| This thread is about: Rear Speakers - Replacement with Coaxials (3 Door), it's in How To at the Honda Civic forum Civinfo; This guide shows you how to replace the rear speakers on a 3 door Civic (ie Type R). The existing speakers are lightweight poor quality ... | ||
This guide shows you how to replace the rear speakers on a 3 door Civic (ie Type R). The existing speakers are lightweight poor quality woofers. The new speakers are coaxial – ie with built in tweeters.
Thanks to Pottsy for the excellent Front Speaker replacement guide. I am assuming you have already done this as the sequence for the rears is similar. Thanks to G4il1 for showing how to remove the rear speaker panels easily – Photos repeated here. Parts Needed: 1 A Pair of quality 6.5” coaxial Speakers – I used Infinity Kappa 62.7i, simply because I found a good deal on ebay (about a third of the retail price!!). They need to be coaxial for the best improvement as there are no separate tweeters in the rear. 2 Two Speaker rings similar to those used for the front doors in Pottsy’s guide. Alternatively make them out of 19mm MDF sheet like I did. (An off cut of MDF cost £2 and this would have been enough to make numerous speaker rings). The MDF needs to be sealed to make it moisture proof - I used wood exterior primer. 3 4 sq ft of Dynamat Extreme soundproofing sheet – optional but recommended. 4 Check you have enough screws, clips and tape etc. Sequence: 1 Remove the red armrest cover as shown in photo. Bend in the red part above the black to help release the clips. It needs a fair bit of levering and fiddling so you need to be very careful not to damage the trim 2 Remove the @ six screws holding on the panel above the armrest 3 Remove the panel above the armrest – this comes off easily. 4 Remove old rear speaker. There is 1 screw at the top, then a bit of a push breaks the bond with the door panel. Watch for the 2 locating clips at the bottom of the speaker. 5 Fix the new speaker ring to the door. I used 4 self tapping screws with panel clips behind the doors. The screws and clips came with the speakers. The steel panel needs to be drilled first. 6 Connect the speaker wires to the crossover. The colour coding in the wiki is repeated here as it is still correct for the Type R. Rear Left + Yellow Rear Left – Brown Rear Right +Blue Rear Right - Orange 7 Wire the crossover to the speaker as per speaker supplier’s instructions. I use duct tape to secure loose cables to panels – this avoids them being the source of an annoying rattle. 8 The Crossover is stuck behind the steel panel with double sided foam tape 9 Apply Dynamat Extreme sound proofing on both sides of the panel the speaker is mounted on + some on the outer body panel (see photos). I used @ 4 sq ft in total, which cost £20. 10 Mount the speaker on the speaker ring. I used 4 small screws per speaker in pre drilled holes. These screws came with the speakers. 11 Put the panels back. 12 Go and enjoy a nice cup of tea. Photos in sequence below: Last edited by Munro; 4th November 2007 at 09:01. Reason: Re sized pictures |
When you fade to the rear speakers only, it sounds a lot better than the original rear speakers - so good for rear passengers. With fade centered (ie normal setting) there is not much of a difference from the drivers seat - only a bit more suround than before. However it took a while for the infinity front speakers to bed in (too much treble at first ) so further improvement expected. |
#5 (permalink) | |
The hardest part is getting the arm rest off - In Picture 1 press the vertical part of the red covering in just above the plastic as you prize it up. This helps release the hidden clips. Here are a couple of diagrams of the area which may help as well. |
Great stuff
Instead of adapters, In the front, I used the rings which come with all components (for holding the grilles on) It does mean you need to drill holes into the metal but you can screw straight trough and it works a treat. I used to have those infinity coax in the front of my old car, they are really clear |
LinkBack to this Thread: http://www.civinfo.com/forum/how/9294-rear-speakers-replacement-coaxials-3-door.html
| Type R/ Type S Lautsprecher hinten : Honda Civic FK, FN, FD | This thread | Pingback | 2nd March 2008 22:37 | |
| Front speakers - replacement with Infinity Ref 6510CS | Pottsy | How To | 315 | 11th September 2008 17:57 |
| Info - Pics of inside door panel with speakers | mr w1z | Wiki Article Discussion | 1 | 26th November 2007 22:31 |
| Speakers Rear Speakers in a 3 door! | 5ummer5 | Ipods, MP3 Players and ICE | 12 | 12th March 2007 21:02 |
| Speakers Rear Speakers - Help please. | BlacknBlue | Ipods, MP3 Players and ICE | 6 | 9th August 2006 20:26 |
| Rear wheel arch replacement? | generationgav | General Discussion | 6 | 22nd June 2006 10:47 |
