LED lights I found them too low in brightness, then went for Cree lights and they look x100 better. Was recommended by a member her. 6months + and not failed once.
I bought ones from auto bulbs direct, recommend on a different thread. The led's were 501 Twenty20 Cree LED 12V W5W Canbus Wedge Bulb
I think you get a 10% discount if you use the CIVINFO code at checkout
HIDs Direct do good bulbs as well. Some times prices are slightly on the upper end but there's always a discount code kicking about every so often. I've had a set of side lights from them that have worked their way through three different cars lasting over 3 years.
I tried plenty both cheap and expensive T10 -W5W leds, they usually never last anything, most of the time the heat break the poor glue and the base and head separates or the cables is getting loose, bulb getting ultra low brightness or start to flicker. Only one I had for years (like 2012) is Philips ones, had them first as sidelight but last two years been going strong as number plate light, very happy about these. Kinda looks like these but I imagine there have been some changes from 2012.
Related Threads
2006+ Honda Civic Forum
2.5M posts
103.9K members
Since 2006
