This thread is about: Rear speaker upgrade??...., it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; Ok....I've done the interior blue lighting upgrade, and the front speaker upgrade(Infinity 6510cs...thanks potsy!), applied the auto-door-lock and unlock.....next on my list is the Rear ...
Old 26th June 2006, 14:13   #1 (permalink)
Raegten's Avatar
Ok....I've done the interior blue lighting upgrade, and the front speaker upgrade(Infinity 6510cs...thanks potsy!), applied the auto-door-lock and unlock.....next on my list is the Rear speakers.
I was just wondering if anyone has boldly gone before me? These projects are so much easier when youhave a few pictures and a recomendation on what kit to use.
Failing that, does anyone know what size the rear speakers are and could that recomend a suitable replacement?
Thanks Guys!
Raegten is offline   Reply With Quote
Old 26th June 2006, 15:29   #2 (permalink)
did u do the front ones yourself? if so did you take any pics etc?
Old 26th June 2006, 15:59   #3 (permalink)
Nadz,
Raegten installed the same speakers that I did here:
http://www.civinfo.com/forum/viewtopic.php?t=289
Old 27th June 2006, 00:10   #4 (permalink)
Raegten's Avatar
Yeah, Same speakers as pottsy but I splashed out on the speaker rings too just to dress them up a bit ( an amazing rip of at €54 for two plastic rings!!) and I fitted the tweeters slightly differently to continue the silver and black theme. I'll get a couple of pics up tomorrow.
Old 27th June 2006, 17:45   #5 (permalink)
Raegten's Avatar
Here's the pictures of the finished front speaker upgrade as promised....[url=http://upload4.postimage.org/490623/photo_hosting.html][img]
Old 27th June 2006, 23:01   #6 (permalink)
Bigian's Avatar
Raegten – You have done a great job, how did you fit the tweeters to show the silver trim?
I to would like to change the rear speakers but need advice on type and size.
Bigian is offline   Reply With Quote
Old 27th June 2006, 23:33   #7 (permalink)
Raegten's Avatar
The Speakers that me and Pottsy used were the Infinity Reference 6510cs With Astra speaker mounts. THe links are listed on Pottsy's post about the front speaker upgrade. They cost about £100 for the set and another £10 for the Astra speaker mounts. The kit comes with a whole bunch of different adapters for the tweeters. The one I went for uses three different parts...a silver dish that the tweeter sits in, a cylindrical black collar that fits (with a small amount of filing) into the existing facade on the dash and a colar that screws onto the back to hold the unit in place. The tweeters can then be pointed to achieve the best acoustics. The other thing is that I still have all the existing parts so if I ever need to I can go back to the factory fit.
The silver rings on the woofers are the honda parts...ridiculously expensive for what they are but I'm still glad I went for them. It just goes so well with the whole "theme" in the car.
Rear speakers next I think....they're really drowned out by the front speakers now.
Old 28th June 2006, 11:33   #8 (permalink)
Bigian's Avatar
Thanks for your help.
Old 28th June 2006, 11:42   #9 (permalink)
basegreen's Avatar
Which tweeter did you go for?
Old 28th June 2006, 12:18   #10 (permalink)
Bigian's Avatar
I will go for the infinity set like the other lads but i will buy mine from an e-bay supplier. They cost £62 plus £7 P&P brand new. However Iam still waiting for advice on replacement rear speakers.cheers.
Old 28th June 2006, 12:33   #11 (permalink)
Assuming the rears have the same size speaker, they do not have a tweeter - I Think?
I would suggest these to compliment the fronts that you have chosen.
http://infinitysystems.com/caraudio/product.aspx?ProdId='REF6012I'&Ser=REF&Cat=MEL
- You are not going to get masses of bass from a 6.5 inch speaker in the rear, but this should be better than the stock. If you want low end, then a Compact sub may be the best solution, running from the speaker wires.
To keep the inifinty them going, one of these may even fit under the floor in the boot.
http://infinitysystems.com/caraudio/product.aspx?ProdId='BASSLINK+X'&Ser=BSL&Cat=SUB
You would probably need to feed power from the battery to the boot, but not a major job really.
karlak is offline   Reply With Quote
Old 28th June 2006, 12:50   #12 (permalink)
Bigian's Avatar
Thanks for your help - there is a socket in the rear so that mabe easily accessed.
Old 28th June 2006, 15:00   #13 (permalink)
Beware; Check the fuse rating of the socket in the boot. The preferred route would be a cable direct to the battery.
If the power to the boot is 'ignition switched' that could be used for power on/off
Old 28th June 2006, 15:54   #14 (permalink)
Bigian's Avatar
If I go down that route I will make sure the fuse is adequate - thanks for your advice.
Old 28th June 2006, 16:41   #15 (permalink)
Raegten's Avatar
Karlak, You mentioned in another post thatthe speaker adaptor to use for the rear speakers was a 100mm speaker adaptor kit for the Astra....but your URL links to a page with a 160mm speaker on it. Have you been able to confirm the size of the rear speakers? If not I might have a look at them on Saturday to confirm.
Old 28th June 2006, 17:02   #16 (permalink)
I have not actually fitted the speakers. I was really just suggesting using the same manufacture speaker, whichever size that may be.
Old 17th July 2006, 22:19   #17 (permalink)
Bigian's Avatar
Can any one confirm rear speaker size and what adaptor would fit. cheers
Old 17th July 2006, 22:50   #18 (permalink)
Deemon's Avatar
I had the rear speakers out when I was installing my sub, Didn't take any measurements but they looked the same size as the fronts.
http://www.civinfo.com/forum/viewtopic.php?t=417
Deemon is offline   Reply With Quote
Old 18th July 2006, 08:01   #19 (permalink)
Bigian's Avatar
Thanks Deemon.
Old 18th July 2006, 08:14   #20 (permalink)
deffo same size as the fronts
Similar Threads for: Rear speaker upgrade??....
Civic Type'R Front & Rear Skirt Upgrade jamesaberdeen73 Type-R 3 9th October 2007 22:28
request - speaker upgrade, mudflaps? vtec-hungry Type-R 14 17th September 2007 01:58
Bassworks speaker upgrade kit - sound quality ? lubej Ipods, MP3 Players and ICE 7 20th July 2007 07:00
Speakers Lost sound from ALL speakers after front speaker upgrade Raegten Ipods, MP3 Players and ICE 5 25th June 2006 20:23
Speakers After Market Speaker upgrade andymc63 Ipods, MP3 Players and ICE 13 13th June 2006 15:11
