Old 12th February 2012, 15:20   #161 (permalink)
Bog
Bog's Avatar
Car: 2012 Silver 1.8 EX-GT
Thanks given: 119
I think just random... have you stalled it recently or had a flat battery?
Old 12th February 2012, 23:07   #162 (permalink)
Most Active Australian
Grayfox's Avatar
Car: 2010 Black Civic Si FK2
Thanks given: 67
Eco display Eco display
Stalled.
Lifted the clutch when in 1st at the lights with no throttle when my foot started to get cramps.
LOL
Grayfox is online now   Reply With Quote
Old 22nd February 2012, 16:02   #163 (permalink)
sirkuk's Avatar
Car: 2006 2.2 Civic Sport
Thanks given: 24
Well that was the most useful Quality Street wrapper ever
B1235 and B1240 and as I have no problems with the HVAC, I'm happy.
sirkuk is offline   Reply With Quote
Old 4th March 2012, 12:44   #164 (permalink)
I get a couple of codes that a lot of others have reported
B1241
B1235
Both relate to blower and associated valve.
Thing is i do have an intermittent issue that i reported on another thread. Sometimes (when driving in rain!) I lose control over air and cannot force it to demist etc. Blower still going but nothing coming out....
So... if lots of others report the same issue does anyone have an idea on a fix? My car is now well out of warranty......
Cheers
proto is offline   Reply With Quote
Old 20th August 2012, 21:15   #165 (permalink)
Hi guys I could really do with some help my car is a civic 2.2 icdti sport on a 56 plate i've had the engine warning light come on and off for about 4 months. This problem has now escalated to the point where the car wont start and it puts check system,check engine, air bag warning in orange and vsa , also the red air bag warning light in the top right goes out then comes back on and stays on. I've had the car into an auto electrician for two weeks he's on good terms with Honda here in Aberdeen and they have told him different places to look for faults. He knows there is a fault their but he cant find it he told me it has the potential to cost between 2 an 3 grand to fix !!!!! I have replaced the srs ecu under the gear leaver and it's still the same wont start!. I have just donr the tin foil trick and it came back with these fault codes.
pa50 dtc b1168 (this one wont clear)
pa51 dtc b1231
pa51 dtc b2932( cant seem to find this one?)
Any help would be gratefully received thanks in advance Keith.
gadget555 is offline   Reply With Quote
Old 20th August 2012, 21:36   #166 (permalink)
DUNCAN's Avatar
Thanks given: 31
pa51 dtc b1231
Just bump start it and get a new battery
Old 20th August 2012, 22:03   #167 (permalink)
the battery is fine turns engine over ok. I've had it drop tested in work all is ok
Old 21st August 2012, 20:52   #168 (permalink)
DUNCAN's Avatar
Thanks given: 31
ecu
Old 21st August 2012, 22:08   #169 (permalink)
Which ecu Duncan ? Thanks any way.
Old 23rd August 2012, 00:16   #170 (permalink)
chrishughes's Avatar
Thanks given: 4
Ive not carried out this tin foil test yet, but i have ran seft diagnosis test on dash and ERROR 2 came up. After seeing this ive also realised that the warning didnt come up on dash that my brake light bulb was out or that my tyre pressures were low.
Could this be related?
Also whats the problem and how do I fix it?
chrishughes is offline   Reply With Quote
Old 24th August 2012, 07:05   #171 (permalink)
Any help on this would be nice as it seams tobe a common fault to the 2.2 . Just need to get it to start then in can get it sorted on a back road near to me !
Old 12th December 2012, 21:25   #172 (permalink)
will it work on Civic LX 2012?
fokus is offline   Reply With Quote
Old 13th March 2013, 12:27   #173 (permalink)
Car: 2007 CTR GT, 3 Door in RED
DTC code
DTC B1227 can any one help on this one please.
I have searched for the others listed below, Just the top one that I need help on.
1241
1240
2991
cheers
HCTRFN2 is offline   Reply With Quote
Old 13th March 2013, 12:32   #174 (permalink)
Goat Fancier
Jon_G's Avatar
Car: 2005 Accord iCTDi Tourer
Thanks given: 59
outside air temperature sensor circuit open circuit... OBD II Fault Codes b1227
Jon_G is online now   Reply With Quote
Old 15th March 2013, 22:19   #175 (permalink)
Re: Read (and clear) diagnostic error codes with no special tools
Many thanks new temp sensor ordered.
Old 27th March 2013, 18:37   #176 (permalink)
Serge's Avatar
Gents,
I have the error codes PA51 DTC B2991 and PA96 DTC B1905. Anything to be concerned about?
TIA
Serge is offline   Reply With Quote
Old 3rd April 2013, 17:25   #177 (permalink)
I'm getting pa10 DTC B1008??
Pmartin is offline   Reply With Quote
Old 3rd April 2013, 18:10   #178 (permalink)
Goat Fancier
Jon_G's Avatar
Thanks given: 59
MICU lost communication with Gauge control module (A/T message)... OBD II Fault Codes b1008
Welcome to Civinfo, btw!
Old 6th April 2013, 09:48   #179 (permalink)
Hi all - would be grateful for some help.
Engine warning light came on this morning just as I was returning from a fairly short trip so I followed Pottsy's tin foil workaround and got the code PA51 B1227 - this was flashing and pressing (i) on the steering wheel did nothing.
I've quickly searched this thread and can't see that particular code mentioned - does anyone have the decode?
EDIT : just searched the thread again for B1227 (rather than just 1227) and found that it's to do with the outside air temperature gauge. This appeared to be reading normally - it said 1 degree and there was frost on the car so it couldn't have been far out!
Anyway, the warning light is still coming on when I go to start the car up so unfortunately it doesn't look like an intermittent - do I need to get another sensor (I had it changed about 2 years ago) or is there a less expensive solution?
Thanks in advance.
EmmGee is offline   Reply With Quote
Old 16th April 2013, 18:52   #180 (permalink)
jordm's Avatar
Car: 55 1.8i EX galaxy grey
Thanks given: 3
Hi people I have a few error codes as well, any help would be appreciated;
PA51
DTC B1241,
PA51
DTC B1238,
PA51
DTC B2991
jordm is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/7044-read-clear-diagnostic-error-codes-no-special-tools.html
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) - Thema anzeigen - Software Updaten This thread Refback 9th January 2013 06:49
Kody DTC This thread Refback 13th December 2012 18:16
UFO - problem Check Engien przy wysokim krceniu - Strona 2 This thread Refback 12th December 2012 17:56
UFO - problem - Strona 2 This thread Refback 10th December 2012 11:14
Wentylator.... - Strona 2 This thread Refback 14th July 2012 12:18
5earch This thread Refback 2nd July 2012 20:39
check engine () - 4 - Honda Civic Club This thread Refback 4th May 2012 14:55
Honda club Serbia forum This thread Refback 8th April 2012 08:35
HONDA TYPE-R Club Benelux • Toon onderwerp - Aanpassingen FN2 This thread Refback 10th February 2012 13:44
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 3rd December 2011 14:07
How do I get the error codes from a 2010 Honda Civic without using special tools? (Engine Indicator Lights Honda Civic) This thread Refback 15th September 2011 16:12
How do I get the error codes from a 2010 Honda Civic without using special tools? (Engine Indicator Lights) This thread Refback 25th August 2011 02:42
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 18th June 2011 19:58
Honda Civic 2006 - 8ª geração - Página 303 This thread Refback 16th May 2011 07:10
- 3 - Honda Accord - This thread Refback 6th April 2011 08:19
- Honda Civic Club This thread Refback 16th March 2011 11:22
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 11th March 2011 15:02
Honda Civic 2006 - 8ª geração - Página 303 - FÓRUM AUTOHOJE ONLINE This thread Refback 7th March 2011 01:12
. - Honda Civic Club This thread Refback 21st November 2010 21:29
Wentylator.... This thread Refback 9th November 2010 12:39
check system! This thread Refback 3rd November 2010 16:00
Kontrolka Check Engine This thread Refback 14th August 2010 19:28
Äèàãíîñòèêà îøèáîê ñâîèìè ðóêàìè. - Honda Civic Club This thread Refback 25th May 2010 13:46
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 22nd April 2010 21:31
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 13th April 2010 00:43
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 4th April 2010 19:04
Diagnostic Trouble Code This thread Refback 14th March 2010 21:52
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 3rd February 2010 00:22
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 29th January 2010 09:51
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 21st January 2010 11:15
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 22nd December 2009 15:51
www.clubhondacivic.com - Ver Tema - Leer y borrar errores de diagnosticos sin cable This thread Refback 11th December 2009 23:18
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 3rd November 2009 22:13
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 3rd November 2009 09:17
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 20th October 2009 09:02
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 30th September 2009 17:46
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 30th August 2009 21:55
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 1st August 2009 19:30
FN2R - ECU jumper connection - HondaTech Australia Forums This thread Refback 6th July 2009 06:01
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 12th June 2009 06:19
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Fehlermeldung This thread Refback 11th June 2009 06:04
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 26th May 2009 11:50
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 28th February 2009 10:57
Diagnostic Trouble Code - HONDA CIVIC TEAM This thread Refback 8th February 2009 14:40
Äèàãíîñòèêà îøèáîê ñâîèìè ðóêàìè. - Honda Civic Club This thread Refback 24th January 2009 21:37
www.clubhondacivic.com :: Ver tema - Leer y borrar errores de diagnosticos sin cable This thread Refback 15th January 2009 17:40
Ðåæèì äèàãíîñòèêè - Honda Civic Club This thread Refback 6th January 2009 23:58
Civic-FX.net - Forum Honda Civic ab 2006 (FK, FN, FD) • Thema anzeigen - Software Updaten This thread Refback 11th July 2008 09:27
vtec isn't kicking in This thread Refback 23rd June 2008 16:07
Äèàãíîñòèêà îøèáîê ñâîèìè ðóêàìè. This thread Refback 13th December 2007 20:47
How to see diagnostic codes with no special tool! - Elettronica This thread Refback 26th November 2007 22:23
HONDA TYPE-R Club Benelux :: Aanpassingen FN2 This thread Refback 17th October 2007 22:41
Similar Threads for: Read (and clear) diagnostic error codes with no special tools
Honda colour codes Uffe General Discussion 11 7th November 2011 17:18
Satnav Sat Nav read error sotware not CD help required rugbywear Electronics 6 25th February 2007 20:43
Satnav Sat Nav read error sotware not CD help required rugbywear Electronics 2 21st February 2007 18:16
Satnav Clear SatNav Knat Electronics 3 12th January 2007 20:02
car codes SUPERTEACH General Discussion 25 7th September 2006 09:44
