Old 4th July 2009, 18:38   #1 (permalink)
Car: Honda Civic Type-R GT
Removed HU - Need Extended Wiring Loom
This is going to be a daft question.
Ive removed the head unit and done EVERYTHING else to install my sound system, all i need to do now is create a extended wiring loom for the head unit adaptors.
My issues are.
1) I can attach the two green plugs (Connector D & E as per Audio connections - Civinfo Wiki).
However the other connector (A) is being used by my new head unit with the ISO connectors to power this, but this connector A is also needed by the original head unit to give it power so that the dash comes on with all the air conditioning instructions etc.
How do you over come this? (If i need to extend the wires and run a feed from one to another, where do i get the conencting unit from? Which wire numbers are needed (as per the above link) so that i dont have to take ages copying all the wires across?)
2) Any easy way to extend the original head units connector D & E cables?
You guidance would be much appreciated!
Regards
Cf
crazyfool321 is offline   Reply With Quote
Old 4th July 2009, 18:42   #2 (permalink)
Car: 07 1,8 Executive 5 door NHB
Can you power the new head unit by another method, thereby leaving A available for the old head unit?
Old 5th July 2009, 11:08   #3 (permalink)
Essexboy's Avatar
I take it you have a non-sat nav car?
Connectors D and E need to go into the old head unit
Connector B is for the steering controls, so if you have an adapter it will connect to this.
Connector A is the difficult one.
For my Kenwood stereo I had to do the following -
A2, A3, A7, A8, A11, A12, A15 and A16 - speakers - connected to new stereo
A9, A10, A14 and A17 had to be connected to both stereos
A1, A4, A6 and A13 had to be connected to the old head unit only.
I could not find the connectors anywhere, they are bespoke and honda do not seem to want to sell them.
My solution involved a pair of wire cutters, a lot of new wire and a soldering iron.
I cut off the A connector and made a wiring loom so this plugged into the back of the old head unit, and the new iso connector plugged into the new Kenwood unit.
I also had an aerial adapter, this was tricky to work out what to do, put it turns out that pin F3 has to be connected to ACC (A14).
Essexboy is offline   Reply With Quote
Thanks to Essexboy from:
Old 6th July 2009, 12:28   #4 (permalink)
Thanks for the assistance.
Its the non sat nav unit.
After a heavy night of thoughts, followed by a curry and some beers, I headed to Halfords. They were really helpful, the managed to find wiring loom kit which duplicated both the power unit and iso connectors, which in turn enables me to get two power units from one lead.
Its called a Honda ISO T Harness. Part number is CT 10 H D03, costs £30.
Now i just need to extend connector D & E then I should be away!
Thanks again for the help.
Thanks to crazyfool321 from:
Old 6th July 2009, 21:28   #5 (permalink)
Type R Hero
oslpag's Avatar
I have just moved my HU into the boot in a non-destructive way i.e. not cutting into the original loom, I hope to post a detailed how to in the next few days, if interested I can PM you when I have the how to completed. I actually found a connector for the 10 pin green plug that fitted perfectly.
Fil
oslpag is offline   Reply With Quote
Thanks to oslpag from:
Old 6th July 2009, 23:43   #6 (permalink)
that would be great. Thanks!
Old 7th July 2009, 17:31   #7 (permalink)
It's all about 無限 | MUGEN
Kimotherapy's Avatar
Car: CTR GT
Yes please send me PM with a how to guide.
Thanks!
Kimotherapy is offline   Reply With Quote
Old 7th July 2009, 17:40   #8 (permalink)
Car: 2.2 ICTDI EX 5 door BLACK
Yes please
P UNIT is offline   Reply With Quote
Similar Threads for: Removed HU - Need Extended Wiring Loom
Electrics New Wiring Loom needed Ryan87 Electronics 10 22nd June 2009 11:24
Towbar wiring loom chris rowden 2009 Civic 11 11th April 2009 18:25
Warranty New Car Extended Warranty alanwalne Buying, Dealers and Servicing 5 6th October 2008 17:04
Aux in loom for satnav cars Marco Wiki Article Discussion 1 2nd December 2007 22:32
Power Loom iPod/CD changer, Sat Nav cars FireStarter For sale and Wanted 0 6th August 2007 16:49
