Old 17th June 2012, 17:19   #1 (permalink)
Car: Type R 2010 Black
Replace Rear Speakers in 3 Door - Using Existing Frames
First off thanks to Munro for his guide on how to replace the rear speakers:
Rear Speakers - Replacement with Coaxials (3 Door)
And to chipywinie over on a foreign Civic forum:
www.clubhondacivic.com - Ver Tema - tutorial : como encajar nuevos altavoces
This guide is a combination of both of these guides and will demonstrate how to replace the rear speakers on a civic 3 door FN2 Type R 2010 using the existing speaker frames.
I had a pair of Pioneer TS-E1702i, 2 way coaxial, 180w speakers spare that I pulled from my old 15 y/o Nissan Almera…(shudder)… and thought I’d stick them in the back as the current set up is more then poor.
Step 1:
Following Munro’s guide remove the red armrest and panel above. Tip to prize the armrest off, wrap the end of a screwdriver in insulating tape and use that. This stops any scratching.
Step 2:
Remove old speaker. One good tip is to concentrate carefully not to drop any screws down the cars frame…like I did! If you do, here’s some ways to get the bloody thing back out!
a) Use a magnetic screwdriver to pull it out (attach the driver to something as it could join the screw!)
b) Use a raw plug with a dollop on blue tack on the end to squish it out!
That worked for me…thank god!
Step 3:
Cut out the old speaker from its frame
Using a sharp blade, cut out the speaker
Job done!
Step 4:
Using the bolt that secured the speaker to the car, secure the speaker to the old frame. I used a plastic washer that held the speaker in tight.
Select applicable holes and, using a sharp pointed screw, secure the speaker in.
Step 5:
Remove the original connector and, using a connector block, attach new wires to the speaker. Test and once happy wrap with electrical insulation tape.
Step6:
Pesky bracket. There is a little bracket that the speaker bolt goes into, use to much force and it will pop out and fall down the car frame…it happened to me!
If the pesky bracket keeps popping out, remove the white plastic and gently bend the metal struts out. This will ensure it won’t pop out again
Step 7:
Both speakers in, now for some hacking of plastic! The red speaker trip won’t go back flush unless you shave some of the internal cone. I took about 1cm off from all around, this done the trick.
This is how much i cut off
If you would like to hear the Pioneer’s in action, here’s a link:
http://db.tt/RZhzPMvx
(if you want to install the baby seat, you first need a baby....that's a totally different guide )
MagnusO is offline   Reply With Quote
Old 17th June 2012, 20:41   #2 (permalink)
tuccy29's Avatar
Car: 2.2 Type S - Milano Red
Thanks given: 63
Great review mate. Im thinking of changing mine in the near future. Do you recommend them speakers then?
How much did you pay for them if you dont mind me asking.
Sent on iphone via tapatalk
tuccy29 is offline   Reply With Quote
Old 17th June 2012, 20:55   #3 (permalink)
thanks Tuccy99. Speakers where about £60 if i remember rightly. They sound great in the back my Type R! I bought them as the main front speakers for my Nissan and they did the job very nicely!
They have a nice rounded crisp sound, but will be looking for more deepness when i upgrade the fronts and tweeters (and maybe a sub!) later in the year
Old 17th June 2012, 20:57   #4 (permalink)
Reasonable Tenor voice
shinybadrobot's Avatar
Car: 2009 type s 1800 i-vtec
Thanks given: 4
Your photos are much to big. It is taking me minutes to load this page.
shinybadrobot is offline   Reply With Quote
Old 17th June 2012, 21:04   #5 (permalink)
Fuel Save Mode..
JimmyH^_^'s Avatar
Car: 2009 FN2 CWE
Thanks given: 342
this is a very good idea like..I like this..
JimmyH^_^ is offline   Reply With Quote
Old 17th June 2012, 21:26   #6 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 831
They would be better uploaded as attachments tbh
Syx is online now   Reply With Quote
Old 17th June 2012, 22:10   #7 (permalink)
Changed the res and quality of each pic. Now should load i-Vtec style
Old 10th August 2012, 19:14   #8 (permalink)
vynz's Avatar
Car: Type-S, iShift
Thanks given: 8
reuse the factory speaker connectors
Thanks to everyone on this site who makes guides like this. Not sure if this is the right place for this but I just wanted to add my contribution which is I discovered that it is possible to dismantle the factory speaker connectors leaving spade connectors behind!
These can then be slotted directly onto the terminals of your new speakers saving loads of splicing and allowing you to quickly return to stock if required
vynz is offline   Reply With Quote
Old 10th August 2012, 19:20   #9 (permalink)
ElNino9's Avatar
Car: Civic type s 2009
Thanks given: 237
Nice guide, will be using this when i get round to doing mine
ElNino9 is offline   Reply With Quote
Old 27th December 2012, 12:55   #10 (permalink)
james1234kenny's Avatar
Car: Civic type R GT FN2 58plate
Thanks given: 3
What size speakers did you use?
james1234kenny is offline   Reply With Quote
Old 29th December 2012, 17:32   #11 (permalink)
Pioneer TS-E1702i: 17cm 2-way Coaxial Speakers (180W)
Old 4th January 2013, 10:07   #12 (permalink)
Kuneho's Avatar
Car: 2010 Honda Civic Type-R Euro
what about the front?
Kuneho is offline   Reply With Quote
Old 8th January 2013, 03:47   #13 (permalink)
shameless
Frank Gallagher's Avatar
Car: 2007 Spaceship with i-shift
Thanks given: 16
the speaker ring adaptors for vauxhall astra/vectra front doors is the right shape and size to be of use in a civic
Frank Gallagher is offline   Reply With Quote
Old 8th January 2013, 06:29   #14 (permalink)
Civinfo Bulb Trader
Aqib's Avatar
Thanks given: 91
Great review
Aqib is offline   Reply With Quote
Similar Threads for: Replace Rear Speakers in 3 Door - Using Existing Frames
Rear Speakers - Replacement with Coaxials (3 Door) Munro How To 18 22nd April 2013 18:05
Infinity 6.5" 2-way rear door speakers for sale Jason DAlby Items for sale 6 13th November 2010 15:27
Speakers Help on how to upgrade front and rear speakers and improve door isolation. Thanks! Hansakraft Ipods, MP3 Players and ICE 8 1st August 2010 20:25
Speakers Rear Speakers in a 3 door! 5ummer5 Ipods, MP3 Players and ICE 12 12th March 2007 22:02
Speakers Do I need to replace front & rear speakers? richierich Ipods, MP3 Players and ICE 5 6th October 2006 12:31
