Old 8th April 2012, 20:05   #1 (permalink)
Car: 2007 CTR Alabaster
Thanks given: 571
Front Springs- to Eibachs.
Basically this is the same as Coste1l's guide which i followed to fit Eibachs.
I just took moar pics so each step would be a bit clearer.
I take no responsibility for ANYTHING that occurs as a result of following this guide, that includes but is not limited to- personal injury, damage to property, Alien invasion, Acts of God, Famine, nuclear war, transgenderisation, artificial insemination, erectile dysfunction, nausea, vomiting, cramps, epiphanies, Life changing events, Lycanthropic tendencies, vegetarianism, religion and many other such events.
Firstly loosen wheel nuts
Jack up car
remove wheel
open bonnet and take off the plastic doorway and remove rubber mount.
loosen the three gold nuts on the strut mount.
Loosen but DO NOT undo the centre nut.
using needle nose pliers, remove the abs wire holders.
undo the brake pipe anchor 12m
Undo the two large nuts on the bottom of the strut (breaker bar unless you are Hercules)
jack up the hub and remove the top drop link nut, move this out of the way.
now remove the two large bolts that you took the nuts off a minute ago.
hold the suspension fork and undo the three nuts completely at the top.
Lift this out very carefully
make sure you leave the jack under the hub so it doesnt flop about
Apply spring clamps and remove tension from the spring.
undo the top nut
dissasemble it all and clean it all up
fit a new bump stop into the top mount bearing.
blast the bottom with WD40 this cleans everything.
apply new spring, reverse procedure to refit everything.
basically just do everything in reverse now.
job done.
crowmar kirkliss is offline   Reply With Quote
Thank You to crowmar kirkliss from 4 Users:
Old 8th April 2012, 21:57   #2 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 749
Nice How2
Think I'll need this if/when I replace my shocks
parsco is offline   Reply With Quote
Old 8th April 2012, 22:00   #3 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 159
Good guide pal.
when your in that far it's easy to swap the ARB bushes too, they are attached to small plates under the lower arms, the difference in new and used after 25k is amazing. cheap easy fix too
Stephen
stoney is offline   Reply With Quote
Thanks to stoney from:
Old 8th April 2012, 22:08   #4 (permalink)
Thanks given: 571
Originally Posted by stoney View Post
Good guide pal.
Stephen
From honda? or is there aftermarket? powerflex?
Old 8th April 2012, 22:09   #5 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 159
I got mine from Honda but I think Paul at TDI has uprated ones from somewhere
Old 8th April 2012, 22:11   #6 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 836
Worth replacing the drop links too as you're half undoing them anyway!
Good guide pal.
Syx is online now   Reply With Quote
Thanks to Syx from:
Old 8th April 2012, 22:14   #7 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 159
LMAO, don't mention ARB links to him
Old 10th April 2012, 23:28   #8 (permalink)
Thanks given: 571
All thanks and credit to Coste1l for the original how to.
Thanks to crowmar kirkliss from:
Old 11th April 2012, 00:13   #9 (permalink)
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Thanks given: 257
good pictures and detail there CK, nice one!
just to add also that I found jacking up both sides relieved the tension on the anti roll bar and made the drop links come off much easier.
Laney is offline   Reply With Quote
Thanks to Laney from:
Old 13th April 2012, 14:11   #10 (permalink)
Worlds dirtiest Civic
Ben GT's Avatar
Car: 2.2 Type S GT in NHB
Thanks given: 176
Hi Crowmar,
Can I have a full list of tools required to do it?
Many thanks
Ben GT is offline   Reply With Quote
Old 13th April 2012, 14:28   #11 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 836
You'll need jack, axle stands, wheel locking nut etc.
For the actual suspension change (after the wheels are off):
Rears require a 10mm socket. Very easy.
Fronts require:
14mm socket
10mm socket & ring spanner
12mm elbow spanner & socket
6mm allen key (I think it's 6mm)
Breaker bar
Spring clamps
Mole grips
And in my case, a blowtorch.
I think that covers it.
Definitely do this. I put both fronts on axle stands and had much less bother with the drop links as a result.
Thanks to Syx from:
Old 13th April 2012, 14:38   #12 (permalink)
Ben GT's Avatar
Thanks given: 176
Fronts require:
14mm socket
Breaker bar
Spring clamps
Mole grips
Hopefully it wont come to that!
Old 13th April 2012, 14:41   #13 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 836
For your sake I hope not... but those droplinks just needed that extra encouragement!
Old 13th April 2012, 14:42   #14 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 737
Plastique do?
Relic is online now   Reply With Quote
Old 13th April 2012, 14:44   #15 (permalink)
Its a cake, not a biscuit
Spank My Car's Avatar
Car: '57 CTR GT
Thanks given: 168
Sounded like a DIY job that even I could undertake...until I heard blowtorch!!
Awesome how to though!!
Spank My Car is online now   Reply With Quote
Old 13th April 2012, 14:45   #16 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 836
Originally Posted by Relic View Post
Plastique do?
Didn't come to that but I wasn't far off. ****ing things were a nightmare on the nearside. Offside came off without a problem!
It is straightforward mate, honestly.
Old 13th April 2012, 15:00   #17 (permalink)
無限 Unlimited
Laney's Avatar
Thanks given: 257
Hi Crowmar,
Many thanks
14mm ring spanner for the top three nuts (under bonnet)
18mm ring spanner for the top nut plus a 6mm allen key to stop it spinning
Wheel off.
long nose pliers to pinch the abs clips off
14mm ring spanner plus 5mm allen key for the drop link.
Wire brush to brush off any rust on any threads
WD40 or penetrating oil
12mm spanner to remove the brakeline bracket.
19mm spanner PLUS another 19mm to hold the other side of the bolt in order to remove the two big bolts holding the strut at the bottom.
I don't remember using a 10mm but is always useful to have a selection of spanners anyway.
Old 13th April 2012, 20:20   #18 (permalink)
Ben GT's Avatar
Thanks given: 176
Final question- which spring compressors do people use?
Old 13th April 2012, 20:53   #19 (permalink)
無限 Unlimited
Laney's Avatar
Thanks given: 257
I used the ones in the first photo, that work on a thread but only because they were cheap
If I had access to ones like in the second picture then I'm sure the job would have gone much quicker
Old 15th April 2012, 16:06   #20 (permalink)
Thanks given: 571
Wheel off.
One of those is bigger, i think it is the large nut on the end whih is either a 20mm or a 21mm
Similar Threads for: Front Springs- to Eibachs.
Suspension Eibachs and FRS set up on front only for now stackerman Wheels, Tyres, Suspension and Brakes 9 17th January 2012 22:22
Suspension Eibachs springs fitted alex4dana Wheels, Tyres, Suspension and Brakes 8 17th August 2011 18:25
Eibachs springs for sale jtpt2007 Items for sale 12 10th August 2011 09:11
Type R front/rear springs griffin Items for sale 3 5th May 2011 14:46
Suspension Front springs slowhand Wheels, Tyres, Suspension and Brakes 1 9th September 2007 00:29
