![]() Car: 2009 2.2 Type S i-CTDi Black
Thanks given: 143
I currently have the existing factory headunit & speakers installed in my Civic Type S 3 Door. I would like to upgrade my system so it sounds a bit better quality. Now I understand you can only get so much of an improvement with the existing factory kit but I already have an Xcarlink device and a Review mirror monitor which I play music videos on setup and plugged into the unit so I don't want to start ripping it all out.
I am a beginner at car audio but I enjoy taking on car DIY projects. This is what I was going to do. 1. Remove old factory speakers. 2. Install sound proofing around speaker areas etc.. front and back. 3. Then decide on amplifier and speakers I would quite like something similar to: - For the fronts I would quite like something similar to Infinity Reference 6510CS components which Pottsy suggested and used in his how to guide. - For the Rear speakers I would quite like something similar to 6.5” coaxial Speakers Infinity Kappa 62.7i as Munro in his how to guide suggested and used them. But if possible with me being a beginner I may be better getting the exact size replacements. I don't want to spend to much money on my system but I do want fairly good quality sound and I would like the ability to add a sub at any stage in the future if I wanted to. So the questions are:- Q. Would I be able to use the following amplifier with my existing system and the updated speakers or similar suggested above? Auna AMP-CH04 Car Amplifier 4 Channel 2800W Hifi System
Q. If I can use the above amplifier would I then also need to use a LOC (line out converter)? Q. Also with the kit above would I also still be able to add a sub in the future if I need/wanted to? Do you think the above will be a decent improvement to my existing system and am I on the right lines and if so any suggestions/comments or answers to the above questions are much appreciated as I really am a beginner when it comes to car audio installs. Thanks in advance. Peter. Last edited by CTR-PeteLFS; 23rd May 2012 at 10:58. |
![]() Join Date: 10th August 2006
Yes, you can use that amplifier.
No, you don't need LOC (as amplifier has 'high' input). Yes, you can add sub in future. You will need new amp for sub though. Lastly.. 380W RMS for mid/high speakers (aka non-sub speakers) is a LOT. Actually WAY too much. |
Thanks to Nick7 from:
#3 (permalink) | |
Thanks given: 143
sorry for being a beginner but what exactly do you mean could this cause damage too speakers or do you mean it's just wasted as it too powerful? Hope you know what I am trying to say. May be I should look for a different amp if I would need to upgrade if I also added a sub? Thanks. |
Well, if you crank it up, you'll most likely blow most of speakers with it
To put it into perspective, in my old car I had front&rear speakers connected to HU with LPF. Sub was on separate amplifier. I did manage to blow fuse for sub (30A one) while sound was still OK on stock HU (which is max 25W per channel... but even actually less than that). Also as an example: tweeters take only few W of power before you'll fry them. My point is only this: sub takes much more power to generate louder effect due to it needing to move much more air mass. Midrange&highs require quite a lot less power for high volume. Anything above 100W RMS for midrange/highs is VERY loud (can actually hurt your hearing). |
Thanks given: 143
Thanks Nick7, I think I understand the problem is I am a beginner so it takes a bit to learn lol.
Sorry to ask you lots of questions but would I be better getting something like this then and this would still be using the speakers I mentioned in my first post. I hope I have read this right but this amp produces 4x 30W RMS so would this be a safer option. Then I can forget about a sub because thinking about it I would like good quality sound from my speakers but I don't really want to loose much space in the boot with a big sub. I really appreciate it if you could help, Thanks. |
Similar Threads for: Upgrade existing factory unit questions & advice welcome
| Factory EX Head Unit | AntVAG | Items wanted | 4 | 8th December 2010 23:35 |
| Brakes What to upgrade to from standard factory fitted? | borse2010 | Wheels, Tyres, Suspension and Brakes | 1 | 10th November 2010 17:41 |
| Head Unit Sub & Amp connection to factory head unit | Spartan13 | Ipods, MP3 Players and ICE | 1 | 25th July 2010 10:34 |
| New CTR!!!! - But Questions Existing! | DPG87 | Type-R | 16 | 6th February 2010 02:02 |
| 18" orginial factory upgrade alloys | dannypunto | Items for sale | 13 | 8th March 2009 17:17 |
