This thread is about: Mp3 CD's, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; dtm, welcome! This has to be an encoding issue - are the skipping one encoded at the same bitrate as the non skippers? Or encoded ...
Old 2nd August 2006, 21:06   #21 (permalink)
dtm, welcome!
This has to be an encoding issue - are the skipping one encoded at the same bitrate as the non skippers? Or encoded using different software? To eliminate the disc, you could try re-burning and seeing if the skipping ones are the same on the two discs.
Old 2nd August 2006, 21:26   #22 (permalink)
basegreen's Avatar
Guessing it's a CDR issue.
Old 2nd August 2006, 22:05   #23 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Been playing a cd with multiple folders and albums (All mp3's) to-day with no problems at all.
Old 2nd August 2006, 22:15   #24 (permalink)
Ancient Nerd's Avatar
No problems with mine. Only slight whinge is that it takes a while to start playing at startup , and after an interruption ( traffic info etc. ). Otherwise it really is very good
Old 2nd August 2006, 23:10   #25 (permalink)
Bungle's Avatar
I have had some problems with the CDs...
I have only tried WMA format using Media Player to encode the tracks. When I tried to create the CD, Media Player insisted in shoving all the tracks into the root of the CD. Annoying with 100+ tracks with no folders!
Secondly, if I just use Windows to create the CD, no matter what I do; the folders are arranged alphabetically. I cannot seem to stop this happening. I was trying to make a CD of one band, and I wanted their albums (folders) in chronological order, but now they are just alphabetical.
Thirdly, every once in a while, a loud crackly sort of sound, similar to noise on an unused radio frequency, but more harsh, comes through. It comes through loed and is enough to make me jump when it occurs during quiter moments.
Anybody had a similar problem or have any ideas of how I might fix it.
Thinking about it more, I'd like a control on the wheel to change folders or display. To be honest, thought, I find myself using the dash controls more then the wheel ones unless I think about it.
Old 2nd August 2006, 23:17   #26 (permalink)
WoolyCiv's Avatar
A good MP3 encoder is MediaMonkey http://www.mediamonkey.com/, if you do a google search you will find ways of using the full version
Old 2nd August 2006, 23:29   #27 (permalink)
dtm316's Avatar
Cheers Pottsy. I was guessing it was an encoding issue. I've downloaded mediamonkey to aid in the tagging of tracks do you know if this can re-encode existing mp3's?
Scrub that, I've just had a play around and I think I've figured it out
dtm316 is offline   Reply With Quote
Old 3rd August 2006, 07:16   #28 (permalink)
Smell My Cheese!
richierich's Avatar
Noticed the other day that media player can change the tag info on tracks, but I guess the tags need changing before burning to CD, rather than on the host machine, otherwise it will screw them up for good. I have created a folder for the MP3 I wanted to burn and then changed tag info that way. ball-aching job, still not found anyway of renaming/editing multiple tracks
Old 3rd August 2006, 10:07   #29 (permalink)
I use a program called Magic File Renamer. This allows some extremely complex renames to be done, including filenames, MP3 tags etc.. The standard version is sufficient.
It costs (I think) $15, but the demo version has full functionality and allows 100 rename operations. Given that I have very rarely needed more than one rename operation to make all the changes I need to the tracks of an audio book, including filenames and MP3 tags, this goes a long way. (Typically this involves 100-200 file renames etc as one operation).
Details are at http://www.finebytes.com/mfr
Old 3rd August 2006, 10:59   #30 (permalink)
Or the excellent, free TagScanner that does everything you can think of. Homepage can be a bit slow, but you can download here.
Old 3rd August 2006, 11:14   #31 (permalink)
If it's only the tags you want to change, then TagScanner wins hands down. I have it, but rarely use it, only because I tend to do a lot of general file renaming anyway.
Old 3rd August 2006, 11:55   #32 (permalink)
dtm316's Avatar
OK tried my new disc after using the re-encode option in mediamonkey and it works fine now thanks Pottsy. For those that may have come across this problem, you can highlight the track in mediamonkey and then select Tools along the top and then re-encode, I accepted the default encode setting (compatible 128bit) and the option to use the same filename and it works a treat.
Old 13th August 2006, 22:55   #33 (permalink)
kho
kho's Avatar
Just a quick note. If you er... get your mp3 collection from other "resources". They sometimes come with a playlist or images of the album cover etc. When you copy the folder to cd make sure these files don't get copied to the disc, you only want the ".mp3/.wma" files. (Folders are ok)
I had a problem where my cd player couldn't read the disc bcos it kept hanging on these alien files and or weird folder names.
kho is offline   Reply With Quote
Old 14th August 2006, 08:45   #34 (permalink)
allan40alt's Avatar
I used 'mp3 maker - titanium' by 'magix' (cost £9.99) to convert my 12 most played audio cd's into mp3 format and then created a playlist and transferred them onto one mp3 CD. I had to enter the ID3 tags manually and put a, b, c etc in front of each album title so that they appear in the order I want. All the album, track and artist info comes up in the display on my EX. That gives me 12 albums (and a couple of singles) on one CD.
Old 20th August 2006, 15:52   #35 (permalink)
Big Civic fan
stu_iow's Avatar
I use a piece of software called "Tag&Rename".
I used to use it for a MP3 player i used to have in my Clio.
You can change file names, tag details either singlely or by batch using "mask" methods.
stu_iow is offline   Reply With Quote
Old 18th May 2007, 09:13   #36 (permalink)
k10
k10's Avatar
Bungle - The only way I've been able to get round this is to prefix the folder names with a 1. , 2. , 3. , etc. to make them list in my chosen order.
Has anyone noticed a fault where the first track in a folder does not always correctly display the track name (I seem to recall it shows the artist name or something else) as soon as you go to track 2 all is back to normal.
k10 is offline   Reply With Quote
Old 18th May 2007, 10:22   #37 (permalink)
spile's Avatar
has anyone had a problem with some .mp3's skipping/jumping very frequently during playback
It might be worth trying different media to see if that is the issue.
In terms of what to use, I find the Itunes (it is free and you don't need an IPOD) is the best for me. It allows you do manage your MP3s, edit ID information and burn playlists to CD. It even prompts you to add additional blanck CDs when you need more than one.
TiP: Itunes normally creates folders on your CD representing Artists/Albums depending on what you've sorted you media by.
If you sort by Track title it creates all the MP3s to the root with no folders.
Tip2: The shy Disp button to the left of the CD slot allows you to toggle what is displayed on screen.
spile is offline   Reply With Quote
Similar Threads for: Mp3 CD's
Built in CD 90Min CD's with WMA & MP3 goumet Ipods, MP3 Players and ICE 8 2nd October 2007 15:15
Built in CD Playing mp3 cd's and seeing what's next? (EX question) stu_iow Ipods, MP3 Players and ICE 5 10th December 2006 09:46
Built in CD Does EX Display Info for Normal CD's? pjelsworth Ipods, MP3 Players and ICE 6 8th October 2006 10:19
Built in CD MP3 CD's in Album not Alphabetical order? Help. Roger Harris Ipods, MP3 Players and ICE 21 12th July 2006 08:36
