This thread is about: Anyone found a way around changing the head unit?, it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; I would have changed the HU a long time ago if it were possible, miss the Alpine ipod set up I had in my Megane. ...
Old 9th September 2007, 02:43   #21 (permalink)
I would have changed the HU a long time ago if it were possible, miss the Alpine ipod set up I had in my Megane. Great as the EX dash is, it's just too integrated. If that makes sense?
czechplastik is online now   Reply With Quote
Old 9th September 2007, 12:06   #22 (permalink)
yer lol. i dont mind too much abt the sat nav like i said, i just dont want to lose out on any other things such as seats, colour coding etc
ImmyG is offline   Reply With Quote
Old 9th September 2007, 14:53   #23 (permalink)
Sorry, but what does that have to do with the HU?
Colour coding is a non-Honda option (although some dealers do it) and the seats are the same in EX and non-EX.
Are you refering to leather only being an option on some equipment levels? You may be rights there, not sure if you can get leather without satnav -as we canīt get leather at all over here.
Old 9th September 2007, 16:11   #24 (permalink)
Leather and glass roof are standard on ES models (which does not come with NAV) and can be specified on any spec level.
Old 9th September 2007, 19:38   #25 (permalink)
lol sorry i havent done that much research into it, its just the some cars have different equipment with different models etc e.g. golf gt tdi as opposed to the normal tdi etc. (sorry if i began to confuse u aswel lol)
Old 10th September 2007, 13:10   #26 (permalink)
The biggest problem with replacing the HU in the Civ is that you can't actually see it in the first place.
Therefore, to create a hole big enough to fit an aftermarket HU into the dash you end up loosing room for some (or all!) of the controls.
For the SE, ES and Sport models (ie non Sat Nav), this is not too much of a problem, as the controls you loose are for the radio / CD
However, for the EX, there are also controls for the Sat Nav, which would then have nowhere to go
This is with the current double din replacement dash - which is the dash from the now discontinued base level 'S' spec (NOTE - NOT the 'Type S', just 'S')
And as yet, there doesn't seem to be a single din version, although there is a thread investigating that option.
Old 10th September 2007, 14:49   #27 (permalink)
The Phantom's Avatar
Has anyone looked at fitting a HU in the small cubby in the centre console yet?
Went out to look at this at the weekend, and if there is enough room behind the console, then an HU could be fitted in here quite easily. Granted you would loose steering wheel control (until the aftermarket can provide a link) but it would mean you could leave the standard HU insitu, keeping clock & temp & SRS functions, and just redirect the speaker output to the HU below.
A cage would be needed to replace the cubby hole and allow rear fitting of the HU but the gap in the centre console can easily accommodate a removable face plate.
I'm gonna have a closer look this weekend, and will report back.
The Phantom is offline   Reply With Quote
Old 10th September 2007, 15:02   #28 (permalink)
thanks, btw can u not use the steering wheel controls on some headunits which have the integration built into it?
Old 10th September 2007, 17:35   #29 (permalink)
I had given thought to fitting one in the arm rest cubby.
Old 10th September 2007, 18:12   #30 (permalink)
That would be ok if you had remote access and the ability to transfer data to the heads up display, most of which we don't have yet.
The little silver-doored cubby is in a perfect position for reach and display, hence my reasoning for placing a secondary HU there.
Sod's Law dictates though, that there won't be enough room in the back to fit the HU. Just wait and see.
Old 10th September 2007, 22:46   #31 (permalink)
in the new accord people have done something like that. keeping the original screen in there while installing an aftermarket head unit in one of the cubbys while still retaining another slot (as a double din type adaptor)
Old 11th September 2007, 12:35   #32 (permalink)
Civic's cubby looks too small for a double din, unfortunately.
I'm thing of two options.
First is a single din plus the spare space used as a wee cubby still.
Or more likely, a single din with a dock for my ipod. Gonna test fit this weekend with my Kenwood HU before looking into buying an Alpine IDA X001 Media Player and new 80Gb i-Pod.
This is all purely hypothetical but if it does work I'll post up a how to and what's needed guide.
Old 11th September 2007, 12:52   #33 (permalink)
ok cool. looking forward to it
Old 11th September 2007, 13:43   #34 (permalink)
in the links given some posts above (the second one "New Ice Installed") you can clearly see that there is enough space for a 2-Din installation.
vatigoal is offline   Reply With Quote
Similar Threads for: Anyone found a way around changing the head unit?
Head Unit Aux head unit ITSRICKSCIVIC Ipods, MP3 Players and ICE 1 12th July 2007 10:45
Head Unit Head Unit replacement chetan Ipods, MP3 Players and ICE 5 28th May 2007 19:43
Head Unit Double Din Head Unit! Someone help please.. DanKo Ipods, MP3 Players and ICE 15 27th April 2007 22:48
Head Unit Alpine's New iPod Head Unit. The Phantom Ipods, MP3 Players and ICE 0 18th April 2007 22:28
Little compartment under Head unit ? daiashthomas Cleaning and Styling 1 15th October 2006 19:06
