Old 2nd May 2010, 15:39   #1 (permalink)
quango86's Avatar
Thanks given: 21
remote wire
looking for some help with my sounds I have fitted everything including my loc but have no idea where to put the remote wire is there a connection in the back of the head unit or somehwhere else??? thanks any help is very welcome
quango86 is offline   Reply With Quote
Old 2nd May 2010, 16:14   #2 (permalink)
Thanks given: 2
hello there
i used the 12v power socket in the boot for mine because this is only fed when the ignition is on. To connect it i just used a old 12v phone charger lead and connected the pos from this to the remote on my amp.
hope this helps.
jtpt2007 is offline   Reply With Quote
Old 2nd May 2010, 17:03   #3 (permalink)
cheekyweeboy's Avatar
Car: 2007 type r gt, NHB
Thanks given: 1
not what i would do this can cause a surge to the amplifier and could also draw power from the socket, i would use a remote feed from the head unit or use a remote generator
cheekyweeboy is offline   Reply With Quote
Old 2nd May 2010, 17:12   #4 (permalink)
Thanks given: 2
Re: remote wire
Amp remotes only draw milliamps anyway and the 12v socket is capable of about 10amp. If your using the original HU then there is no remote out anyway. Plus removing the hu isn't a quick job. Another reason I used this is so I can take my sub out quickly if I need the boot space.
Old 2nd May 2010, 17:16   #5 (permalink)
Strong in me The Force is
Koen's Avatar
Car: 2.2 NHB & 1.8 DBP TypeS
Thanks given: 9
I used the wire that sits next to the antenna wire at the back of the HU. I think it's the supply to the antenna amp that is placed somewhere in the back.
Any way, there is 12v on it when the HU is on, and it is at ground level when not. Perfect for remote.
K.
Old 2nd May 2010, 17:19   #6 (permalink)
Thanks given: 1
iv seen what can happen from remote wire surge the amplifire will go into protection and will remain usless if it gets a surge a remote is designed to come on grandualy after a head unit is on, you will hear a pop when you turn your car on and off if you surging the amplifier
i install custom sound systems for a living
Old 2nd May 2010, 17:19   #7 (permalink)
Thanks given: 1
K.
correct friend
Old 2nd May 2010, 20:41   #8 (permalink)
quango86's Avatar
Thanks given: 21
where would I get a generator for this??? I was planning on using a 12v supply with a switch wired into it for on/off???
Old 2nd May 2010, 20:43   #9 (permalink)
quango86's Avatar
Thanks given: 21
do you know what colour this wire is on the back of the head unit??? sounds like a job to take it apart ha thanks for your help guys
Old 2nd May 2010, 21:00   #10 (permalink)
Thanks given: 2
Re: remote wire
I have had mine wired this way for about 18 months now and had no problems. Who do you installing for? Only asking as i am after a patch lead for a non oem HU so I can still use the steering wheel buttons.
Old 2nd May 2010, 21:10   #11 (permalink)
Thanks given: 1
off hand no i dont no the colour of it but it can b found using a test light or a multi meter
looking for a remote wire now i have had my head unit out but its not something i have looked for but every radio has 1 to find this u will need a testing light turn your car on with the radio on do not unplug it u will bring on the airbag warning light anyway connect the testing light onto an earth like the chassie of the car or the metal on the radio then start testin the wires u will find there will 3 wires that will make the testing light light up 4 if your head lights are on the 3 wires u have that light up 2 will go off when u turn the car off and 1 will stay lit that is your main power wire turn the car back on and look that the other 2 turn the raidio off usin the power button on the front of the radio and u will see 1 of the wire now goes dead that will b your remote
if you use a multimeter then do the same as discribed but the meter will read 12 volts
as for a remote generator its a company called connects 2 that make them you will get them from halfords or any good supplyer
part number for it is "igni-gen"
Old 2nd May 2010, 21:20   #12 (permalink)
Thanks given: 1
i work for company called ray smiths car hifi
yes they are avilable company connects 2 makes them get it from halfords or any good supplyer part number "CTSHO002"
then you need a patch lead depending on make of radio
popular makes are
pioneer "ctpioneerlead"
sony "ctsonylead"
jvc "ctjvclead"
kenwood "ctkenwoodlead
but no 1 does alpine as far as i know
Old 2nd May 2010, 21:28   #13 (permalink)
Koen's Avatar
Thanks given: 9
It is the wire/connector in the red circle in the attached picture. If I remember well it's a black wire. Click here for more details on the HU connections.
I wouldn't use any +12v, like the plug in the back. Your amp would be powered even the HU is not on. And you don't know what state it is in when not active. (Open, ground, HiZ,...)
You could however make your own remote by making a signal detection circuit on one of the speaker outputs. That's pretty advanced electronics though. If you're interested, there is an example here.
K.
Old 2nd May 2010, 21:30   #14 (permalink)
quango86's Avatar
Thanks given: 21
popular makes are
sony "ctsonylead"
jvc "ctjvclead"
where abouts in fife are you I stay just outside glasgow and was looking for my parrot kit to be fitted aswell?
Old 2nd May 2010, 21:32   #15 (permalink)
Thanks given: 1
im in kirkcaldy mate
yeah parrot kits are easy enough done mate
so you are looking to change full head unit?
Old 2nd May 2010, 21:33   #16 (permalink)
quango86's Avatar
Thanks given: 21
thanks for all the help guys
Old 2nd May 2010, 21:37   #17 (permalink)
Thanks given: 1
K.
well found mate spot on yes that will work
Old 2nd May 2010, 21:49   #18 (permalink)
Thanks given: 1
hi quango86 if yor are looking for me to do this or any work for you please pm me and i will give you my number
thanks
Old 4th May 2010, 12:46   #19 (permalink)
VtecAndy's Avatar
Car: Bronze CTR
Thanks given: 2
I just wired my subwoofer amp up yesterday using the rear power outlet wire as a remote turn on and it works fine no pops etc.
Could I not wire and inline fuse or something in the remote wire, or might the amp be ok if it has a protection mode?
Anything must be easier than removing HU and locating/trailing a new cable
VtecAndy is offline   Reply With Quote
Old 4th May 2010, 13:02   #20 (permalink)
Koen's Avatar
Thanks given: 9
Adding a fuse would be a good idea indeed in this config. And put a diode in series with the fuse, so that, in whatever odd case, your amp is protected against reversed current from the remote input.
As the amp only draws milli-amps from the remote pin, use the smallest fuse possible. (small in terms of rating.)
Mind you that your amp will always be on when your car is running, not only when the HU is on.
K.
Similar Threads for: remote wire
Electrics Radio remote wire for amp ljubisa86 Electronics 6 7th March 2010 21:33
Other Drive by Wire civ-boy Engines and Transmission 2 25th November 2009 00:25
Tech Drive by Wire Minkster Engines and Transmission 11 24th June 2007 15:03
Amplifier How to wire an amp? Silver6 Ipods, MP3 Players and ICE 4 30th January 2007 20:15
Tech Drive by wire CavOK Engines and Transmission 1 25th April 2006 03:14
