This thread is about: illumination of H, it's in Lights at the Honda Civic forum Civinfo; good evening, here my realization with leds white That functions with fires...
Old 1st December 2006, 20:36   #1 (permalink)
mandrake10's Avatar
illumination of H
good evening,
mandrake10 is offline   Reply With Quote
Old 1st December 2006, 21:16   #2 (permalink)
PTR
PTR's Avatar
Originally Posted by mandrake10 View Post
good evening,
Aren't you afraid that the policeman will "kick your ass"?
Old 2nd December 2006, 00:25   #3 (permalink)
Works, but not something i'd really be interested in
Old 2nd December 2006, 10:06   #4 (permalink)
bounce75's Avatar
Personally I think it looks quite good, whether you would get away with it in the UK is another matter.
bounce75 is offline   Reply With Quote
Old 2nd December 2006, 23:03   #5 (permalink)
thiswilldo's Avatar
Maybe it would look better if somehow just the 'H' was illuminated from behind the same way that Wolseley cars had their badge illuminated many moons ago. The Wolseley badge top of the radiator was softley lit up....
Jeez, showing my age now !
thiswilldo is offline   Reply With Quote
Old 3rd December 2006, 11:13   #6 (permalink)
Smell My Cheese!
richierich's Avatar
Well before my time, but Wikipedia makes a good read for those who want more info.
http://en.wikipedia.org/wiki/Wolseley_Motor_Company
Old 3rd December 2006, 12:39   #7 (permalink)
Yeah 'thiswilldo' if the 'H' was illuminated that would look cool!
Old 3rd December 2006, 12:43   #8 (permalink)
AubreyS's Avatar
Showing my age now, my first car was a Wolseley 1100.
Old 3rd December 2006, 19:48   #9 (permalink)
Stef's Avatar
Hi Mandrake10,
Nice set-up!
just wondering, what type of positioning lights you got?
Old 3rd December 2006, 20:07   #10 (permalink)
mandrake10's Avatar
Originally Posted by Stef View Post
Hi Mandrake10,
Nice set-up!
hello stef,
I made a tutoriel, but in French....
my English is not very good
it's here :
http://www.f-forge.com?d=Rrg8tauIyVlLs7Hq3XnO
Old 3rd December 2006, 22:47   #11 (permalink)
Sky
Sky's Avatar
Location: Paris capital Froggy//Laussane a part of week
hello stef,
cocorico! ( http://www.civicyume.com/ power!)
Sky is offline   Reply With Quote
Old 4th December 2006, 20:38   #12 (permalink)
hello stef,
it's here :
Here's an automatic translation, done by software:
How to light up the "H":
Materials:
Wire blue (+) and chestnut (-) I took of 0,75 mm2 like section ..... Three leds white leds of 5mm 12.000 Mcd with resistor:
Some connectors like this:
Sheath thermo and insulating fabric
Tools
A soldering iron + solder:
A small drill with a bits of diam. 6 and diam. 5
+ flat screwdriver, cutter, grip with fine nozzle…. (small tools)
To start:
To prepare the leds (has to make Three times)
It is necessary to weld onto each leds (3) a resistance onto (+)
From memory it (+) onto a leds is the longest leg
Then a blue piece of wire on (+)
piece of maroon wire on (-)
Then place a sheath on to each leg for insulation.
Then to dismount the black mask has the front one, to remove the fasteners to pay great attention it are fragile, it is necessary to place a flat screwdriver of each coast of the fastener and to draw to the top gently by making light movement from left to right.
Then to dismount the mask of bulb headlight (me I chose coast accumulator) and to bore a hole in the centre of the aforementioned.
Then to carry out a piece of wire as on the photograph and to pass it in the hole
Then reference mark the leg (+) of the side-lights (light blue)
To place a connector on this wire and the end of the son to pass in the lid of the mask
Second stage:
Boring of the grille by the top:
PS: I have to replace the black mask to withdraw at the beginning, to trace his position on the grille, as that when I give it to the end, one does not see anything .......
For boring it is enough to go there all gently, I start with bored with the wick of 6 ONLY plastic, all into blowing to make leave the pieces of plastic. When plastic is bored, I change wick (5) and I bore the interior part (reflectors).
Small trick, if particle falls into the reflectors, I to use a very fine rigid sheath that I master keys in the hole to the particle, then I aspire gently to make it go up in the sheath to stuck on the end, I continuous has to aspire until the sheath that is to say any more in the reflectors and here I have to remove the plastic particle
Once borings carried out, I place the leds in each hole, which I clog with cement of plumbing (favours: it is waterproof, it is malleable, if ever a leds should be changed, that remains easily dismountable).
Then it is very simple, hardest is done .......
For the connexion the blue ones (+) on the blue son who comes from the mask that one made front
For chestnuts (-) I put them together and to place on a mass
ZOOM (detail connection leds on food)
Then one can of insulating fabric on the connector industries blue…. And one gives the black mask and the clips which it is enough to insert in the holes.
Finished result:
Mandrake10
Here is ...... Good luck!
Old 4th December 2006, 20:52   #13 (permalink)
gray52's Avatar
a neon 'H' would look the dogs, but this is abit chavish.
Similar Threads for: illumination of H
Electrics Steering wheel switch illumination? t8adc Electronics 3 28th September 2007 19:25
Electrics Button illumination Wildcat Electronics 2 7th July 2007 15:49
Other window cutout switch illumination Tomthumb Lights 7 21st August 2006 05:24
