| This thread is about: Boot panel clip - can you help?, it's in John Pease Honda at the Honda Civic forum Civinfo; I recently fitted parking sensors to my car, and when I took the interior boot panel off, discovered that a plastic clip was bent and ... | ||
I recently fitted parking sensors to my car, and when I took the interior boot panel off, discovered that a plastic clip was bent and that explained why the panel appeared to have been 'popping out' and not fitting exactly.
Problem is that as I removed it to fit sensors, there is no chance of getting it sorted under warranty. So can you help? The panel is boot interior driver's side, the one that supports the parcel shelf rubber 'bit' and meets the rubber boot seal. There is a white plastic clip near the top about half way along. It looks like a big white raw plug and is attached to the plastic panel and should push into the metal body of the car. The panel and approx position of the clip are shown by the black arrow in the pic below: ![]() Is it possible to order a new plastic clip, and if so, how much is it? |
Try this guy here:
kelliott@gowandunlaoghaire.com I had some queries and Kenny was very helpful. He's based in Ireland and is a parts manager, he hopefully should be able to let you know the part number so you can go back to your local dealer. Cheers Barry |
#5 (permalink) | |
John Pease - can you get hold of a couple of black plugs and a couple of white ones used to hold the plastic boot trim on? Almost all the plastic/carpet bits seem to be held on with the same black/white plugs, so hopefully it shouldn't be too difficult to find them?
Can you message me the cost and I will work out payment details. Thanks MAtt |
#10 (permalink) | |
John Pease Honda
Certainly, Just pick up the phone and speak to Craig 01376 334664
Regards Quote:
| Boot panel clip - can you help? | mattlittle | Holdcroft Honda | 7 | 29th October 2007 16:01 |
| Bodywork Manufacturing fault with Civic's boot panel? | AdamP | Bugs, faults and irritations | 29 | 30th August 2007 06:35 |
| Clip & Foam under sills? | WoolyCiv | General Discussion | 9 | 23rd July 2007 14:30 |
| viral clip - Aston crash | medicsource | Recycle Bin | 13 | 1st July 2007 10:38 |
| Mounts Brodit Pro Clip? | tonyt | Electronics | 9 | 3rd March 2007 07:57 |
