![]() Car: 2012 F10 BMW 520D
Thanks given: 78
If it's the same as the Accord, then here's a DIY I just posted on the accord forum. Originally posted by my fellow Admin, Alnug.
Tools required: A syringe with a small tube attachment...the tube size needed at the end is what you will find in common bic biros A GOOD o-ring compatible grease or a high quality medium/thick silicone grease. ![]() Mine was a silicon based grease i bought from Renault many years ago..was used for ball bearings on plastic runners. It's very good stuff and sticks where it's placed plus is high temp compatible...this is important since clutch fluid makes the clutch master cylinder hot. DO NOT..I REPEAT DO NOT! use WD40 or similar water displacing/ grease removing fluids (yes wd40 actually removes grease!) read below. ALSO Spray can lithium type greases or silicon sprays are also less effective since they don't have the viscocity. Some say it lasts for about a month if that and I have no idea how the lithium reacts with the o-rings. What I'm trying to say is that the grease type used will determine how effective this is. METHOD --------- -look up into the footwell and see where the master cylinder rod goes into the clylinder from the clutch pedal. where the rod goes in you'll see a holding washer(??) which prevents the rod from springing all the way out..on this washer there are two notches cut out and these notches are where you will insert the syringe extension tube (see pic where syringe enters) ![]() -push and HOLD the clutch pedal inwards...this is IMPORTANT! not doing so will mean you don't get the grease all the way in. -push the extension tube of the syringe as far into the holes as you can and squirt in some grease. -rotate the washer, where your syringe enters round,...yep it actually moves around and squirt in more grease...do this all the way round -once you've squirted in enough grease try spreading it around the inside of the cylinder+pushing it as far into the cylinder using the syringe extension. - once that's done work the pedal backwards and forwards to work the grease in. some/ a lot may squirt out of the two notches in the washer but the grease will be where it's needed. Hopefully that will fix the creak/click for a long while...enjoy the drive! DO NOT..I REPEAT DO NOT! go squirting WD40 or similar fluids in there...it may work for a day or more but as the fluid evaporates the lubricity (is there such a word!!!??) vanishes and you're back to the beginning. Worse still WD40 removes what grease was in there to begin with and also dries out the rubber/EPDM that makes up the o-rings in the cylinder and you end up being worse off! You've been warned! you need a thick grease which will stay put. |
Thank You to F6HAD from 4 Users:
![]() Join Date: 10th August 2007
Thanks given: 89
I have had same problem with the squeak when I press the clutch pedal. F6HAD's fix has worked for me.
The CTR has a different clutch pedal arrangement from the Accord as shown in photo below. It is a 5 minute job to grease the piston. You can reach behind the steering column and behind the clutch pedal bracket (red arrow) to apply some grease from the end of your finger on to the piston (green dotted line). |
Thanks to Munro from:
#4 (permalink) | |
![]() Join Date: 3rd October 2011
#7 (permalink) | |
![]() Car: 2007 57 EX 2.2 NHB
Thanks given: 13
Its a cake, not a biscuit
![]() Car: '57 CTR GT
Thanks given: 168
Going to try this tonight. Just to clarify, do I need to follow Munro's and not F6HADS for a CTR?
Most Active Australian
![]() Car: 2010 Black Civic Si FK2
Thanks given: 67
F6HADS pictures are for an accord.
Use his guide with Munros pictures Last edited by Grayfox; 17th January 2013 at 02:37. |
LinkBack to this Thread: http://www.civinfo.com/forum/how/77334-squeaky-clutch.html
| Frizione che cigola - Pagina 8 | This thread | Refback | 10th September 2012 21:14 | |
Similar Threads for: Squeaky Clutch.
| Squeaks squeaky clutch | sammaywalker1 | Bugs, faults and irritations | 30 | 14th June 2012 21:59 |
| Clutch Squeaky clutch | Cbro | Engines and Transmission | 3 | 24th April 2012 08:20 |
| Squeaky Clutch | Starpoint | General Discussion | 8 | 24th October 2011 21:23 |
| Squeaks Squeaky Clutch? | Jason85 | Bugs, faults and irritations | 6 | 6th December 2010 14:34 |
| Squeaky clutch on FN2 | Spudwiser | Type-R | 17 | 27th January 2010 20:47 |
