![]() Join Date: 2nd October 2007
Thanks given: 8
Raising Compression - J's Racing
Hi James,
J's Racing has raised the compression of a FN2 to 11.7:1. I think they used FD2 RRC pistons. Could you find out more about this please? They saw a good 8% power increase ( 16ps) and a 6% torque over stock compression, by raising it to 11.7 and changing to RRC oil pump. Thanks for all your help. Regards |
PM Matt@Touge - not me!
![]() Car: 2005 Premier EP3
Thanks given: 77
It will be extremely difficult to find out. J's Racing aren't the most helpful bunch if I'm honest.
I will try though. |
![]() Join Date: 26th May 2008
Thanks given: 72
you have to live in japan as they do all the service (it's not only parts).
They will take the block of the car, do the honing of it, change to rrc pistons and rings. You don't need j's racing to do this. |
#7 (permalink) | |
Thanks given: 8
I know Nuno, But would like to know what was changed. Just the pistons to RRC ones?? Or anything else?? The gains were good for OEM cams. So i am inteterested. |
Thanks given: 72
only pistons and rings. Don't think they changed to a the thinner head gasket as j's don't sell them (this would make the CR 0.2 to 0.4 higher).
Thanks given: 8
Any news on this James? Was it just the RRC pump and Pistons that where changed?? Or did they put RRC cams on it aswell? Thanks |
![]() Join Date: 24th May 2009
Thanks given: 1
Hi James
thank you for the info Do you have the J's ECU? RRC Civic FD2R Oil pump? I see the FD2R cam and FD2R piston in your store but no oil pmp only toda shaft killer pump, which will cost me almost 1K SGD but the FD2R oil pump will cost me 450SGD here in singapore thank you |
#14 (permalink) |
Thanks given: 77
Makes sense to buy it in Singapore then.
We are constantly added parts to the store, please be patient. |
#15 (permalink) |
![]() Car: 2009 CTR GT , Silver
Thanks given: 112
These are the parts for oil pump swap!
All are HONDA OEM parts 13441-pcx-004 chain (64l) 13450-pna-004 tensioner, b-chain 13460-pnc-004 guide, oil pump chain 15100-prb-a01 pump assy., oil 11221-pnc-000 plate, baffle |
Similar Threads for: Raising Compression - J's Racing
| CPL RACING header VS TODA RACING header | allagios | Type-R | 65 | 20th December 2010 19:27 |
| Honda World HRC Racing Machines and Racing Kit Parts Lists | Honda News Feed | Honda News | 0 | 8th June 2010 07:00 |
| HKS Racing kit | onweed | Items wanted | 7 | 7th March 2010 14:46 |
| hks racing | boyscotty | ABP Motorsport | 1 | 25th February 2010 18:05 |
| Performance Technical question for beginners: compression ratio + turbo | Jeroen1000 | Engines and Transmission | 15 | 12th July 2008 10:29 |
