Old 17th June 2012, 20:41   #1 (permalink)
Stevo M81's Avatar
Car: 2007 Milano CTR GT
Thanks given: 14
How to install a Japspeed Shortshifter
Here is the kit you will receive when you order your shortshifter. There are a couple of people who sell this exact same kit, Japspeed, Shortshifteruk.
I used Shortshiftuk as he only charged £24 delievered, as Japspeed are chargaing £40 delivered.
Here is the links on ebay for them both
Shortshiftuk:
Honda Civic Type R Si 06-08 Short Shifter Shift Quick | eBay
Japspeed:
JAPSPEED HONDA CIVIC TYPE-R FN2 2006-2010 SHORT SHIFTER KIT 40% QUICKER SHIFT | eBay
Right lets get started on how to do this install.
Step 1 - Remove your gear knob like so.
Step 2 - place your hand at the base of the gear stick and pull up as seen in pic, this will release the plastic surround
Step 3 - Now to take out the Armrest and front lower dash, it sounds like its going to be mental but its really simple, Trust me.
1st pull of the 2 blacks caps of the arm rest circled in the pic, you need to do this for both passagner and drivers side. Next unscrew, all 4 bolts.
Step 4 - Pull the armrest up from were the lighter is located and remember to bring it up a little as you have to release the lighter connection underneath. Once this is done remove the armrest as seen in the pics.
Step 5 - Removing the lower front Dash, as seen in the pics remove the 1 cover on the drivers side then remove all 4 push bolts 2 on the drivers side and 2 on the passengers side as indicated in the red circles on the pics. Once done pull out the lower dash. If you have an ipod connection remember to feed it out the hole in the back of the front lower dash pocket.
Step 6 - Right at the base of the gear stick you need to remove the clip that is holding in the blue plastic ball cover. 1st pull the clip at both sides then pull down to release the black cover. Next get the little tool supplied with your kit to remove the blue cover. Put it behind the blue cover and pull foward and it will pop of as in the pic.
Step 7 - Remove the bolts as indicated by the red circles also the item in the blue square i also released the clips on this as it made it easier to remove the rubber shift bushes underneath the bolts you have just taken off. Next Push out the metal in the centre of the rubber base bush and then the rubber after.
Step 8 - Take your metal base bushes and place some white-tac around it as it will help hold it in place when you are installing them. Do this for all three also make sure that the metal bush is facing upright as in pic 1 when installing them.
Step 9 - Replace the bolts and tighten as indicated in the red circles, and thats that part of the job done
Step 10 - Now to install the blue cap on the shortshifter, grease the top of the ball, and then push the blue cap on to the shortshifter or in my case I used a vice as it makes it easier to do. This is not necessary but if you have a vice use it.
Step 11 - Install the shortshifter to the base of the gearstick making sure that it is fully in the shortshifter, then tighten. Next thing to do is to place the black cover on over the blue cap and also put the gear knob back on as you need to check that it is selecting each gear. When I did this i noticed that it catching on 2nd, 4th, 6th and reverse. So i filed a section away and it was fine.
Step 12 Replace the clip on the black cover around the blue cap. Then have one final check selecting all the gears, if happy then just reinstall all the bits you have taken off.
Click the image to open in full size.[/quote]
Step 13 - Take the car out for a drive and enjoy the nice gear throw, feels so much better [smilie=karls_thumb.gif]
Stevo M81 is offline   Reply With Quote
Thank You to Stevo M81 from 10 Users:
Old 20th June 2012, 10:09   #2 (permalink)
Car: 1.6 dig t juke
Thanks given: 4
Shame I fitted mine sbout a month befor this but that is a great guide glad it wasn't just me that it was catching on 2 4 6 r. Good job fella
Bubble is offline   Reply With Quote
Old 20th June 2012, 22:59   #3 (permalink)
Stevo M81's Avatar
Thanks given: 14
Thought I would post the guide as so many people were saying there was none for this kit. Such a great little piece of kit for the price, the gear throw feels great now.
Old 22nd June 2012, 16:27   #4 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
Cheers again for the guide mate.
I've just completed this to my original type r shifter (mugen one currently fitted to the car). One thing I would say to people (if they take care) is to take 10-12mm off the top of the lever and extend the thread to the bottom of the lever using a die. This should help with the shorter throws I would have thought?
I'll get some pictures up when I've finished
parsco is offline   Reply With Quote
Old 25th June 2012, 22:15   #5 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
I completed this on the weekend.
I ended up fitting it to my Mugen shifter and was really easy to fit and has made a HUGE difference
So far I have had no trouble getting it in 3rd gear (usually it was once every drive), been out 3-4 times now and it slots in perfect every time and the throw is so much shorter it's ridiculous
Very cheap and easy mod that everyone should do
Thanks again Stevo
Old 25th June 2012, 22:38   #6 (permalink)
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 3
Will this kit work on a 2.2?
Sent from my BlackBerry 9900 using Tapatalk
stevencavanagh is offline   Reply With Quote
Old 26th June 2012, 08:12   #7 (permalink)
Its a cake, not a biscuit
Spank My Car's Avatar
Car: '57 CTR GT
Thanks given: 167
Installed my shortshifter last night. Had a couple of issues, firstly i was trying to install the washes on top rather than underneath, had difficulty getting the original blue cap off (but soon became a pro, and i also ended up filing quite a lot off..
Didn't take many pictures during the install, as i didn't se the point as this how to guide is ful of all the info you need. But...i did take a before and after video!
Standard:
https://www.youtube.com/watch?v=HRHT...e_gdata_player
Japspeed:
https://www.youtube.com/watch?v=4kdO...e_gdata_player
Spank My Car is offline   Reply With Quote
Old 26th June 2012, 11:17   #8 (permalink)
FireBIade's Avatar
Car: M200, er.....CW
Thanks given: 9
Thanks again Stevo
You added this to the Mugen shifter that already has a shotened throw?
FireBIade is offline   Reply With Quote
Old 26th June 2012, 11:58   #9 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
Correct. It's made the throw even shorter and sharper.
Old 26th June 2012, 12:30   #10 (permalink)
Pheasant Plucker
Fr0d's Avatar
Car: 2006 2.2 EX, NHB
Thanks given: 56
I'd really like to try one of these, but my concerns are with the build quality, long term reliability and insurance implications of such a device?
Fr0d is offline   Reply With Quote
Old 26th June 2012, 12:32   #11 (permalink)
Tom8126's Avatar
Car: 2007 NHB Type R GT
Thanks given: 461
Good job James, will have to let me have a go on the weekend
Sent by me
Tom8126 is online now   Reply With Quote
Old 26th June 2012, 12:56   #12 (permalink)
Car: '57 CTR GT
Thanks given: 167
Sent by me
Defo!
Just trying to find a garage/engineer willing to shorten and die (thread) my gear sharf so the gear knob can sit lower.
Finding it slightly difficult to track someone willing to do it.
Worse case scenario is i'll buy a machine from Machine Mart, but I think I'd prefer someone else to do it for me tbh. Don;t want to knacker the thread completley.
Old 26th June 2012, 17:27   #13 (permalink)
Car: '57 CTR GT
Thanks given: 167
Did you do this?
Old 26th June 2012, 18:28   #14 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
Originally Posted by Spank My Car View Post
Did you do this?
Yes mate, to the original Type R gear shifter not the Mugen one (that is already 10mm shorter). My tap and die set turned up the other day and I've extended the thread further down the shaft now
Old 26th June 2012, 18:34   #15 (permalink)
Car: '57 CTR GT
Thanks given: 167
Was it easy? I've noticed your in Cambridgeshire.... Im gonna be Bishops Stortford this weekend, any chance i could pop round and you could do mine (Trim the stick and die it lower)?
Old 26th June 2012, 18:46   #16 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
I would love to help but (believe it or not) I managed to break my hacksaw while chopping the end off just managed to get it off though.
However, I'm sure I'll be able to get hold of some more blades before the weekend (fingers crossed). I'll be about on Sunday if you'd like it doing?
Old 26th June 2012, 19:11   #17 (permalink)
FireBIade's Avatar
Thanks given: 9
Cool
Old 26th June 2012, 19:17   #18 (permalink)
Car: '57 CTR GT
Thanks given: 167
If you can do early Sunday then im defo interested (Im meeting Tom8126 about lunch time and his teaching me how to clean my car *properly* ) ! I'll cover the cost of the blades too
Is using the die difficult?
Old 26th June 2012, 19:34   #19 (permalink)
THE NINJA
parsco's Avatar
Car: 2007 CTR, NHB
Thanks given: 748
Sounds good, I'll let you know if I can get hold of some blades before Sunday
I'll give you a PM nearer the time
Dead easy using the die mate, I'll show you.
Old 26th June 2012, 19:54   #20 (permalink)
Car: '57 CTR GT
Thanks given: 167
You sir are a legend! Keep me in the loop, I'll PM you my mobile number
Thanks to Spank My Car from:
LinkBack to this Thread: http://www.civinfo.com/forum/how/78160-how-install-japspeed-shortshifter.html
Short Shifter - Strona 15 This thread Refback 19th February 2013 00:37
Similar Threads for: How to install a Japspeed Shortshifter
Japspeed fn2 induction kit Gaz225R Type-R 11 6th June 2012 15:57
Transmission Japspeed Shortshifter Stevo M81 Engines and Transmission 7 17th May 2012 14:26
Japspeed Drift Scooby Nicked!!!! k20_ed Any non Civic chat here please! 22 18th June 2011 08:03
My install First ICE install ever.... onweed Ipods, MP3 Players and ICE 9 2nd October 2010 23:28
My install my new ICE - install VaTaR Ipods, MP3 Players and ICE 9 6th January 2007 09:16
