This thread is about: Headlight washers? Should I have?, it's in Lights at the Honda Civic forum Civinfo; Originally Posted by Meino Can't complain about the lights, maybe because most of the roads in Holland are well lighted (correct english?). That's why I ...
Old 3rd February 2007, 00:30   #41 (permalink)
Originally Posted by Meino View Post
Can't complain about the lights, maybe because most of the roads in Holland are well lighted (correct english?). That's why I can't or maybe don't want to justify the € 1000
1k EU is a lot to pay for what you get. As you say the roads in Holland are well lit () so it probably isn't worth it at all!
czechplastik is online now   Reply With Quote
Old 7th February 2007, 09:00   #42 (permalink)
您看了
CivPilot's Avatar
Originally Posted by civicsport View Post
There not motorised PhilA, they use the high water pressure to extend the telescopic arms the nozzles are fixed to.
Interesting, I never knew that, always thought they were powered.
Might be why mine wouldn't return to flush this morning.
I cleaned a de-frosted the washer nozzles once I got to work to get the windscreen a quick spray to get rid of the road grime. However the windscreen nozzles froze again almost straight away (despite a winter mix of washer fluid) and after that the light washers would not return to totally flush (Passenger side was sitting about 3/4mm out, drivers side 2mm).
I'm guessing that the frozen main washers let the pressure build slightly and this back pressure kept the light nozzles out? I will try again at lunch time and if the nozzles still sit proud instead of returning to flush I will give my dealer a call as there might be an "error"
Old 7th February 2007, 16:53   #43 (permalink)
Galaxy class starship
Copycat's Avatar
Originally Posted by lippy View Post
On UK spec, the Sport has HID lights and headlightwashers. However some of you may not realise that the washers for the headlights only work when the lights are ON.
Originally Posted by BrianAlbertsen View Post
My civic holds around 6,5 lites of washing fluid. My old Pug 206 only held 2,5 liters. But I have to refill my civic more often.
Correct me if I'm wrong but you can still operate your windscreen wipers without using headlight washers if you switch your lights off or on to sidelights/position lights/parkinglights.
Not perhaps the most practical technique, but it might save you a krone or two.
Old 7th February 2007, 20:57   #44 (permalink)
Bournemouth Belle
lippy's Avatar
Just what I said - only a different way of putting it!!!!!
lippy is online now   Reply With Quote
Old 8th February 2007, 00:07   #45 (permalink)
alternatively, play the game where you pull the wiper stalk for a very short time. repeatedly.
The screen washers squirt almost instantly.
The headlight washers only squirt after a second or two
Old 8th February 2007, 06:37   #46 (permalink)
Copycat's Avatar
I know. And thank you for that.
My point was that even though we Finns and Danes can not turn the lights off, it's enough to switch to side lights only for a few seconds while you operate the washers.
Similar Threads for: Headlight washers? Should I have?
Head What Is The Point Of Headlight Washers? liamcalland Lights 31 17th October 2007 15:59
No front fogs or headlight washers in ctdi Sport Kirbs General Discussion 21 30th April 2007 20:16
Windscreen NO Washers??? markymark81 Bugs, faults and irritations 10 9th February 2007 20:57
Lights Faulty Headlight Washers kwokieuk Bugs, faults and irritations 7 19th December 2006 12:52
HID HID Washers Maldax Lights 2 13th November 2006 22:58
