Old 6th September 2008, 09:28   #1 (permalink)
Legend88's Avatar
Question Creating a new music CD - Help!
Hello,
I can't find the answer to these questions in Wiki so hopefully someone out there will know the answers?
Q1) Does the cd player only play WMA type files or does it play MP3?
Q2) Do you create an MP3 cd in the same format as you do for WMA? (I found the link on how to do this in the Wiki).
Q3) Which file type gives the best sound output - Mp3 or WMA?
Q4) What type of disc is best and can you use 80min cd's and do DVD's work?
Thanks for your help
Legend88 is offline   Reply With Quote
Old 6th September 2008, 09:31   #2 (permalink)
Goodbye all, have fun!
DVD's don't work. You can do WMA or MP3, the advantage of using WMA is that you will be able to fit more songs on the disc than if you used MP3
Have you got Nero Burning software?
Old 6th September 2008, 09:36   #3 (permalink)
brawnr's Avatar
Here's a cut and paste from wikipedia (note that WMA is made by microsoft):
"Microsoft claims that audio encoded with WMA sounds better than MP3 at the same bit rate; Microsoft also claims that audio encoded with WMA at lower bit rates sound better than MP3 at higher bit rates. Double blind listening tests with other lossy audio codecs have shown varying results, from failure to support Microsoft's claims about its superior quality to supremacy over other codecs. One independent test conducted in May 2004 at 128 kbit/s showed that WMA was roughly equivalent to LAME MP3; inferior to AAC and Vorbis; and superior to ATRAC3 (software version). Another test performed by ExtremeTech showed different results, however, placing WMA at the top of the list in terms of quality."
brawnr is offline   Reply With Quote
Old 6th September 2008, 09:40   #4 (permalink)
HappyMan's Avatar
Car: 1.8 EX NHB 2007
You need to get a program like 'Nero' which can copy the CD.
You can also get programs like CDex which converts songs into MP3 format.
Old 6th September 2008, 09:50   #5 (permalink)
Car: Type R GT
If you do use Nero, then when you create a CD use the 'Create Jukebox CD' function and you can fit around 16 albums on one cdr in mp3 format, about the same as you can in wma format.
Old 6th September 2008, 10:05   #6 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
Car: 2.2 type S GT (Milano)
It really depends on the size of the albums- you cant more or less depending on the size and number of tracks.
I think i managed 25 albums once- but that was mostly beatles stuff ( short tracks, short albums)
Old 6th September 2008, 10:09   #7 (permalink)
Nice to hear someone else has a good taste in music!!
Old 6th September 2008, 10:09   #8 (permalink)
Car: Type R GT
Yes mine are usually compilations, around 20 tracks on each.
I have just used Nero to convert an album from mp3 format to wma format, to compare the size of the files. There were 18 tracks on it. In mp3 format it was 55 mb and in wma format it was 52 mb, so not much difference really.
Old 6th September 2008, 15:00   #9 (permalink)
AJS007's Avatar
Hello,
I've just created an MP3 tutorial for the complete novice here > New MP3 tutorial
AJS007 is offline   Reply With Quote
Old 7th September 2008, 01:40   #10 (permalink)
Legend88's Avatar
Thanks everyone, some really good advice . I'm off now to try it out!
Great "Tutorial" AJS007!
Similar Threads for: Creating a new music CD - Help!
Music in your CTR THP General Discussion 8 25th May 2008 20:27
music mbase Type-R 14 25th May 2008 19:15
Creating a post with a picture Pottsy Basic tutorials 0 10th December 2006 16:11
Creating your first new post Pottsy Basic tutorials 0 10th December 2006 15:48
Music Maldax Any non Civic chat here please! 31 23rd July 2006 17:21
