| This thread is about: Weird glitch playing MP3 CDs/CDR discs, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; I recently put some tracks onto recordable CDs from the music library on my computer. Some were MP3s downloaded from the net and some were ... | ||
I recently put some tracks onto recordable CDs from the music library on my computer. Some were MP3s downloaded from the net and some were from CDs that I own which I'd ripped to put on my MP3 player.
All of these discs were pretty full with music (about 18-20) tracks on each disc. However, when playing them in my car (Civ Type-S) they seem to get about half way through, then either completely fail (and a "disc error") message appears or they play in a very broken and distorted way. Is this because the car CD player can't read the full disc properly? Should I be using a particular type of disc? Any thoughts on this one? |
Didn´t have any problems with mine so far, but as far as I know, the brand of the CD´r can make a big difference. So I would suggest to try another brand of CD´r and try again. Next to that I should also try to burn the CD at lower speed...
Greek Subtopic Moderator
my advice is to burn your normal cd's at lowest speed...but i can't understand the reason of doing it in a mp3 cd...
Of course i agree taht the brand of the cd's makes a big difference...so try not to choose no name cd's for your cd player... |
Normal CD's are .CDA files which as you say are about 20 per CD(R).
.MP3 should be burnt as Data CD's and I would expect loads more on the CDR. (Up to 100 ?) As above, burn at the slowest speed possible (1x to 4x) and go for quality makes of CDR. I like Verbs, Imation, TDK, etc. Also try to avoid paper type labels, if they come unstuck at the edges then it can damage the unit and fail to eject them properly. Labels also add to the CDR depth and that can cause problems. A good source of quality CDR's is http://svp.co.uk/products-list.php?cid=68 |
Thanks guys. I tried a CD that my girlfriend made for me on the way home from work today - it's entirely MP3 or WMA files, about 47 of them in total, and it seemed to play all of them fine except tracks 45 to 47 inclusive.
Looking at the underside of the disc, where you can see how much of it has been burnt onto, I'd say about half of it is full. Annoyingly I can't find the blank discs we were using at the moment, but I think they were TDK or some other named brand - not Tesco's own or something. I'll try making a disc with a slower burn rate but a full capacity of tracks (either audio or data/mp3/wma) and see what happens. I'll keep you posted. Cheers. |
A couple of things :
Try an original CD, dirt on the lense or misalignment tend to be more of a problem with home blown CDs. Don't mix file types on the same CD. Try the iffy CDs in your computer. |
So - Just so I get this right:-
I should burn MP3 files (or WMA but not both on one disc) onto discs as data files. Do I need a particular TYPE - as opposed to brand - of blank disc? I need to get a decent brand of blank disc. If burning AUDIO (music CD to blank CD) I should burn at the lowest available speed. If burning MP3/data files - does speed of burn make a difference? Sorry if I'm being a bit of dunce at this. My old car's CD player wouldn't play these MP3 discs at all, so it's new territory for me! |
If you use Music software to burn your CD it will no doubt burn it as an Audio CD and not MP3. With MP3 you just need to copy your files from your PC in the same format with folders etc. I can get about 10 Albums on an MP3 CD
#12 (permalink) |
I've had a mix of WMA and MP3s on the same CD with no problem
Whenever burning anything to CD or DVD that I'm going to use more than once or twice, I always go for slow speed. For the sake of the extra 10 mins or so to burn, vs having to reburn another one in the future... BUT quoting from the manual: In a disc compressed in WMA standard, the DRM (Digital Rights Management) file cannot be played. If the system finds the DRM file in a disc, you will see "CD FORMAT" in the display for a few seconds. The system searches for the next folder or file and plays it. Now - I have absol-blinking-loutely NO idea what that means It just rang a bell when you said it wouldn't play the last 3 WMA files, and thought it might be related |
Thanks guys.
Just made a disc of about 100 songs as .wma files. It's all the songs that I burnt as audio files onto about 5 normal CDs a couple of weeks ago. Will persevere and let you know! |
#14 (permalink) |
A few of points worth noting.
A car CD player is not like a home unit. The laser head is slightly further away from the CD as it has a built in tolerance for shock protection. The same thing applies to CD Walkman's. That gives car units a disadvantage. Point 2 is that CDR's in general are only about 70% as refelective as pressed CD's = disadvantage No 2. A third thing to watch this time of year is a CD brought from a warm house to a cold car. The CD can mist until the CD player warms up. A: = Yes - burn .MP3 files as 'data' otherwise your burning application will convert them to .CDA and you will typically only get about 20 per CD. Always ensure that the CDR's are 'finalized' which ensures more compatilbilty with standalone players. |
#15 (permalink) |
Kremmen - I suppose that your first and second points above might explain why it's the last couple of tracks that it isn't picking up properly. Interesting. I didn't know that about car CD players.
#16 (permalink) | |
#17 (permalink) |
Well, the WMA CD I made with about 100 tracks on it seems to be working alright. Very pleased with it in fact. Another neat feature of the Civ, this track listing thing, isn't it?
#18 (permalink) | |
The CD player in the Civic doesn't have the possibility to go online and fetch a license to play the file. Fortunately programs like FairUse4WM.exe exists and can remove the DRM from the file as long as you have a license to play the music on ther PC. |
#19 (permalink) |
re WMA / DRM
fab - cheers both, I think I understand that now!
cor blimey, wait till I tell my teenage daughter I know what DRM is |
#20 (permalink) | |
| Weird Crashes | pjelsworth | Any non Civic chat here please! | 2 | 20th August 2007 18:45 |
| Brakes rusting discs | chetan | Wheels, Tyres, Suspension and Brakes | 10 | 6th June 2007 12:52 |
| Brakes rear discs ?? | daiashthomas | Bugs, faults and irritations | 9 | 30th April 2007 15:58 |
| Built in CD WMA Discs | fishyuk | Ipods, MP3 Players and ICE | 42 | 21st December 2006 08:27 |
| Squeaks Weird Noise | geoff | Bugs, faults and irritations | 13 | 24th October 2006 13:35 |
