This thread is about: Ground Loop Isolator, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; I've just bought a ground loop isolator for the Connects2 box, only one minor issue. The input is 2 male phono's, the output is 2 ...
Old 23rd June 2008, 21:40   #1 (permalink)
generationgav's Avatar
I've just bought a ground loop isolator for the Connects2 box, only one minor issue. The input is 2 male phono's, the output is 2 female.
I want to place the box in between the jack plug and the Connects 2 box, therefore I could do with the inputs being female and the output's being male.
Does anybody know if the ground loop isolator can be fitted either way round or does it matter? If so then do I need a female - female adaptor on one end and another phono to phono lead on the other?
Old 23rd June 2008, 22:43   #2 (permalink)
I think it can be fitted either way - you could try it and see if it gets rid of the whine (fitted the "wrong" way)...
Old 24th June 2008, 07:57   #3 (permalink)
jj69's Avatar
Basic ground loop isolator is just a transformer with 1:1 ratio, if no other filter is included, you should be able to fit it either way round.
If there's no power input on the isolator box (meaning no active filter inside) it should be safe to try
jj69 is offline   Reply With Quote
Old 24th June 2008, 09:23   #4 (permalink)
Thanks.
I will try it - but not planning on pulling my dash apart until the weekend, but wanted to know if I should get the bits!
Will definitely try it first and see how I get on.
Old 24th June 2008, 09:30   #5 (permalink)
coolice's Avatar
Hey,
If all else fails there are gender converters available to convert from female to male and vice-versa.
I've used a ground loop isolator in the the past but have never connected it the other way to see if there was any difference. However it must be labelled input & output for a reason and so I'd be inclined to say there may be a genuine reason for it to be connected a certain way.
Only a test will tell.
Ian
Old 25th June 2008, 06:03   #6 (permalink)
Jani's Avatar
I have groundloop isolator connected to connects2box. It doesn't matter how it is connected, because "it is just a transformer" like jj69 said.
Jani is offline   Reply With Quote
Old 25th June 2008, 13:46   #7 (permalink)
Thanks,
How well does it work? I take it you've got it between the mp3 player and connects2 box?
How much difference does it make?
Old 25th June 2008, 14:08   #8 (permalink)
Jani's Avatar
Well, it's between laptop and connects2box. For me grouldloop isolator makes a huge difference. My laptop and all the cables etc. caused so much interference that it was impossible to listen music when driving. It was bad even when car was engine on, but I wasn't driving. (engine interference).
I bought isolator and that was the end of interference in my car. I really mean it stopped all interference problems.
Old 1st July 2008, 13:39   #9 (permalink)
It works! Thanks everyone.
I've fitted it the "wrong" way and there's now no audible inteference in the system and I can't notice any loss in quality either!
Similar Threads for: Ground Loop Isolator
Ground Terminal pedro_coelho General Discussion 0 26th April 2008 23:04
Honda Aero Breaks Ground for Headquarters and Plant Honda News Feed Honda News 0 30th November 2007 06:40
Electrics Ground wire upgrade PTR Electronics 10 13th September 2007 22:36
Fruit Loop Neighbour jme1978 Any non Civic chat here please! 2 16th May 2007 12:18
