| This thread is about: Brand of CD used for Civic MP3 CD player?, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; Hi What brand of CDs do you all use for the Civics MP3 player? I have just tried Verbatim (1 burned at 4x speed, and ... | ||
Hi
What brand of CDs do you all use for the Civics MP3 player? I have just tried Verbatim (1 burned at 4x speed, and one burned at 24x speed) and neither worked... The CD player just kept spinning when I inserted it. Wondered what brand you guys had had success with? Cheers |
have 3 different types of no-name discs.
two of them bought at my local grocery shop... they work fine. the latest one is called "platinum" do the discs work in other players? Last edited by FWH; 27th August 2007 at 20:06. Reason: F7 |
I suppose the Civic plays normal CDs fine?
Are they CD-RW discs? These are a problem in some readers, haven´t tried this in the Civic. Did you verifiy the discs after burn? What burning software? I use Nero and that works fine. I was thinking if there may be a setting with the finalising or something. |
Vivid Blue Rocks!!!
Did you actually burn them as data cd's??
Did you finalise the disc?? Do normal cd's that you burn work ok in the Civic?? I use Datawrite Titanium CD-R discs, they work fine as data and music cd's. Hope you can get it working soon |
#6 (permalink) | |
Yes I did
I think so, although in WinXP which I'm not sure whether it finalises or not... Yes they do, have tried a burned audio (not data) CD and that works, also an original CD works as well. Just having no luck with data CDs. Quote:
Cheers, I'm going to load on Nero onto a PC and try that next, and also try a different brand of CD... |
important thing: in the nero use "Disc at once"!!!! instead of "Trak at once" option. I burned a disc in track at once mode... it was my fault but then I corrected it and everything was fine...
I use Verbatim printable CD-R for my MP3, have about 20 now and have had no problem what so ever.
Usually burn at 34X using Nero 6 then print picture of car etc with Epson Print CD program. I burn a lot of CD's and DVD's and find the Verbatim brand excellent with no coasters YET!!!! |
#12 (permalink) |
I'm using Verbs, the printable ones, and all systems go at this end.
I suspect the 'closing' or 'finalising' of the CDR as mentioned above is the answer. |
Have tried it on another computer using Nero, finalising the disc and it worked great!
So I know the CD player is ok, have taken some Philips CDs and am gonna stick Nero on and try it again with my own music! Cheers guys |
#14 (permalink) |
OK so end result - its working perfectly
Combination of using Nero, and also not using WMA, but MP3... Just tried using MP3 instead to rule that out, and worked. Guess it had encoded to WMA funny, shame as WMA is about half the size of MP3! Oh well, glad its all working now |
#15 (permalink) |
Smell My Cheese!
Have used Verbs, Phillips and even W H Smith, all burnt using "data disc" and Nero at 52x, never had a problem. Once used Media Player to make an MP3 CD and that was fine too.
#16 (permalink) | |
Vivid Blue Rocks!!!
But the more files you place on the disc, the longer it takes to load, and with MP3 files it takes long enough Anyway, 11 albums on 1 disc is pretty good. |
#18 (permalink) | |
WMA should work OK, according to the Civic bible/manual, but I've always used MP3. I use a bitrate that returns about 7 albums per CD and I consider it to be better than having an autochanger as they can be troublesome depending on where they are located. |
| FS: Brand new Brodit phone holder for 06 Civic onwards | Dream Weaver | For sale and Wanted | 6 | 22nd May 2008 11:46 |
| Built in CD 1.8 ES CD Player - MP3 Player ???? | andymc63 | Ipods, MP3 Players and ICE | 21 | 3rd December 2007 21:02 |
| Brand New NHB Honda Civic 1.8 SE with Leather | nellz_bassettshonda | Bassetts Honda | 3 | 30th September 2007 21:42 |
| My car Pickin my brand new civic up tomorrow.. | jofawe | Buying, Dealers and Servicing | 17 | 17th May 2007 16:31 |
| Brakes Faulty Hand Brake on Brand New Civic | padre | Wheels, Tyres, Suspension and Brakes | 7 | 9th June 2006 22:23 |
