This thread is about: My ICE (lot's of pics), it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; Decided too build new sound system as the original speakers sounds like **** Have been living in the garage for the past week now and ...
Old 1st September 2007, 13:43   #1 (permalink)
Have been living in the garage for the past week now and here is the result...
ICE that's going into the spaceship
1x Helix 1000.2 - 2x1132w @1ohm
1x Ground Zero GZNW 12 SPL 4500W RMS 2 x 1 ohm
2x Earthquake 1.5 Fahrads 2000W with display
2x Digital Design C 6.5" with tweeter
kskanoy is offline   Reply With Quote
Old 1st September 2007, 13:53   #2 (permalink)
Cap
Cap's Avatar
Sweet kskanoy! Hope for some pictures when insalled! What did you put in the back doors? And how big is your sub?
Cheers from fellow Norweigian
Cap is offline   Reply With Quote
Old 1st September 2007, 14:14   #3 (permalink)
mounting
Getting the power cable from the front to the back was quite a challenge. It is really tight space!
My friend helping me with his small tools :P
Thank's too the HOW TO guide here at civinfo changing the speakers / tweeters went fine
The beauty/beast that's going in...
The box, it is small because it only needs 37 litres with the magnet out.
First test
Cutting out a copy for the bottom plate
And it fitted perfectly!
And with the sub
Fitting of the capacitors
Plexiglas for protection
Preview and testing in the car
Time for some clothing. You can see here that i used racing grill for the capacitors. When it's mounted it willl be 2x30cm blue led stick that will light under it.
Almost there now!
Old 1st September 2007, 14:17   #4 (permalink)
Final result
At night
Old 1st September 2007, 14:20   #5 (permalink)
Pics up now
Haven't change the back doors yet, only in the front. The sub is 12" and 5000W, 4500W in RMS
Old 1st September 2007, 14:35   #6 (permalink)
jayt43's Avatar
Very nice! The capacitors make it look like the sort of thing James Bond might have to diffuse to save the world!
And, best of all, you've still got room for the shopping!
jayt43 is offline   Reply With Quote
Old 1st September 2007, 14:59   #7 (permalink)
Cap
Cap's Avatar
Originally Posted by kskanoy View Post
Pics up now
Nice, bet its a good sound! Hope you dont usually carry to much luggage
Old 1st September 2007, 15:06   #8 (permalink)
Bungle's Avatar
Practicality is not high on your list, then
Old 1st September 2007, 15:10   #9 (permalink)
The engine went from 1500 rpm to 1300 rpm when i crank the volume up...I hoped that capacitors would fix that but I think they are not big enough (3fahrad together)
And i'm afraid the front window will be loose after a while, it vibrate quite heavily.
Haven't been on db drag yet, but i suppose around 140-141 desibel
Practicality? well, civic has a good solution for the backseat, just bring them up and you get a quite big "trunk" Have to offer something for sound
Old 1st September 2007, 15:25   #10 (permalink)
Cap
Cap's Avatar
That sounds like a really LOUD stero!
Old 1st September 2007, 15:56   #11 (permalink)
I would miss the boot space too much, but it does look like an impressive set up
Old 1st September 2007, 15:56   #12 (permalink)
TYPE R GT (R-8130)
wow you will need a hearing aid after a couple of weeks listening to the system
Old 1st September 2007, 16:35   #13 (permalink)
Bog
Bog's Avatar
F*** me that's one 'ell of a speaker, that will shake your teeth loose!!
Nice setup!
Old 1st September 2007, 16:44   #14 (permalink)
elfa7's Avatar
I don't think LOUD music should be played, whilst the vehicle is being driven. Just a personal thing.
Old 1st September 2007, 20:09   #15 (permalink)
The Phantom's Avatar
Nice install.
Gonna be bugger the next time you got to Ikea though.
The Phantom is offline   Reply With Quote
Old 1st September 2007, 20:34   #16 (permalink)
gray52's Avatar
if you back shocks dont rattle, there sure will now!!! nice install.
Old 1st September 2007, 21:00   #17 (permalink)
Cap
Cap's Avatar
Hes only playing loud when hes got his ride inside the livingroom
Old 2nd September 2007, 12:26   #18 (permalink)
Civic Mad!
Wow !!!!!
m4rky is offline   Reply With Quote
Old 23rd October 2007, 10:59   #19 (permalink)
Koen's Avatar
Haven't been on db drag yet, but I suppose around 140-141 desibel
Capacitors only help to flatten the current-peaks you draw from the battery, they are not "extra batteries". Bigger capacitors will definately not solve your rpm-problem. (e.g. They do help to solve the problem of flickering interior lights when cranking it hard.)
Installing an extra battery in the back might help, though. The extra battery loads when you use the stereo at "normal" volumes. That's most of the time, rof your ears sake. When requiring more power, the second battery will help to provide the extra current.
K.
Old 25th October 2007, 23:28   #20 (permalink)
Swindon Japster's Avatar
I always like to see the boundaries pushed. Take on board practicality, but good job!
Swindon Japster is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/ipods-mp3-players-ice/7832-my-ice-lots-pics.html
melhusgatebil.no :: Vis Temaet - Prosjekt Civic 07 This thread Refback 4th November 2007 21:23
Similar Threads for: My ICE (lot's of pics)
Galaxy 1st Pics mickjim Gallery 6 28th May 2008 03:20
out with the old (EP3) in with the new (FN2) pics norton Type-R 13 7th October 2007 00:26
Black Some pics. rammos Gallery 7 14th September 2007 13:38
enough R GT, any R pics? Hothatcher Type-R 10 20th March 2007 20:10
Silver New Pics. AubreyS Gallery 5 31st August 2006 00:31
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
