| This thread is about: [Built in CD] MP3 disc compilation problem, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; I agree that for 'old' recordings (analog) then vinyl is best. Converting analog to digital cannot be lossless. Not so for recent recordings I suggest. ... | ||
#21 (permalink) |
I agree that for 'old' recordings (analog) then vinyl is best. Converting analog to digital cannot be lossless. Not so for recent recordings I suggest. Do the theory ... things recorded in digital ... stored in digital (CD) .... and played back on digital equipment has got to be what the artist wants you to hear!?
#22 (permalink) | |
His thoughts were that if he tooled about in anything expensive he would be easily recognised and bits nicked. Sound thinking |
#23 (permalink) | |
#24 (permalink) | |
#25 (permalink) | |
Does anyone know how to get around this? |
#27 (permalink) |
Vinyl to .MP3 :
Stage 1 - get the vinyl to your PC : Tutorial: How to copy vinyl records and tape cassettes to your PC - Audiotoolers Stage 2 - Clean the file If your recording has clicks and pops then there are applications out there to clean them. I use CoolEdit Pro (now Adobe Audition) but that is very expensive and other, cheaper solutions are available. Personally I always remove clicks & pops manually as I find that the auto cleaners tend to remove more than required and leave the whole track sounding flat. Once cleaned you will need to 'normalize' the recording. This is a procedure where the track is scanned and the loudest part is raised to 100% and the rest of the track increased in volume to match. This ensures that the whole recording or set of recordings are all at the same volume level. Then use either Nero or Roxio to burn all the now cleaned and normalized .WAV files to your CDR as .MP3 which means you need to use the data format. Burning as audio will produce .CDA files and you will only get about 70mins per CDR. |
#28 (permalink) |
Thanks!
My wife will not love this! I've seen a couple of turnables with USB for direct conversion to your PC (plug & play = GH friendly). Any opinions on the sound quality these produce? I'll bet they won't beat my old Thorens, but anyway this is 192b MP3 files in a car.... |
#29 (permalink) |
Most modern HiFi setups no longer cater for turntables hence I think the market for the USB varieties.
If you have a turntable and an amplifier with 'cassette out' phonos then it's cheaper to use that. 2 x phono to 3.5 stereo jack, then make sure Windows recording is set to line-in instead of it's default microphone = proper job! |
#32 (permalink) | |
You will still get an error message though if iTunes converts the CD songs into AAC and you want to burn those as MP3. You can easily check the format by showing the "type" (or something like that, my iTunes is in Dutch, don't know the English term uses in iTunes). Right click on the column heads and tag "type" to do that. Then select all the AAC songs, right click and choose "convert selection to MP3". If that worked, you can burn the songs as Mp3. To prevent having to do this in the future, let iTunes convert CD-tracks to MP3 immediately by changing the preferences. If your songs actually are protected, there is software available to convert protected mp4 (=aac) songs to mp3. Just google on Internet and you will find them for sure. Peter |
#33 (permalink) | |
Type-R GT [R-11523]
I don't remember how to turn it off once iTunes is already installed... -H |
#34 (permalink) |
Just had similar problems with a cd I burned yesterday...
I didn't realise how stupid the inbuilt mp3 cd player really is Haven't checked for the numbering of tracks although if I have to number all the tracks before burning them in that will be very annoying and you will lose information due to the aformentioned cap on track listing characters! Not a very good solution if you ask me, my old Alpine CD player worked perfectly with mp3 tracks. That said though what are the possibilities of Honda bringing out a firmware update for the in car system, fixing these issues (reading id3 tags to organise songs) and maybe improving it? How cool would it be to have album art aswell? |
| Sponsored Links | |
Advertisement |
Similar Threads for: [Built in CD] MP3 disc compilation problem
| No SatNav disc | oldmanchris | Electronics | 18 | 20th March 2008 22:12 |
| MP3 compilation disc | LoonyJohn | Ipods, MP3 Players and ICE | 44 | 10th March 2008 15:07 |
| Does the disc need to be loaded to use sat-nav? | FWH | Electronics | 3 | 8th June 2007 18:44 |
| 17" wheels and disc covers. | TonyBee | Wheels, Tyres, Suspension and Brakes | 6 | 23rd December 2006 09:13 |
