Technical Hardwiring Sat Nav - Civinfo
 4Likes
  • 1 Post By Farqui
  • 1 Post By Kremmen
  • 1 Post By Kremmen
  • 1 Post By chrizzlephaa
post #1 of 13 (permalink) Old 17th February 2017, 13:19 Thread Starter
Surge's Avatar
Car: 2005 2.2L CDTI Sport
Hardwiring Sat Nav
I'm going to wire my sat nav into the dash so that the cable is nice and tidy in the cabin.
I have already figured out how to wire it in principal, I just need to scotchlock onto an ignition live and ground under the dash.
I'm going to run the wire under the triangular top piece of the dash, and was thinking of tapping into the wires in the back of the stereo.
Does anybody know if there is an easy way to do this without stripping all the dash to get to the back of the radio?
Would it be possible to just remove the top piece and fish the wires out somewhere in the footwell and plug them in elsewhere?
Surge is offline
post #2 of 13 (permalink) Old 17th February 2017, 13:47
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Don't break into any wiring, use the Option Connector instead (Hobbyist section).
It's a much neater solution and allows for quick removal later if necessary.
Kremmen likes this.
Farqui is offline
post #3 of 13 (permalink) Old 17th February 2017, 14:16 Thread Starter
Surge's Avatar
I will be leaving a cigarette lighter down under the triangular piece of dash, so it should be very quick should I ever need to remove it. Is it possible to feed down to the option connector without dash removal?
Surge is offline
post #4 of 13 (permalink) Old 17th February 2017, 14:34
Farqui's Avatar
Not sure, though I suspect someone will be along shortly who has.
In the meantime, take a look at this/similar threads Guide:- How to install a Parrot MKI9200 into a Honda Civic / Type R
Farqui is offline
post #5 of 13 (permalink) Old 17th February 2017, 14:45
could use a fuse tap, and tap into the fuse box,
or just connect into the cig lighter
Cuprajake is offline
post #6 of 13 (permalink) Old 17th February 2017, 15:33 Thread Starter
Surge's Avatar
I know how I am going to wire it - I am going to put a cigarette lighter usb charger away under the dash, and just power the charger off ignition live and ground from the stereo.
My question was more about if there is a way to not remove the entire dash to do this
Surge is offline
post #7 of 13 (permalink) Old 17th February 2017, 19:23
Car: MY13 1.8 EX Auto
The best way is to get an option connector, as advised.
Then, as you say, wire in a power socket, which is exactly what I've done.
Farqui likes this.
Kremmen is offline
post #8 of 13 (permalink) Old 17th February 2017, 20:45 Thread Starter
Surge's Avatar
Are there any risks piggybacking the power from the head unit? As I don't have the option connector I would be reluctant to use it if possible to wire elsewhere - unless I can get the wires down to the footwell without removing the dash.
Surge is offline
post #9 of 13 (permalink) Old 17th February 2017, 20:53
Farqui's Avatar
What do you mean by taking the dash out, the full dash? Or just the radio/HU?
If the HU is out, then I don't think you will have any trouble running a cable to the footwells. Actually the center console will also be out, so you'll definitely have access to the footwells.
Farqui is offline
post #10 of 13 (permalink) Old 17th February 2017, 22:05
Lithium Flower
Grayfox's Avatar
Car: '11 Impreza R Special
you can easily get the wires down from the roof to the footwell.
My How to install a dashcam will show you this.
Grayfox is offline
post #11 of 13 (permalink) Old 17th February 2017, 22:07
Farqui's Avatar
Foxy, he doesn't want to fix his satnav at the top of the windscreen. Instead, on top of the dashboard, in the middle.
Farqui is offline
post #12 of 13 (permalink) Old 18th February 2017, 06:33
For £6 I would always wait and get an option connector.
Having done all 3 methods it's definately the best and safest.
1) Piggyback
2) Normal spade connector in option connector slot
3) Option connector
You can do it without removing the lower panel but you need to be a fit contorsionist and work upside down.
Farqui likes this.
Kremmen is offline
post #13 of 13 (permalink) Old 18th February 2017, 16:47
chrizzlephaa's Avatar
Car: '07 FK3
Personally, id use a piggyback fuse and run the cable up behind the dash to where the triangular trim is. You could also use the option connector and run the wire the same way. That's just me. I don't trust scotch locks as far as I could throw them.
Farqui likes this.
chrizzlephaa is offline
  Civinfo > 8th Generation Euro Honda Civic > Ipods, MP3 Players and ICE
Human Verification
How to fit OEM sat nav to non sat nav models Matt416 Type-R 4 5th October 2016 10:33
Add-on nav buy sat nav version or normal and buy double din sat nav marklola Electronics 6 15th April 2016 12:18
Head Unit Sat nav radio to a non sat nav car Drejc Ipods, MP3 Players and ICE 3 4th December 2014 12:50
