Old 18th June 2012, 22:17   #1 (permalink)
easiest way to connect loc to rear speakers
Hi there,
Ibe nearly finished installing my vibe active sub,just trying to find out the easiest way of connecting to rear left speaker,rather than having to.cut into the heavily insulated loom inside centre trim.any advice appreciated
Cheers
A.Regan is offline   Reply With Quote
Old 18th June 2012, 22:59   #2 (permalink)
CTR-PeteLFS's Avatar
Car: 2009 2.2 Type S i-CTDi Black
Thanks given: 143
Eco display Eco display
I am not sure if I am on the same wave length A.Regan but getting access to the rear speakers is far more easier than the fronts. Once you remove the arm rest in the rear. Then you only have the two wires to the speaker to attach on the left and the same on the right. That is probably the easiest method instead of cutting the main headunit wiring harness.
This guide will help you remove it which is written by Munro which is really good. I Installed my LOC in the bottom by the seatbelt in a hidden area.
Rear Speakers - Replacement with Coaxials (3 Door)
Other civinfo members may be able to give better help as I am not a audio expert I just like learning and doing it DIY style.
Pete, Goodluck.
CTR-PeteLFS is offline   Reply With Quote
Old 19th June 2012, 09:09   #3 (permalink)
Thumbs up
Thanks for the advice ctr.did think there must be an easier way.so I can connect to the speaker wires without having to channel into the rear door?as not sure ive got enough wire on my loc.
Should I be able to find the two speaker cable under the trim where the seat belt is?
Cheers
Old 19th June 2012, 09:46   #4 (permalink)
Thanks given: 143
Cheers
You will find it better if you take the rear armrest off. You can access the bottom of the armrest were the seatbelt is and use that little space to place your LOC. As the speaker wire (2 cables) are better accessed behind the armrest as the wire goes through a hole into the back of the speaker. You may be able to see this in Munro's examples. I am sorry my description was probably not great. The speaker wire is hooked up before it goes through the hole to attach to the speaker if you unhook it then you will hopefully have enough wire to reach your LOC if you position it in the little space next to the seat belt which is below the armrest. Hope I have explained this ok. If you want I will try and take a picture of my installed LOC.
Pete.
Old 19th June 2012, 19:57   #5 (permalink)
Thumbs up
Ok cheers Pete.i reckon you must have a 3 door,as ive got a 5 door es and my back speaker set up is slightly different set up.i probably didnt explain to well.as I said I would have to feed the loc into the back of the door.have u got any ideas about connecting up to the speakers at an easier point?
Cheers
Adam
Old 19th June 2012, 22:36   #6 (permalink)
Thanks given: 143
No worrys regan, sorry I just get carried away thinking everyone has a 3 door lol. I will have to have a think about that one. I suppose it is gonna have to be the method you suggested originally unless you can get to the wire at the bottom of the middle pilar between the front door and the rear.
I hope another member who has fitted a LOC in a 5 door maybe able to help as I have also had a look at this website
Original Honda Car Parts from Lings - Model Selection
which may help. But I am not 100% sure about your exact model but if you configure it you may be able to find the location of the wiring harness in some of the pictures.
Hope you have success and if you figure out a way post it on your thread as I am interested how to do it know. Goodluck.
Pete.
Old 19th June 2012, 23:52   #7 (permalink)
Type EX,A guy called Mark
markvirgo's Avatar
Car: 2006 1.8, Alabaster Silver
Thanks given: 95
See this how to How to install a Pioneer sub woofer
markvirgo is offline   Reply With Quote
Old 20th June 2012, 23:25   #8 (permalink)
Thumbs up
Cheers for the advice lads.great help.much appreciated.
Similar Threads for: easiest way to connect loc to rear speakers
My install Which rear speakers? KizZamP- Ipods, MP3 Players and ICE 15 14th May 2012 12:01
Speakers Rear Speakers (5 dr) Palindrome Ipods, MP3 Players and ICE 9 8th March 2010 14:44
Speakers Rear Speakers MattJ10 Ipods, MP3 Players and ICE 4 17th August 2009 11:41
Speakers Easiest way to connect amp to front speakers? Viol8r Ipods, MP3 Players and ICE 0 23rd June 2009 12:28
Speakers Rear Speakers - Help please. BlacknBlue Ipods, MP3 Players and ICE 6 9th August 2006 20:26
