This thread is about: Temperamental Rear Interior Light, it's in Lights at the Honda Civic forum Civinfo; I swapped over to Blue interior bulbs a few weeks ago but the rear one is a bit temperamental - some times it comes on ...
Old 23rd January 2008, 12:15   #1 (permalink)
Loving It!!!
Maquis73's Avatar
I swapped over to Blue interior bulbs a few weeks ago but the rear one is a bit temperamental - some times it comes on and sometimes it doesn't
I have had the cover off to see if it is seated right and it seems to be ok - has anyone else had this problem.
When it first happened I thought the bulb had blown but it came on the next time I opened my door.
When it is on it doesn't flicker (even when tapped) so I dont think it has a loose connection.
Maquis73 is offline   Reply With Quote
Old 23rd January 2008, 13:01   #2 (permalink)
tomtank62's Avatar
I had exactly the same problem with the LED replacements- I kept taking the cover off and rotating the unit in the holder. I could never identify a specific problem with it. This went on for a few weeks and then no more problems.
tomtank62 is offline   Reply With Quote
Old 23rd January 2008, 13:09   #3 (permalink)
Have you tried putting the origianl bulb back to see if the fault is still there??
Old 23rd January 2008, 13:28   #4 (permalink)
Loving It!!!
Maquis73's Avatar
Not yet - I am going to swap them back over tomorrow. I don't even know if it had the problem before I swapped to the Blue bulb as I had only had the car a week and didn't take much notice when it was white.
Hopefully mine will sort itself out as well - I will keep my fingers crossed.
Old 23rd January 2008, 14:21   #5 (permalink)
Find the wires, solder them to the LEDs, settlement They tend to last longer than the car anyway so you won't have to solder them out again
Old 25th January 2008, 09:09   #6 (permalink)
I had this too, but some sand paper sorted it.
intermittent blue LED cluster problem
Old 25th January 2008, 09:18   #7 (permalink)
Loving It!!!
Maquis73's Avatar
Thanks for this - I will get the sandpaper out tomorrow
I think I will try the sandpaper approach first - but thanks for the advice.
Old 25th January 2008, 14:17   #8 (permalink)
Charles_Harding's Avatar
Try a bit of a nail file thingy, the paperish ones that is.
The emery board will be a bit more gentle.
My father is Scottish and my mother is Chinese.
They both support their ethnic roots.
So tonight will be a Chinese Burns night!"
Old 25th January 2008, 14:43   #9 (permalink)
Loving It!!!
Maquis73's Avatar
I have some very fine sandpaper at home which should be ok.
Similar Threads for: Temperamental Rear Interior Light
Interior Interior Boot Light dave525 Lights 5 26th November 2007 11:33
Red interior light mod FireStarter Type-R 10 20th August 2007 23:21
Rear Door Interior Skin Lucid General Discussion 1 26th February 2007 10:58
Interior Interior light Wesley Lights 5 31st August 2006 12:50
Interior LED on Interior Light?.... Raegten Lights 10 31st May 2006 14:01
