This thread is about: Single Din Conversion .., it's in Ipods, MP3 Players and ICE at the Honda Civic forum Civinfo; If there was a single din conversion available for the new civic would people be interested, even if the cost was a little more than ...
Old 6th September 2007, 14:04   #1 (permalink)
If there was a single din conversion available for the new civic would people be interested, even if the cost was a little more than others - £ 152.75 to be precise ?
SteveTDCi is offline   Reply With Quote
Old 6th September 2007, 15:06   #2 (permalink)
£152.75!!! is that just to convert the dash or does it include a headunit
Old 6th September 2007, 15:54   #3 (permalink)
The Phantom's Avatar
That's a bit steep.
Will it allow full use of the display for temp /time / tracklistings from aftermarket outputs and adjustment for the clock?
If not then probably not at that price.
The Phantom is offline   Reply With Quote
Old 6th September 2007, 15:59   #4 (permalink)
Thats just the faceplate, not sure on the connection cables, i'll find out.
Old 6th September 2007, 16:00   #5 (permalink)
Thats just the faceplate, not sure on the connection cables, i'll find out. I thought the Honda one was more expensive ?
Old 6th September 2007, 16:02   #6 (permalink)
I thought that the Civ one was around £75 plus vat.
Someone posted a parts list with prices in one of the other threads I'm sure.
Headunit facia????
Post #35 & 40.
£75 for the facia, £30 for the pocket. Plus vat. Plus fitting came to £177 IIRC.
Old 6th September 2007, 18:42   #7 (permalink)
Thanks, i'd miss read that post.
Old 6th September 2007, 20:04   #8 (permalink)
any pics of this fitted
Old 10th September 2007, 13:09   #9 (permalink)
would it be in a Sat Nav dash, or non Sat Nav?
(Sat Nav version has more buttons...)
Old 26th October 2007, 01:05   1 links from elsewhere to this Post. Click to view. #10 (permalink)
p64
Ezermester
p64's Avatar
This is my aftermarket headunit instalation. In my head at the moment.
Instead of the old volume button - a hole pocket for eg. a pen...
It is an Alpine DVD unit, the plan is to get a steering wheel control interface, hacking to the LCD, Alpine bluetooth system, relocatind OEM HU. Any known solutions to the steering buttons? I believe that americans have a solution from PAC and I think the steering wheel is identical.
Comments, solutions...?
Greetings, Andrej
p64 is offline   Reply With Quote
Old 26th October 2007, 08:45   #11 (permalink)
you would be a star amongst owners if you manage it...
step 1 - find a single DIN dashboard...
Old 26th October 2007, 09:44   #12 (permalink)
p64
Ezermester
p64's Avatar
I would do this with the existing dash. If I could get my hands on another piece, so the car would be drivable in the meantime, while I do it.
I did something similar, only much less destructive on my previous Civic. It is all handwork.
Andrej
Old 26th October 2007, 16:20   #13 (permalink)
Not sure how easy it would be to clear out the stuff behind the dash to get a new HU in on an EX.
Old 28th October 2007, 01:30   #14 (permalink)
p64
Ezermester
p64's Avatar
Nearly impossible. Today I disassembled everything and there is a single PCB with all the buttons, for radio and navigation behind the panel. The only solution would be to relocate the headunit with the PCB and use the lower part of an another one connected only for illumination and controls of the nav part. Not worth it. (At the moment)
A lot of effort from Honda to put everythyng together and still make it full of flaws.
The list of things that really annoy me:
-RDS not functioning properly
-MP3 folders taking ages to read
-rubbish sound, despite the infinitys
-unable to dial from the mobile to transfer to HFT
-no nav coverage for my country
So, I will install a Blaupunkt amplifier and Parrot ck3000 evolution BT kit instead of OEM. Hope I will be able to use the OEM wiring for muting and sound input. Will keep you posted.
Some pistures of the headunit disassembled:
Picasa Web Albums - Andrej - Honda Civic E...
Andrej
Old 30th October 2007, 07:38   #15 (permalink)
Originally Posted by p64 View Post
Nearly impossible.
But not impossible, it can be done and is has been done.
If people are desperate, buy the double DIN fascia, get the work done I had done, and use the other slot as a cubby hole.
Rizlam is offline   Reply With Quote
Old 30th October 2007, 09:32   #16 (permalink)
p64
Ezermester
p64's Avatar
I meant retaining the stock satnav. I believe it hasn't been done yet. Am I right?
Andrej
Old 30th October 2007, 13:37   #17 (permalink)
I think so. But it shouldn't be logistically difficult as any h/u output will be an aux input. The physical difficulty is in where to site the controls. For my H/U swap I have put the existing H/U in the boot.
LinkBack to this Thread: http://www.civinfo.com/forum/ipods-mp3-players-ice/7963-single-din-conversion.html
ICE - Stereo Upgrade / Sat Nav - HondaTech Australia Forums Post #10 Refback 30th October 2007 05:27
Similar Threads for: Single Din Conversion ..
Help with EG6 K20 conversion gazrawly Previous Civics 1 6th May 2007 13:58
Interior Single Courtesy Light philosoma Lights 1 13th April 2007 23:09
LPG Conversion? Bardley General Discussion 14 3rd December 2006 18:13
