This thread is about: Bassworks and speaker upgrades..., it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; I've had the bassworks stuff added to my replacement car, and I was surprised to find the amp was fitted inside the dashboard. This means ...
Old 26th April 2006, 19:48   #1 (permalink)
basegreen's Avatar
I've had the bassworks stuff added to my replacement car, and I was surprised to find the amp was fitted inside the dashboard. This means you can't change the gain or crossover settings on the front of the amp without removing the entire dashboard! This seems a bit ridiculous to me.
Anyone got any clue about this?
Also - any ideas if fitting the bassworks sub speakers in the front is a supported configuration? My dealer fitted them the wrong way round, as I had a coaxial upgrade alongside it, and naturally it sounded absolutely appalling (as I assume the feed for the front speakers was for the rears and vice versa.
Any info at all on this would be appreciated.
Old 26th April 2006, 20:06   #2 (permalink)
Having installed a few systems... The coax drivers should be in the front and the subs in the rear. Anything else would sound very odd.
Once we know how to dismantle the dash, it will be no problem! I will be on to it soon.
Old 26th April 2006, 20:09   #3 (permalink)
basegreen's Avatar
Yeah, it sounded very odd indeed!
I was a bit wary of blowing a speaker or something when I tried it out.
Old 26th April 2006, 20:11   #4 (permalink)
basegreen's Avatar
Regarding the "service manual".
I had a very quick look at the system which has all the fitting instructions on it for the various accessories and upgrades. Big lists of things and full instructions on how to fit/debug them etc. Looked VERY useful.
It was web based... on some sort of intranet. I'm annoyed that I didn't pay enough attention to the name/URL.
Old 10th May 2006, 09:56   #5 (permalink)
Galaxy class starship
Copycat's Avatar
I was at a local dealership a while ago here in Finland and talked to one of the sales staff. He told me that the first Bassworks kit that they'd installed had been fitted so that the amp ended up inside the dashboard.
Only after the customer had informed them and questioned the reasoning behind it, had they realised that the amp had to be accessed to change the settings. Apparently they have since been installing them in the glovebox, which does make more sense.
If only the concert packs weren't so darn expensive...
Nearly £1000 installed.
Old 10th May 2006, 10:12   #6 (permalink)
basegreen's Avatar
The official instructions say inside the dash, and it gives "optimal" settings for the xover and gain settings.
except, theyre crap....
I cant decide whether to get it back in at the dealer and ask for a glovebox mounting...
help!
Old 11th May 2006, 14:01   #7 (permalink)
jah
Honda has a part no: 08B06-SMG-500 on www.honda-access.com that is used for installation in glove box for Cassette or IVES system..
Has anyone tried using this for mounting the amplifier or how can this be done...?
Also as Gissing writes has anyone any experience about mounting in the glove box, and would one often want to change the gain or crossover settings or could a "best setting" be found so that installation inside dashboard could be acceptable...?
jah is offline   Reply With Quote
Old 11th May 2006, 14:25   #8 (permalink)
basegreen's Avatar
I'm loathe to take it back in again, after all my fuss. It is sounding better with settings
BASS -1
TREBLE +2
and FRONT +2
BALANCE 0
At higher volumes the sub makes a nasty "I CANT TAKE IT" noise, which is because the gain/ xover is set too high. Needs to be subtle.
Old 13th May 2006, 21:07   #9 (permalink)
jah
So we can conclude: The concert pack could have sounded better, but with the correct settings its ok. And again when you have the correct settings, there would be no need to change settings and hence no need to let it take up room in the glove department...
Although not ideal, best position is behind the dashboard and with the settings that Gissing provided...
Similar Threads for: Bassworks and speaker upgrades...
Bassworks Speaker Upgrades Nighthaunt Ipods, MP3 Players and ICE 6 4th September 2007 19:34
Honda Performance Upgrades illegalhunter Type-R 9 11th July 2007 21:52
Bassworks Bassworks and speaker combinations hhuberla Ipods, MP3 Players and ICE 6 19th May 2007 17:36
Brake Rear Lights Upgrades? DanKo Lights 6 6th May 2007 14:34
Bulbs Type S bulb upgrades? tonyt Lights 3 19th April 2007 22:38
