| This thread is about: changing the radio, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; So does anyone know of a RHD version of this facia plate? I've had a rake around but as usual there is nothing for this ... | ||
#22 (permalink) | |
If every car was exactly the same they would be very boring. |
#23 (permalink) |
pioneer definitly do one, the part no from them is 12.301130-08 and its avaiable in two colours, anthracite/ taupe and piano black(12.301130-07). i havent had a visual from them yet but hopefully this is the correct part.
#24 (permalink) | |
#25 (permalink) |
if you do a search for facia you will find a post about a right hand drive facia plate that honda already make the part numbers and pictures are in the post hope this helps
#26 (permalink) |
If replacing the radio, what about controls on the steering wheel ? What about display on the main screen of the car ? How do you set up the clock then ?
#27 (permalink) | |
Afterall doesn't the base spec come without at CD player? Does this mean they don't get a clock or temperature display either? I doubt it. There must be a little circuit board that controls these things. |
#29 (permalink) |
The base model came without stero at the start and had a blanking panel instead - you can get these from the stealer and then mod to take your HU. Think it may even have been preped to be modified for a 1/2 dim unit. Speak to the stealer - he'll go through the parts catalogue with you.
As to the radio receiption 3rd honda mentions, it is related to the glass antena - same problem in the Accord - certain area it's crap - nothing to do with the head unit (It's guite a good Panasonic unit actualy) just a bad ariel design for the UK's coverage. Wife's Jazz with a bee sting has no problem in the same areas. So if you want to improve it, fit an antena. But I agree with baillieswells. You can't appreciate the quality of a good system in a car with out cranking it up to an un-socialble level. And if you do well.... you've got your answer. |
#32 (permalink) |
The Panasonic head unit may be a reasonable quality but it is far too limited.
I think I may have discovered why my signals been so bad on radio reception recently. I had my Bluetooth GPS plugged into the rear socket and sitting in the middle of the parcel shelf. The electrical interference from the power cable must have effected the signal. Similar to the heated windscreen problem that some folk have reported. |
#33 (permalink) |
Same symptoms !
I noticed that when the DVD player of my boy was connected to the rear DC supply, the radio reception was particulary poor .... any advice ? |
#34 (permalink) |
I have my snooper (on the dash) powered by an extention cord from the rear power socket. Will test disconnecting to see if there is a differance.
What route does the ariel cable take from the HU to the rear window? |
| changing the grill | BeefBurga | Cleaning and Styling | 11 | 13th October 2007 13:26 |
| Head Changing lights over for European travel | sibo | Lights | 1 | 18th August 2007 10:06 |
| Is it worth changing to the type R? | sonicm | Buying, Dealers and Servicing | 6 | 25th July 2007 21:16 |
| Dealers Changing Dealerships | emmaloula | Bugs, faults and irritations | 3 | 21st February 2007 14:31 |
| Winter Changing the tyres - any pointers? | Skaven252 | Wheels, Tyres, Suspension and Brakes | 15 | 7th November 2006 10:33 |
