods,Cameras
MrBozo's Avatar
Car: 2007 2.2 EX, NHB
Thanks given: 562
Originally Posted by Bog View Post
Nice write up
Spot on....great detail.
MrBozo is online now   Reply With Quote
Old 22nd January 2012, 20:39   #7 (permalink)
packard bell's Avatar
Car: 2012 type S Sliver
Thanks given: 19
Good job mate.
packard bell is offline   Reply With Quote
Old 9th February 2012, 18:14   #8 (permalink)
phil739's Avatar
Thanks given: 7
am rubbish at stuff like this , how much you charge for fitting ...lol
phil739 is online now   Reply With Quote
Old 9th February 2012, 20:19   #9 (permalink)
OOOOSH
smig's Avatar
Thanks given: 80
It really isn't that difficult, but it is quite time consuming. It's probably best to have a go when there's more light and warmer than it is at the moment though lol
Old 12th April 2012, 15:56   #10 (permalink)
rockyridge04's Avatar
Car: 2010 Civic Type S Black
does the camera supply the reversing grid or is it the head unit??? my Pioneer AVH-2400BT doesnt show one and why did you only connect the Red wire does it not need a negative ????
rockyridge04 is offline   Reply With Quote
Old 26th August 2012, 19:07   #11 (permalink)
Red Dwarf's Avatar
Car: 2011 1.8 Si-T, Milano Red
Thanks given: 1
Have you had any problems with it since fitting?/
Mine a factory fit system. Blew clock/ac display up. Honda replaced and it blew up again. Called Honda headquarters to find out known problem thats now factory cured with a 'can'? that sits between satnav and clock.
Can you make voice controlled calls with yours or have you to use the touch screen to dial out. Advertised as a HFT system but not to mke if reaching across to touch screen to dial.
It is a nice system but software to download POI's mainly for europe. All the POI's I had in my tomtom lost as cant transfer.
Red Dwarf is offline   Reply With Quote
Old 26th August 2012, 20:08   #12 (permalink)
ElNino9's Avatar
Car: Civic type s 2009
Thanks given: 237
Brilliant how to, will be using this next week for my install
ElNino9 is offline   Reply With Quote
Thanks to ElNino9 from:
Old 26th August 2012, 21:33   #13 (permalink)
OOOOSH
smig's Avatar
Thanks given: 80
Never had any problems with the clock.
Didn't know you you could make calls without touch screen (never read the manual lol).
The only POI's I used are the UK speed cameras.
Old 26th August 2012, 21:34   #14 (permalink)
OOOOSH
smig's Avatar
Thanks given: 80
Old 16th December 2012, 10:40   #15 (permalink)
Thanks given: 3
very impressive mate.
riccom is offline   Reply With Quote
Old 16th December 2012, 10:55   #16 (permalink)
Thanks given: 34
I found an alternative route for the revearse camera cable that takes 2 minutes to fit front to back ...
The cable wil tuck in behind the airbag /roof lining along the top of the door rubbers and exit exactly where you want it at the boot rubber ..
npg1 is offline   Reply With Quote
Thanks to npg1 from:
Old 16th December 2012, 11:36   #17 (permalink)
devil84's Avatar
Car: Milano Red FN2 GT
Thanks given: 161
Pics
devil84 is offline   Reply With Quote
Old 16th December 2012, 12:21   #18 (permalink)
Thanks given: 34
Originally Posted by devil84 View Post
Pics
camera flat battery, but if you look where the headlining joins to the side and slip your finger in you ll see exactly how its done !!
LinkBack to this Thread: http://www.civinfo.com/forum/how/65100-how-fit-aftermarked-reversing-camera-aftermarked-head-unit.html
Civic Type-R Owners Club & Forum • View topic - About to get an FN2, here are my plans. This thread Refback 19th October 2012 19:57
Similar Threads for: How to fit an aftermarked reversing camera to an aftermarked head unit
Parking Reversing Camera Sandozer Electronics 10 1st February 2011 18:37
Reversing Camera for 09 EX-GT Bog Gordons Honda 1 23rd November 2010 23:36
Add-on nav Reversing Camera curlyearly Electronics 4 23rd November 2008 21:14
Electrics Reversing Camera Kit allan40alt Electronics 3 9th May 2008 10:02
Parking Reversing camera Giggy Electronics 7 31st August 2007 23:57
