![]() Join Date: 7th February 2012
Thanks given: 25
Air Box Mod (better sound than most induction kits)
I'm not going to include a (how to remove the airbox filter housing) in this tutorial as it's pretty straight forward to do. This mod work's on all petrol engines but i haven't tested it on a diesel car so cannot comment.
I'm not taking full credit for this mod as i did not discover it but have done this mod on my 2.0l Audi and my 1.8l civic and have noticed a difference on both cars. The sound is hugely improved and the car seem's more eager to shift without consuming fuel like a CAI/Induction Kit. Tool's Required
NOTE - the bottom half of the airbox housing must be removed before drilling due to wiring looms running below the housing when it's installed on the car. Also, i cannot see how this would void your warranty as the holes will be hidden and unless your airbox housing was to be removed for some reason, they wouldn't know it's been modified but please do this mod at your own risk as I will not be held responsible. 1/ Remove the airbox housing only, some people find it easier to remove after taking the battery out but I managed ok with the battery and everything else in place. 2/ The filter housing is in two parts. The part you're going to modify is the bottom section. 3/ You will need to drill approximately 30 x 12mm holes in the bottom section of the filter housing only. The reason for drilling the bottom section of the housing is because all dust particles and debris will still hit the filter. If you were to drill the top section of the housing, all dust and debris would bypass the filter and clog your engine. NOTE -After reading this far into the tutorial, your more than likely having doubts now. This is a perfectly safe modification to do and does exactly the same job as an Induction Kit but without the expense. Not really sure why it sounds better but i'm guessing it's down to the air passing through the holes on the filter housing and because the housing is hollow it creates a deep roaring sound. Once you have drilled the holes, put everything back in reverse order to how you removed it and the modification is complete. I have included a couple of photo's below to give you a better idea of how the bottom housing will look afterwards and to make sure your still on the right track. ![]() ![]() ![]() I welcome all comment's and opinions. If you perform this modification and you don't like it, the bottom part of the housing is cheap and easy enough to replace. I can assure that you won't be dissapointed!! As some of you already know, iv tried different methods and this is by far the best one. |
Thanks to ArcAneD from:
![]() Car: Silver Civic EX 1.8
Thanks given: 3
Interesting, do you think your still getting cool air coming in through the resonator cold feed pipe or is it just sucking in hot air from the bay ?.
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 839
My concerns exactly. Surely you're just going to be sucking nice hot air?
On the 1.8 the airbox base is under £20, but on the 1.4 and CTR it's about £90 so a much more expensive replacement! Last edited by Syx; 26th July 2012 at 20:09. |
Civinfo Trader
![]() Join Date: 1st July 2007
Thanks given: 1,100
OMG
All you have done is reduce the air pressure and drawing hot air in from the engine too...How on earth can this be an improvement?? |
![]() Car: 59 Milano Red
Thanks given: 21
Sorry but i just can not see how this will be an advantage
There are induction kits that will do the job without sucking up all that hot air From the engine bay as said |
無限 Unlimited
![]() Car: 59 Mugenised CTR
Thanks given: 257
As above i cant see how this is an improvement, although Alan titchmarsh might be happy, you could plant a few Gerbera's in there
Thanks to Laney from:
#12 (permalink) | |
Thanks given: 25
It might be retro but it's definately got the best sound and performance over any air filter / induction kit iv ever tried. Thinking of retro, i do believe induction kits were invented way before this mod was lol. There's not alot of heat generated underneath the air filter housing on the 1.8, certainly not on mine anyway. Milano FN2, which type of induction kit are you thinking? Majority are open cone which allow alot more hot air in than this mod. Without the use of a chamber or closed filter. After doing various tests with different filters and induction kits. Every method iv tried excluding the drilled air housing has given lots of heatsoak and quite often struggled when accelerating before a sudden burst of power kicked in. Iv not noticed any flaws with this mod. Last edited by ArcAneD; 26th July 2012 at 22:21. |
Clingfilmed
Thanks given: 839
Please don't think I'm a "hater", mods are worth trying if you think it will give an improvement.
The problem I see here is that you will be drawing in hot air - open the bonnet after a drive and tell me it's not hot in there! A CAI to an enclosed filter is going to give a much better result, the better thing to do here would have been to re-route the intake hose to the front, giving you colder air and a ram effect. Granted you won't get the noise that way; if that's the primary objective here then I've misunderstood. |
#14 (permalink) |
Banned, for being CK
Thanks given: 14
Hks Rsk draws boiling hot air from the engine bay... and costs ££££££££££
and yet somehow thats ok but drilling a few holes for free isnt? LOL. |
#15 (permalink) | |
Thanks given: 25
I'm on the understanding that an enclosed filter is quite expensive? Considering the recession and job losses etc, not everyone can afford to splash that cash for these things. This is a cheap alternative and at a push, pay for some ducting to give a better piece of mind. Still alot cheaper than any kit available. |
#16 (permalink) | ||
Clingfilmed
Thanks given: 839
#17 (permalink) |
Thanks given: 25
Iv never owned an RSK so can't comment but i'm guessing the same or worse than the K&N's? lol. They all do the same thing at the end of the day, it's just different companies manufacture them.
#20 (permalink) |
Thanks given: 3
A none hater also but I just asked if you think a lower % of cool air is still being drawn in via the resonator or is it all coming through the holes.
Thanks to Maca44 from:
Similar Threads for: Air Box Mod (better sound than most induction kits)
| K&N induction kits fn2 | fourthdisciple | Introduce yourself | 9 | 13th April 2012 20:41 |
| HKS induction kits or Group N induction kit? | K15KNY-FN2 | Type-R | 47 | 6th June 2009 13:01 |
| Induction 2.2 induction kits? | deamer2k5 | Engines and Transmission | 53 | 28th March 2009 19:37 |
| Tuning FN2 induction kits | polsonm87 | Engines and Transmission | 0 | 20th November 2008 23:18 |
| Induction kits | reb | Type-R | 12 | 12th November 2008 15:39 |
