Old 8th May 2012, 20:23   #1 (permalink)
living the dream
Brungle's Avatar
Car: 2006 1.8 EX, Milano
Thanks given: 187
Remove glovebox without removing centre dash?
Trying to install bogs video input box and was wondering if it's possible to remove the glove box without taking the gear surround section out? It took me a while when I was installing my dension and I'd love to avoid it if possible.
I've tried giving it some force but can't get it out, I'm sure I read on here someone else had managed it!
Cheers
Brungle is offline   Reply With Quote
Old 8th May 2012, 20:51   #2 (permalink)
Pheasant Plucker
Fr0d's Avatar
Car: 2006 2.2 EX, NHB
Thanks given: 56
Not sure it's possible, as I tried a good while back, trying to get to the back of the SatNav unit to connect my reverse camera harness. It will twist out so far, then gets stuck at the centre console end. No idea why you want it out, but if it's for connecting the above, you can just about do it in situ, if your nimble fingered.
Just do it the tried and tested way (centre console out) - its quite easy and you shouldn't break any clips if you're careful.
Unless someone else knows otherwise?
Fr0d is offline   Reply With Quote
Thanks to Fr0d from:
Old 8th May 2012, 21:00   #3 (permalink)
living the dream
Brungle's Avatar
Thanks given: 187
Thanks, it's not just for the video in cable, I need it out so I can solder Bogs Video switcher box (it needs a satnav wire cutting and soldering to his box)
Looks like I'll go down the proper route then
Old 8th May 2012, 21:17   #4 (permalink)
corasdad's Avatar
Thanks given: 8
you can but you break the right hand side its not worth it for the xtra ten mins to remove the center
corasdad is offline   Reply With Quote
Old 8th May 2012, 22:45   #5 (permalink)
living the dream
Brungle's Avatar
Thanks given: 187
Thanks I shouldn't be so lazy, it only took an extra 10 mins as you say.
too dark now to finish the job too. Will continue tomorrow.
Similar Threads for: Remove glovebox without removing centre dash?
Head Unit Fitting Xcarlink - absolutely neccessary to remove dash? Type 666 Ipods, MP3 Players and ICE 3 10th January 2012 00:40
Other What is the sensor in the centre of the dash? borse2010 Electronics 16 23rd March 2011 13:58
Trim How to remove dash display facia front panel? wellzie74 Bugs, faults and irritations 2 1st March 2011 09:19
hard to remove white spot on dash Jeroen1000 Cleaning 12 4th November 2008 21:23
Removing centre console to clean? generationgav Cleaning 1 17th January 2007 12:22
