| This thread is about: Radio problems, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; Good morning folks - Joined the forum just now and was not surprised to see a few threads about poorly performing radios - this, too, ... | ||
Radio problems
Joined the forum just now and was not surprised to see a few threads about poorly performing radios - this, too, has been my experience with a 2.2 Sport bought in March. I have started a new thread on the topic because I am interested in whether there is an identifiable pattern. Many of the previous posts complain generally of poor reception while others (fewer) observe that the AF function within RDS sometimes fails to tune to a stronger signal when the car is moving. I suspect they're all pointing up symptoms of the same basic problem. Allow me to explain. I complained about the radio in our car within a fortnight of taking delivery and had it changed under warranty in April/May, but the replacement was little better. Like its predecessor, it is intermittently ignorant of the alternative frequencies available under the pre-set buttons and it often fails to re-tune, even though a far stronger signal of that particular broadcast is available and easily found if the scan button is pressed. The issue is particularly evident if the car is driven from one area to another with the radio off. Upon arrival, one can turn the radio on, press a pre-set, and be greeted with nothing but FM hiss. However, if one then 'forces' the radio to tune either up or down the frequency spectrum by pressing scan, it will find a perfectly good signal. This 'feature' is as far as I can tell independent of what pre-set one is pressing – in other words it can apply to all of them at various times. Just for the record, I have the logical BBC stations under pre-sets from 1-4 and Classic FM under 5. RDS AF is not perfect and all car radios can occasionally be caught out and not immediately re-tune when reception quality drops off. However on every other radio I've used, pressing the appropriate pre-set forces immediately forces the AF function to make a search and re-tune. Not so with the Civic radio. While a few of the problems reported on this forum may be down to faulty signal boosters or a duff connection between the radio and the window antenna, but I think that there is a fundamental design fault that afflicts ALL Civic radios: the unit is either incapable of decoding the alternative frequency information broadcast by the nearest transmitter, or is receiving it but is unable to act upon the information being provided. Here's the test: Turn on frequency display and note your strongest Radio 2 frequency (or 1, 3 or 4). Tune to a weak Radio 2 (or 1, 3 or 4) signal. Press and hold a pre-set button until the unit beeps and accepts the pre-set. Wait until hell freezes over – your radio will not now automatically seek out to the strongest frequency for the station you have selected. At my local dealer, Fish Brothers in Swindon, the workshop supervisor witnessed for himself this failure to automatically change frequency, and he was able to replicate the fault on my vehicle and, subsequently, on another Civic that was in for service. I have personally tried the same trick on 3 other Civics recently and they too exhibited identical symptoms. Honda's customer care people told me that they were aware of 'a problem' and that the radio manufacturer was sending a team from Japan to 'investigate the UK's unique radio environment.' I personally think they're in denial. There is nothing special about the UK – just ask Blaupunkt, Sony et. al. My guess is it's a glorious *ock-up by the radio's manufacturer: either a generic fault in the design of the RDS chip they've used in the radio, or an error in the firmware that prevents the chip working as designed. Either way, it's not at all confidence inspiring. As I observed to Honda customer care, RDS has been available in the UK since the early 90s and it is farcical to have such a problem in 2006, let alone in a car costing just shy of 17k. Regards to all. KevinF. Last edited by Pottsy; 19th November 2006 at 15:19. Reason: Increased font size |
Kevin. A nice and clear precis of our problems.
We wait in hope for the solution! Have you seen the other thread about switching AFSEL off, which has resulted in an improvement for some? |
Kevin - welcome!
I have an EX and the radio works perfectly. The ability to hear weak stations is astonishing, possibly the best I've ever had (right up there with a £1000 Alpine). So I wonder if the problem is limited to non EX cars. Here's a demo. 1. Go into diagnostic mode by pressing and holding (in order) 1, 6 and then press the power on button. 2. Press and hold FM for a few seconds to see the signal strength. 3. Tune R4 on 93.7 (strength 43 db). 4. After 20 seconds or so, the RDS AF re-tunes to 92.7 (strength 64 db). If you try to tune a weak station (on mine about 17-22 db) where I get good hiss-free sound, but there's no RDS data, it will not re-tune because it doesn't know the AF frequencies. Pottsy Video of it in action (click on the play symbol) |
I had the exact same issue with RDS not tuning in to the strongest signal, but I fixed.
I turned of the A-SEL function which when on prevents the RDS tuning from working. Since I turned it off the retuning has been working perfectly for me. Ian |
#11 (permalink) | |
I wouldn't expect this to work because when turning the radio on, the signal is too weak for RDS data to be received, hence no AF. Regards, pcr. |
#13 (permalink) | |
#15 (permalink) |
hmm i did not have this problem until my radio was replaced under warranty for randomly being silent when using the radio (not the cd), now i have a new radio it seems like ive got the same "fault" as KevinF.
is it just that they might not have pushed the ariel fully back into the radio when they fitted it? i also have a sport 2.2. |
#17 (permalink) |
French Stations
Coming back from france recently in northern france radio 2 worked fine get of the boat at dover and for a least 20 mins the radio would not find anything but french stations i turned it off used the cd next time i turned it on it was back to normal (which is only so so)
I think it must be a software problem or maybe i should move to france Still like driving the civic Just wish honda would fix the design faults |
#18 (permalink) |
My radio reception is really poor when I use the rear window demister. It is going in on Monday for some warranty work of which this is one.
Following all the various 'poor radio' threads it would appear that the EX does not exhibit the same problems as other models, such as the ES. Perhaps they are wired differently due to the presence of the sat nav? |
#19 (permalink) |
Geoff, couldn't agree more about Honda fixing the design faults. The most worrying thing about the Civic, and the radio issue is typical, is the inconsistency of the problems. Now I know that many people will have had no problems or make allowances and that by the very nature of people more faults are likely to get posted on forums such as this but having looked at some other forums this one does seem to have a lot of problems posted on it.
My problems; Drivers window developing mind of its own Gearbox - 2nd and 3rd falling out with each other - replaced Dampers - Relieving themselves over my drive - replaced Colour - Galaxy grey - It was like expecting Kylie and getting Sue Pollard, brochure suggested nice gunmetal what I've got is taupe. Passenger seat base detaching itself from frame. Instability under braking Inconsistent performance and MPG Radio HFT and voice activation microphone sited for LHD cars which is partly why it doesn't work properly. Fuel filler flap Every possible combination of creak, squeak, rattle, buzz, clonk at various times and sometimes all together. The worst thing about it all is that its made me a bad driver, because I'm so fed up with the car I don't care if I kerb the wheels or that one of the mirrors is held on my duct tape, or the oil light is on (again) or the service should have been done ages ago etc, etc. All Honda had to do when they had the car back at the factory for a month was admit to & fix some of the problems noy just give it a clean and a polish. |
#20 (permalink) |
My car went in for some warranty issues today, the radio included. Luckily the garage was able to replicate my problems, including the TP icon disappearing when cold and the poor reception with the heated rear windscreen on.
I am now advised that the poor reception is possibly due to a secondary cable, which runs down the passenger side A pillar being trapped behind the dash/radio. They have to order the part and will fit it at the same time as my iPod link to save taking the dash apart twice. |
| Site problems? | Naresh | Site suggestions, feedback and rules | 12 | 16th October 2007 20:33 |
| Music Problems with Radio 1 through tweeters | Ham'sCivic | Bugs, faults and irritations | 8 | 22nd June 2007 14:12 |
| Any new CTR problems, i have.... | mr w1z | Type-R | 10 | 2nd June 2007 02:14 |
| Satnav Any problems with satnav/ HFT | rayhopkins | Electronics | 25 | 21st March 2007 21:02 |
| Phone hft problems | panasony | Electronics | 4 | 28th January 2007 02:24 |
