Old 12th May 2012, 12:36   #1 (permalink)
cf136322's Avatar
Car: 58 Black Type R GT
Thanks given: 52
Changing hks filter
Just changed mine it took 5 minutes.
Unscrew last jubilee clip nearest the filter.
Gentlely remove the mushroom housing from the pipe.
Unscrew the hks screw the metal housing will separate from the plastic dome.
Replace filter, then follow the above steps in reverse.
Really easy to do.
cf136322 is offline   Reply With Quote
Old 12th May 2012, 19:42   #2 (permalink)
OOOOSH
smig's Avatar
Car: 2007 Type R GT - NHB
Thanks given: 80
I was thinking of replacing my filter. Is it 150mm or 200mm?
smig is offline   Reply With Quote
Old 12th May 2012, 19:57   #3 (permalink)
cf136322's Avatar
Thanks given: 52
200mm bud, got it from sumopower
Old 25th October 2012, 16:33   #4 (permalink)
Kuneho's Avatar
Car: 2010 Honda Civic Type-R Euro
any pics?
Kuneho is offline   Reply With Quote
Similar Threads for: Changing hks filter
Remap Rolling Road Plot Results - Remapped 2.2 with OEM filter & Pipercross Filter damianscott71 Engines and Transmission 26 22nd April 2012 01:16
changing rsk filter NeoFlare General Discussion 5 11th January 2012 21:38
Induction Changing K&N Filter on Gruppe M.... fonejacker Engines and Transmission 15 3rd October 2011 13:25
Servicing Help/advice on changing the fuel filter on the 2.2 CDTi lawmie Engines and Transmission 16 9th January 2011 21:30
Induction Resetting ECU after changing air filter griffian Engines and Transmission 13 18th November 2010 13:34
