| This thread is about: Extra rear positioning lights, it's in Lights at the Honda Civic forum Civinfo; Should somebody be interested, there is a way to add 2 positioning lights at the back. The “unused” fog light can be used as a ... | ||
The “unused” fog light can be used as a positioning light, see picture. Still the original fog light remains unchanged in function. Leave a message if you need some more info |
I am a bit confused. You have changed the fog light into a position (tail) light, and the dummy one on the other side so they come on with the lights?
Is your fog lamp now used as a position light and a fog light, meaning it has two lamps in there? The other light has just had a low output lamp fitted? It looks good, actually. I would be more interested in just wiring up the second fog to work with the first, rather than used them as tail lights. Do you know if there is a limit on how much light or how bright the tail lights can be to stop dazzling outher drivers? |
The original fog lights remains the original fog light.
As soon as you turn on the fog light, the extra positioning light goes off and the original fog light burns at full strenght. It is a simple wiring. I installed the same light bulb (21W) in the non used fog light. When turning on the lights, this second lamp comes in series with the original fog light, resulting in an output of about 5W each, since they only get 6V each. ( half the voltage result in 1/4 of wattage). The most difficult part is to make the hole to fit an extra bulb connector. You have to make the same hole as the original fog light, buy a second fog light holder and connect between red wire of licese plate light and original fog light yellow wire. I have done this while I was installing the backup camera so I had access to all the wires... If you realy want to do this and you know nothing about removing pannels, drilling holes, wiring ... ask a friend who can ( or visit me in Belgium ha |
Allan,
When the fog is on, it consumes 1.4A (and the extra bulb is off). When the fog is off, the two 21w bulbs (fog and extra) are running in series, so consume a total of 0.7A, ie less than having the fog on. So there is no extra power consumption (though I wouldn't worry about hanging an extra few amps off a lighting circuit anyway!) My calcs are: I=W/V ie 21/14.4 = 1.45A R=V/I ie 14.4/1.45 = 10 ohm In series: 20 ohm, so I=V/R ie 14.4/20 = 0.7A Last edited by Pottsy; 19th October 2006 at 13:21. Reason: Maths/brain problem |
Pottsy is right
I did check this out first This is how the connector looks like: bought it from the dealer incl bulb for 9 Euro (if I remember correctly). Here also a picture of the hole you will have to make. First make the round hole (use a vacuum cleaner while drilling), then carve the 4 notches. afterwards vacuum the light for leftovers. If you want to come over to my place in Geraardsbergen I am willing to help. |
Yes WoolyCiv, I have most of the circuit diagrams.
Unfortunately I got then from my French speaking dealer, so some comments are in French on the diagrams. They are in pdf format and I did rename the titels in English. Total about 900Kb. Give me your Email and I send them to you. Stef. Email me a stephans@versateladsl.be EDIT: Pottsy: The files are now here: Civic 06 wiring diagrams + to do on my list Thanks Stef! Last edited by Pottsy; 21st October 2006 at 10:34. Reason: Added link to Stefs zip file |
#14 (permalink) | |
Your electrical skills are obviously better than mine- is there enough capacity to say fit a twin filament bulb 5w/21w, the 5w for tail light and the 21w for the fog light. With the bulbs wired in parallel? This would make the existing fog light a tail light, while retaining the fog light capability - the existing blank would then become a dual tail/fog light. There are certainly cars around with three bulbs per side for tail lights so brightness shouldn't be a problem - Volvo 480 for instance. Mike |
#17 (permalink) | |
My diagram works perfectly, and does not affect the original fog light capacity! It is illegal to have 2 fog lights, next to the licence plate. Furthermore the Civic original has 4 rear light, adding the 2 extra using my diagram, makes 6. The 2 fog lights in series have exact same capacity as a regular 2x 5W bulbs. Stef |
#18 (permalink) | |
Retro fitting may be a different matter, but I doubt it. There are regulations on brightess and spacing from other lights, but you are allowed one or two rear fog lights. |
#19 (permalink) |
Well better be safe than sorry.
Just think that with a Civic you would be driving in front of a car And 2 triangular exhousts And 4 rear lights He could be calling the police stating he saw a UFO |
| Fog Rear fog lights | djm | Lights | 18 | 3rd July 2007 09:07 |
| Rear Spoiler - Optional Extra | binchy | Cleaning and Styling | 5 | 13th June 2007 22:23 |
| Install extra rear positioning lights | Stef | How To | 10 | 10th May 2007 14:08 |
| Indicator Misterious extra front indicator lights | Stef | Lights | 51 | 5th February 2007 09:47 |
| Fog Rear Fog Lights | JPDirect | Lights | 17 | 5th November 2006 21:29 |
