This thread is about: Calibrate the speedo, it's in How To at the Honda Civic forum Civinfo; Originally Posted by ctrdaveg Surely sat-nav speeds are not that accurate ?? I think they probably are... How Sat Nav Works TomTom/Sat Nav GPS Spped ...
Old 5th April 2008, 00:16   #21 (permalink)
How Sat Nav Works
TomTom/Sat Nav GPS Spped Accuracy - Page 2 - Volvo Performance Club UK Forums
Old 4th May 2008, 17:39   #22 (permalink)
Enthusiastic Supporter
Miggins's Avatar
Linear % Error
I don't believe the speedometer on the Civic (mine at least) is simply out by a percentage through the range, as was the case with mechanical speedometers in 'olden' days.
Mechanical speedometers used to fall within the legal requirement of 10% up to 70mph and then go haywire at any speed over this (the UK national limit).
My Civic is out by +3mph (seems more sometimes) at 30mph and +4mph at 40mph. At higher speeds it doesn't go out by more than 4mph - this is also the case at speeds above 70mph.....mmmmm. So will a pulse modifier work accurately if the input is not linear? Logic says not unless you can input a non linear variable compensation.
BTW: All speeds were compared with 2 GPS units and another vehicle (SEAT Alhambra) to validate the GPS readings as well as the useless roadside speed indicators!!. All done at steady speeds to ensure the GPS had time to recalculate etc.
Old 5th May 2008, 21:44   #23 (permalink)
p64
Ezermester
p64's Avatar
I think it is the sofware that modifies the speed indication, since mine also deviates about 6 km/h at speeds above 50 km/h up to 160 (did not bother to go higher). Speedo healer is not the right solution. You would be surprised that the odo is quite accurate, within 2%, imo because of the tyre diameter change. So, again, the speedo is manipulated, shame.
andrej
p64 is offline   Reply With Quote
Old 7th May 2008, 19:57   #24 (permalink)
TYPE_R GT in NHB
Big_AL's Avatar
Smile
Think I am loosing the will to live on this one.......Every time I drive past one of those flashing radar posts which reads your speed....usually I am 5 mph high.......so what. When I drive by the gatso's at the wrong speed, let's hope this bit of built in buffer saves me a ticket. Pottsy, I am well impressed that you even contemplated working out how to do this.......
Big_AL is offline   Reply With Quote
Old 7th May 2008, 20:15   #25 (permalink)
philosoma's Avatar
I still have not fitted mine yet, is tricky to get to. Anyone with petrol engine fitted one yet?
philosoma is offline   Reply With Quote
Old 12th July 2008, 10:49   #26 (permalink)
I cant believe this could not be done more easily, without so many nuts and bolts! Just by fiddling with the car software should do the trick!
bbalas74 is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/how/8346-calibrate-speedo.html
Type-R FN2 This thread Refback 24th April 2008 14:32
tarare contakm ? - Elettronica This thread Refback 6th December 2007 23:30
The Best Speed | Honda CIVIC 8. generace This thread Refback 24th September 2007 10:47
Similar Threads for: Calibrate the speedo
Speedo speedo accuracy (merged) Billybobbo Electronics 169 7th July 2008 09:35
Computer tyre calibrate panasony Electronics 2 1st June 2007 17:15
Speedo speedo briang Electronics 1 9th September 2006 19:27
Speedo Speedo Charles_Harding Electronics 9 24th August 2006 23:08
Speedo Digital Speedo GlenMH Electronics 11 27th July 2006 11:49
