| This thread is about: [How To] Type R Spoiler fitting to Type S, it's in How To at the Honda Civic forum Civinfo; Hopefully i'm not going over old ground here, but i've recently fitted a Type R spoiler to my Type S with no major problems. I ... | ||
Hopefully i'm not going over old ground here, but i've recently fitted a Type R spoiler to my Type S with no major problems. I would post some photo's but my camera got half inched on a recent trip to Budapest.
The fitting is relitively straight forward if you have a mate trained as an Aston Martin body tech plus his own work shop in High Wycombe. If anyone needs the inside track on my contact or any aspect of the fitting just let me know. And for the record, it wasn't glued on!! |
hi. im interested in doing the same, fitting the R spoiler on the S, how did you manage to do it, because i had asked others, and i wasnt very keen on glueing the spoiler down. please let me know, with full details on how it was done, as my friend also has a body shop. please reply.barney
The type R spoiler comes with 4 square headed bolts which are located in slots on the under-side of the spoiler itself. In order to familiarise yourself with the spoilers final resting place on the tailgate i suggest you remove the bolts from spoiler by sliding the captured bolts out. Position the spoiler in place and then by tilting the spoiler up and looking underneath you will now see where the bolt ends would have made contact with the perpex tailgate, the purpose being to avoid any premiture marking from the bolt ends. Apply at least 2 x layers of masking tape to the rough bolt contact points. Re-attach the bolt heads to the spoiler and re-position spoiler as before carefully marking the bolt contact points prior to drilling. This is the part where you start to sweat a little and question your accuracy!!. Ideally its a two person job, each holding one end of the spoiler and assessing that you have positioned the drill holes correctly. Pilot drill the holes using a new 3mm/4mm drill, once done offer the spoiler up for a second time just to make sure that the profile on the tailgate lines up with the same profile on the underside of the spoiler. Now re-drill using a 11.5mm or 12mm drill to accept the barrel section of the bolt. The spolier assembly should now locate home with the bolts passing through the perpex. From inside the tailgate itself, gently pull away the plastic trim that is curently hiding the exit points of your drill holes/threaded ends of the bolts and using at least 30mm dia washers and an M6 nut, everything can be loosely tightened up as a pre-fit check. Note: On the bolt ends exiting near the tail-light assembly, you will need to trim-off one side of the washer to avoid fouling problems. Remove spoiler again. The final stage is the infilling (to the correct depth) of the rebates using a fibre glass resin mix where the bridge plates are found at each end of the spoiler itself (i didn't fancy attempting the precision drilling at angles to use these attaching points). Once F/Glass pad is hard, an application of Sikoflex to the F/glass areas only does the trick prior to refitting the spoiler in its final resting place and tightning up the whole assembly. On a final note, use several strips of masking tape to each end of the spoiler to ensure contact pressure while the Sikoflex bonds over night. Job done!!
If all this sounds daunting, the HRD body shop can carry-out the work for £175 and give you peace of mind. |
Where you buy the type r spoiler
where u buy the type r spoiler and how much ????? check this site :
banzai-tuning - Artikel Detail[ID]=773&VID=XLmRIOS59GFT3aqu&saSearch[word]=&saSearch[category]=Civic%20Diesel,%20FN3&saSearch[subcategory]=&saSearch[special]= 279 euros in prime unpainted |
#10 (permalink) | |
hi i`m thinking of getting my skirts & trims coloured to match the car, but a lot of bodyshops say the plastic is textured & the paint might come of in future, does anyone know if this is worth doing or not, please let me know coz honda want to charge me £600
#12 (permalink) | |
painting skirts
Hi there, from an independant body shop, you will get a quote anywhere from 600-900 pounds, i did....but i rang honda, and for once they were cheaper! 300-330 quid for all painted! hope that helps ive also got my type R spoiler on now - 80 quid to buy - from a breakers! 425 retail price! and...fitting was 220 from honda...im a happi boi now! |
#13 (permalink) | |
Nobody gets out alive
it looks good and i don't think you will have a problem in the future mate Painted grey Bumper finish to body color Nellz@Bassetts Milano Red Type S GT |
#14 (permalink) | |
#15 (permalink) |
can all you type s guys out there do me a favor, can u look underneath your car at the back drivers side exhaust pipe before the chrome bit, & see if there is a square cut out of the exhaust pipe as it bends to go upwards into the rear bumper triangle, as i don`t wanna look stupid at honda if it`s supposed to be there thanks.
LinkBack to this Thread: http://www.civinfo.com/forum/how/9653-how-type-r-spoiler-fitting-type-s.html
| HONDAFAN Forum :: Vizualizare subiect - NOUL Civic Type R | This thread | Refback | 6th May 2008 14:17 | |
| S-Vivid Colour coded vivid blue type-s with type-r spoiler and tints | jl133 | Gallery | 30 | 29th June 2008 17:50 |
| Type R Spoiler ......... | Milowski | Holdcroft Honda | 5 | 30th August 2007 11:23 |
| type r spoiler | pete23 | Cleaning and Styling | 19 | 4th August 2007 00:46 |
| Fitting Type S front and rear skirt to 5 Door | kernowcivic | Cleaning and Styling | 10 | 7th June 2007 22:40 |
| Options Type R spoiler!! | mouse123 | Buying, Dealers and Servicing | 16 | 1st March 2007 19:26 |
