Old 25th March 2012, 19:31   #1 (permalink)
Reasonable Tenor voice
shinybadrobot's Avatar
Car: 2009 type s 1800 i-vtec
Thanks given: 4
Fitting space saver.
Several members have posted questions about fitting a space saver. I fitted one last week, so here is a simple guide...
If you buy space saver with the fitting kit, you get a long threaded bold with a wing nut type top, and metal cap and 3 large blocks of foam rubber about 3 inches along each side, one slimmer than the other 2. These stick onto the floor with the slimmer block closest to the rear of the car, for the wheel to rest onto.
Next feel with your fingers for a slight bump on the floor near where the centre of the wheel will be; where the fixing bolt will screw into. Cut the carpet at this spot. Underneath you should find a black plastic blanking cover (about the size of a 2p piece, slotted for a plain screw driver) that screws out revealing a threaded hole for the bolt. With the wheel resting (front down) on the foam blocks the wheel should be able to be screwed down nice and tight. Looking at the picture you can make out the marks my wheel made on them, so should give you an idea of their position
included are a big plastic bag to hold the regular wheel in and a cargo net to hold it all on place as you drive to quick fit (or where ever) You can see the bolt and cap in the attached JPG. I assume that if you don't have one, (you only have the wheel, without the rest of the kit) a visit to a hard wear store should allow you to source a suitable replacement. The foam blocks are crushable to make sure the wheel fit is snug.
shinybadrobot is offline   Reply With Quote
Thank You to shinybadrobot from 4 Users:
Old 25th March 2012, 19:53   #2 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 831
Interesting - I got the foam blocks and the fixing bolt but no wheel when I bought the car!
Old 26th March 2012, 06:22   #3 (permalink)
Car: MY13 1.8 EX Auto
Thanks given: 183
Eco display Eco display
Which presumably means the previous owner took just the wheel out and sold it
Old 26th March 2012, 09:52   #4 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 831
Bought it from a Honda dealer so my guess was either the same as yours or Honda took it out to put in another car.
Old 26th March 2012, 13:29   #5 (permalink)
Thanks given: 183
Strange.
When I got my second Civic it was easy to remove the foam pads and refit in the new one. Just got some new double sided sticky tape.
I did take measurements so I put the pads in the same place but I didn't keep them.
Old 28th March 2012, 20:14   #6 (permalink)
BDJW's Avatar
Car: 2008 CTR, Silver
Thanks given: 74
Does the space saver move around much if it's screwed down and on the form pads?
BDJW is offline   Reply With Quote
Old 28th March 2012, 20:34   #7 (permalink)
Thanks given: 4
Not at all, It is as tight as a tight thing. The foam blocks help by compressing, and pushing up. I guess that is what they are for.
Old 28th March 2012, 20:37   #8 (permalink)
BDJW's Avatar
Thanks given: 74
Sorry, I should have read my last post properly before I hit submit
I meant, does it move around much if it's not screwed down!?
Old 29th March 2012, 06:18   #9 (permalink)
Thanks given: 183
Citroen decided to just put the spare in a boot well on the C5 and it used to bounce around quite noticeably. I ended up wrapping the whole thing in a blanket to muffle it.
Old 29th March 2012, 08:59   #10 (permalink)
Thanks given: 4
Yes it does slide about a bit, from side to side. Also if you want to get paranoid in the event of a really bad accident it could fly out and cause injury, if not secured
Old 1st April 2012, 18:11   #11 (permalink)
grzes8203's Avatar
Car: 2008 2.2 EX Milano Red
Is it 15" or 16" spare wheel?
grzes8203 is offline   Reply With Quote
Old 1st April 2012, 18:16   #12 (permalink)
Car: Crystal Black CTR GT(59)
Thanks given: 2
You interested in selling them? Thanks
englishrick is offline   Reply With Quote
Old 1st April 2012, 18:23   #13 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 831
Sorry mate - still on the lookout for a spare wheel to go in there!
Old 1st April 2012, 21:38   #14 (permalink)
Hullcivic1986's Avatar
Car: 2007 1.8 5 door
Thanks given: 61
I just bought a second hand spacesaver with the long wing nut retaining bolt. No foam blocks or anything and its fixed down secure, not moving or bouncing around or anything so if anyone gets one dont think they are necessary.
Hullcivic1986 is offline   Reply With Quote
Old 1st April 2012, 21:59   #15 (permalink)
Thanks given: 2
I have one of these Integra Type R DC5 Space Saver Spare Wheel | eBay wheels as a spare, just need the fixing
Old 4th June 2012, 21:08   #16 (permalink)
Getting better
civicnewbie's Avatar
Car: 09 2.2 CTS GT Crystal Black
Thanks given: 126
Do you happen to know what the thread is and the length, I have the wheel but no fixing kit, can,the fixing kit be bought on its own?
civicnewbie is offline   Reply With Quote
Old 8th June 2012, 16:53   #17 (permalink)
Car: 2009 Civic 5 door 1.8 Exec.
Thanks given: 1
Space-saver installed
I did it a lot faster, bought a new wheel/tire at Honda, opened up the the boot, lifted up the cover, threw the wheel in and closed it again. Its already there and ready when i need it.
Coordinator is offline   Reply With Quote
Old 8th June 2012, 17:09   #18 (permalink)
Getting better
Thanks given: 126
Love it, that's what I did and there's so much stuff packed around it, tools etc that it does not move
Old 6th October 2012, 18:33   #19 (permalink)
Urban Parkour Monkey
Flipt's Avatar
Car: 2009 CTR GT, Milano Red
Thanks given: 50
Great how to! 2 minute job including placing the foam blocks and cutting a flap in the carpet for the bolt
Flipt is offline   Reply With Quote
Old 29th January 2013, 10:33   #20 (permalink)
Does anyone know an online site that sells the spare and fitting kit where the price is less the £150 I have seen !!!
pacurry is offline   Reply With Quote
Similar Threads for: Fitting space saver.
space saver wheel +fitting kit Jase71 Items for sale 5 22nd November 2010 16:56
Space Saver martin_1.8 Newton Honda London 2 7th July 2009 10:54
Space Saver martin_1.8 General commercial posts 0 19th June 2009 09:04
Space Saver civic58 Items wanted 6 1st January 2009 15:37
